Golf VII Bixenon Coding - Elsa Scheme, VCDS 07coding, Byte 5-6, 16security Access, 5Q0 937 086 AK
tomasz.kochanski 7572 2
  • #1 16831221
    tomasz.kochanski
    Rate: 19
    I'm trying to code a bixenon in golf
    lamps connected according to the elsa scheme, but without coding a disco appears on them,
    when in options in vcds "07coding" I have only in one place it is possible to mark the xenon schuttle check box (it is on byte 5-6)
    but I don't see more about xenon.
    The question is, should I change something in the "16security access" options first?
    and then only look in "07coding" for the appropriate parameters?
    help me please I have demolished the car for 2 days, and it could use.
    ne one of the forums I found that my bcm is a high version
    5Q0 937 086 AK - although the 086 ending in my opinion does not confirm it.
  • #3 16832394
    tomasz.kochanski
    Rate: 19
    and anyone knows how to code a key in the mqb platform?
    or golf vii via VCDS?
