Samsung TV LED Backlight: RGB, Remote Control, Strip Length, 5V USB or 12V - Which to Choose?
sebaele22 7374 6
  • #1 16878245
    sebaele22
    Level 30  
    Rate: 513
    Hello, I have been a Samsung TV holder for 55 weeks.
    I decided to do LED backlight in the back.
    I would like to ask what diodes to choose? Light color, RGB, with or without remote control, do the sections have to be long or better spot when it comes to LED strips? What voltage or 5V under USB or maybe 12V?
  • Recommend linear RGBW backlighting with included power supply
    #2 16878357
    mieszaczwcz
    Help: 185
    Rate: 258
    as for the wall lighting behind the TV I have mixed feelings are good and bad
    good is to reduce the contrast of the TV image with dark surroundings
    \ I would choose linear lighting, in my opinion spotlights would be distracting.
    \ Light intensity and color controlled by RGBW remote control, best for radio, why USB? power supply included in the set, e.g.
    https://led-hurt.pl/pl/p/Zestaw-2%2C5m-tasma-...SMD5050-IP20-pilot-40-przyciski-zasilacz/1810
    the biggest downside is the additional remote control, which simply dies in the most-needed moments; [
  • #3 16878398
    sebaele22
    Level 30  
    Rate: 513
    Hmmm, so maybe choose some steady light? In the previous 32-inch TV I had 3 stripes of 3 LEDs on each and were placed at the top and sides (blue).
    I will also want to put a white brick (old brick), but probably not so fast next year.
  • Recommending adaptive color temperature based on habits
    #4 16878458
    mieszaczwcz
    Help: 185
    Rate: 258
    Your concept is very good because of your own habits
    Nevertheless, following this example, Philips Ambilight would never have been created and what is more it is being further developed.
    I realized how a few years ago I installed the f.lux program which automatically changes the color temperature and brightness of the monitor during the day, taking into account the time, calendar and geographical location.
    For me, the difference is immediately visible when I sit at a foreign monitor.
    recommend
  • #5 16881097
    sebaele22
    Level 30  
    Rate: 513
    Hmmmm but will such USB diodes move damage the TV?
  • #6 16881179
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4259
    The USB port can be charged with 500mA - it is good to make a system that will consume less - and considering that the LED has a lighting efficiency of 8X better than the bulb and a forward voltage of 3V, you can have a power of 1.5W from these 500mA and it will be like a 12W bulb - it just fits as a light behind the TV to reduce the contrast.
    And as to whether it makes sense - a long, long time ago (probably about 40 years) in the "Young Technician" wrote that watching TV so that the eye is dealing with the contrast of a bright screen with a dark environment, is very harmful to the eyesight , and that placing the light behind the TV significantly reduces this harmful effect - for this you need to illuminate the wall behind the TV, and more precisely those parts that can be seen from behind the TV - having LEDs you can better plan the light system, so that less power is needed.
  • #7 16897640
    sebaele22
    Level 30  
    Rate: 513
    Hello, thank you for your help LED strip selected natural color, TV highlighted :-)
The discussion revolves around selecting LED backlighting for a Samsung TV, focusing on aspects such as light color (RGB vs. white), remote control options, strip length, and voltage (5V USB vs. 12V). Users express mixed feelings about the aesthetics and functionality of LED backlighting, with recommendations leaning towards linear lighting to avoid distractions. The importance of reducing contrast for eye comfort is highlighted, with suggestions for efficient LED systems that consume less power. Concerns about potential damage to the TV from USB-powered LEDs are addressed, emphasizing the need for low power consumption. Ultimately, the user decides on a natural color LED strip for their setup.
