Realtek Detection Issue: Steelseries 7h Headphones Recognized as Speakers in Rear Panel Jack
cryyc 32322 17
How can I make Realtek detect my headphones as headphones instead of speakers when plugged into the rear panel jack?
Uninstall the Realtek audio drivers; in the thread, removing them made the headphones start being detected correctly as “headphones” [#11878010] The motherboard/codec does not really distinguish speakers from headphones on its own—it only detects that something is plugged in—so the sound behavior is mostly handled by the driver and mixer settings [#11876258]
  • #1 11868298
    cryyc
    Rate: 15
    I have Steelseries 7h headphones connected to the jack directly to the rear panel and instead of Headphones, it detects as speakers. I connected others, the same.
    What should I do in such a situation? Please help.
  • #2 11868386
  • #3 11868428
    cryyc
    Rate: 15
    There is a difference in sound quality
  • #4 11868463
    wojtek0995
    Help: 80
    Rate: 121
    True, there is a different amplification for headphones. Click on the green circle on the right and select "headphones".
  • #5 11868532
    cryyc
    Rate: 15
    After clicking the green circle, nothing appears and there is nowhere to select "headphones".
    I will add that the audio driver version is: 6.0.1.6167
    audio codec: ALC892
  • #6 11868987
    wojtek0995
    Help: 80
    Rate: 121
    Double-click as when opening a folder.
    Moderated By DriverMSG:
    I edited the post. We start sentences with a capital letter.
  • #7 11868988
    DriverMSG
    Help: 3984
    Rate: 4883
    Connect headphones to the front panel.
  • #8 11870332
    cryyc
    Rate: 15
    Double-clicking does nothing. Clicking on these circles only changes the tabs, e.g. to the microphone if I click pink. On the front panel, if I plug in the headphones, nothing changes. I would like to add that before the format (made today) I had a sound blaster x-fi surround 5.1 pro sound card and in its configuration it was possible to change everything without any problems. I thought to change something in the registry, but I do not know anything about it.
  • #9 11870827
    DriverMSG
    Help: 3984
    Rate: 4883
    Disable headphone detection when connected to the front panel.
    Yellow icon on the top right in your screenshot.
  • #10 11871107
    cryyc
    Rate: 15
    I did as you said. When I connect the speakers to the rear or front panel (before disabling the detection option, of course) it always shows that they are speakers, headphones are the same. Screen after disabling detection options:
  • #11 11871135
    wojtek0995
    Help: 80
    Rate: 121
    Did you click twice? I also have Realtek and this is how it works :)
  • #12 11871192
    cryyc
    Rate: 15
    After all, I wrote that I turned off the front panel detection options ^^
  • #13 11871713
    DriverMSG
    Help: 3984
    Rate: 4883
    cryyc wrote:
    I disabled the front panel detection options
    And after this operation, the headphones work in the front socket?
  • #14 11872070
    cryyc
    Rate: 15
    After this operation, the headphones are still detected as speakers.
  • #15 11872775
    DriverMSG
    Help: 3984
    Rate: 4883
    Read my question again and give an answer.
  • #16 11874316
    cryyc
    Rate: 15
    This is how the headphones work but are detected as speakers
  • #17 11876258
    DriverMSG
    Help: 3984
    Rate: 4883
    Motherboard does not recognize devices, does not distinguish between speakers and headphones and will not detect them in any way. It only detects the connection of the device.
    You have a mixer at your disposal to set the timbre of the sound and that should be enough.
  • #18 11878010
    cryyc
    Rate: 15
    I uninstalled realtek drivers. Surprisingly, headphones began to be detected as "headphones".
The discussion revolves around a detection issue where Steelseries 7h headphones are recognized as speakers when connected to the rear panel jack of a computer. Users suggest various troubleshooting steps, including checking audio settings, disabling headphone detection, and connecting to the front panel. The author reports that despite following these suggestions, the headphones continue to be detected as speakers. A potential solution is found when the author uninstalls Realtek drivers, leading to the headphones being correctly identified. The conversation highlights the importance of driver compatibility and settings in audio device recognition.
