XIAOMI Redmi 4X 3/32 EU: Query on Dual SIM Functionality after Incorrect SIM Card Insertion
harrymartin 4791 4
  • #1 16828108
    harrymartin
    My daughter inserted the sim card into the dual sim phone incorrectly. She put it directly in the device and not in the drawer and only the phone drawer. In addition, she pushed her with a drawer. Now the card is stuck at the very end of the slot. There is no way to get her out. I have a question if I would like to shorten a drawer so that it can be inserted into the phone only with the SIM card no. 2 Would the phone work in this case only on sim no. 2? Replacing the socket on the website costs about PLN 250. Thank you for any suggestions.
  • #2 16828123
    Szelma1
    Rate: 14
    I do not recommend, you can do more harm. You have to undress the phone and see if the sim slot has actually been damaged.
  • #3 16828269
    harrymartin
    Thanks for the answer. It seems to me that the nest is not damaged at all. But you would have to disassemble almost the entire phone to get into the bay. And if you cut a part of a drawer, you will need to buy a new one at the most, cost about PLN 25.
  • #4 16828348
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    I recommend disassembling the phone and pulling out the card, the idea of cutting the drawer is in my opinion bad.
  • #5 16828449
    lukaszd82
    Help: 143
    Rate: 491
    the socket is not damaged, a colleague did so in redmi 4x. You have to disassemble the phone, otherwise you can't pull it out. You have everything on film.
    link
    If you have never done it and have no manual skills, take the phone to a commission.
