SteelSeries Arctis 5 Headphones: Using Phone to Power Audio & LED Backlight Simultaneously
bartek0803 7908 4
  • #1 16828757
    bartek0803
    Can you use the phone to power both the headphones and the leds in them?
    Headphones: steelseries arctis 5
  • #2 16829483
    gradek83
    Help: 929
    Rate: 2099
    Connect it via the OTG cable and see if it works.
  • #3 16829874
    bartek0803
    I do not have these headphones, and I would like to listen to music via a 3.5mm jack from my phone.
  • #4 16829904
    gradek83
    Help: 929
    Rate: 2099
    There is an adapter so it should work. Unless the electronics in the headphones have some built-in battery. The LEDs can work if you use this knob, then you must read the manual for a preamplifier.
  • #5 16829971
    bartek0803
    There are no batteries in the headphones, and this knob is for changing the volume between chat and game. The manual says that the headphones are designed for mobile devices. The sound will come out, but I wonder if the leds will also light up, because nothing is written about it.
