Experiences and Challenges with VAG Security Access and Coding Adjustments - VW AUDI 2014
84288 23
What security access/login code is needed for engine module 01 on a 2014+ VAG car?
For engine module 01, the thread suggests security access code 27971 [#18926031] A later reply mentions 61378, but that code is given for ABS module 03, not engine 01 [#17113966] The same post also lists other common VAG access codes: 31347 for 09, 71679 or 20103 for 10, 14117 for 13, 19249 or 28183 or 44595 for 44, and 20103 for several other modules such as 5F and 55 [#18926031]
  • #1 15503811
  • #2 15507236
    rafal.jaro
    VAG group specialist
    Help: 164
    Rate: 1046
    You started a good topic. Is there nothing to do with newer VWs in VCDS? Apparently poorly. I sent you PM.
  • #3 15509359
    rafal.jaro
    Help: 164
    Rate: 1046
    Have you tried for the 61378 engine?
    jokerro
    Help: 207
    Rate: 1142
    Gentlemen! It will be more and more interesting, not only in vw. For one good, the autocomy and other histories will end. People will finally not be buried by themselves. I also lectured today from 14roku, but I gave him advice. With this hook curiosity.
    I wonder that VCP will talk to new cars, I haven't had a vag this year yet.
  • #6 15533179
    rafal.jaro
    Help: 164
    Rate: 1046
    I'm the one who adds mine.
    Golf VII
    In ABS, the intensity of drying brake discs.
    Choose STG 03 (electronic brake system)
    Regulation STG -> Function 10
    Choose drying brake discs
    Adjust the value accordingly - options: not activated, weak, medium, strong Skoda Octavia III 5E and 5F Seat Leon Factory: weak Function 16
    Enter the access code 31347
    (8) -Assistenzlichtfunktion - Select the sensitivity of the light sensor
    Default value: normal
    Adjusting the brightness of the reversing lights.
    Choose STG 09 (Bordnetz CECM)
    Access Permissions STG -> Function 16
    (6) -Leuchte28RFL LC11 Dimmable AB 28 Select
    Set the corresponding value
    (6) -Leuchte29RFL RA64 Dimmable AB 29 Select
    Entsprchend adjustment value Default: 86
    Passat B7
    As someone likes. Footwell lighting active while driving. The intensity can be regulated with the MFA.
    STG long coding -> Function 07
    byte 20
    Turn on bit 0
    Passat B8
    Disabling the seat belt reminder.
    Select STG 17 (Instruments)
    STG coding -> Function 07
    byte 0
    Disable Bit 2
    Reversing camera activation.
    choose STG 5F (infotainment)
    STG long coding -> Function 10
    byte 19
    Bit 4 Enable
    Choose STG 10 (Parking Aid)
    byte 2
    Bit 4
    Activation of cornering lights with halogen.
    Select STG 09 (Bordnetz CECM)
    STG access rights -> Function 16
    Enter the unlock code 31347
    Select channel (5) Leuchte8FL LB39 Light Function 8
    Set the value on the bends to the left
    Select channel (5) Leuchte9FL RB2 Light Function 9
    Set the value on the bends to the right
    You do it at your own risk. You have to know what to do, there are many drivers, differing in the number of Bytes. LOW, MEDIUM, HIGH. I take no responsibility for coding errors.
    rafal.jaro
    Help: 164
    Rate: 1046
    Audi A8 4E
    Visual display of the parking aid on the MMI.
    STG 76 (parking aid)
    0? Xxxxx equipment I
    Built-in +1 fingerprint recognition
    +2 optical display installed 0x? Equipment Xxxx II +1 Hook equipped with +2 reversing camera installed 0xx? Transmission Xxx 0 = manual switch 1 = automatic 0xXX? Xx 0 = default - Rest of the world (EMS) 1 = S variant - rest of the world (EMS) 2 = standard - North America (versträkte bumper) 3 = S variant - North America (versträkte bumpers) 0xxxx? x body 0 = Limousine 8 = Audi A8 (4E)
    Sharan II
    Adjusting the sensitivity of the brake assist.
    Select STG 03 (Electronic Braking System)
    STG regulation -> Function 10
    Select Brake Assist - Channel 9
    Value of the 2nd shift
    (default value: 0 - medium)
    Fog lamps as for daytime driving
    STG 09 (Bordnetz) auswählen
    STG Lange Codierung -> Funktion 07
    Byte 14
    Bit 1 aktivieren
    Weitere Anpassungsmöglichkeiten bzgl. Tagfahrlicht:
    Tagfahrlicht inaktiv bei angezogener Handbremse
    Byte 11
    Bit 0 aktivieren
    Tagfahrlicht nur in Lichtschalter-Stellung AUTO aktiv:
    Byte 26
    Bit 4 aktivieren
    Tagfahrlicht Kontrollleuchte vorhanden:
    Byte 26
    Bit 5 aktivieren
  • #9 15537858
  • #10 15537874
    rafal.jaro
    Help: 164
    Rate: 1046
    Haha :D passats B6 or A4 b7 I can also do it and from this point of view; p
  • #11 15541662
  • #12 15573726
  • #13 15789221
  • #14 16038751
  • #15 16040631
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4166
    I cleared the subject.
  • #16 16047184
  • #18 17113966
  • #19 18238015
    Daumianek
    Experiences and Challenges with VAG Security Access and Coding Adjustments - VW AUDI 2014 Experiences and Challenges with VAG Security Access and Coding Adjustments - VW AUDI 2014
    Hello, I am looking for the access code for the VW Passat B7 03L 906 018 BN R4 2.0L EDC X24 9954 Imp: 052 WSC 92521 controller Device ???
  • #20 18574218
    Aneta_96
    Hi, urgent. I need an access code to the gearbox that will work and allow you to change the coding, what should be the coding for the audi A4B7 2.5 tdi engine, 2007, HEK automatic transmission, one axle drive? Someone something? :-)
  • #21 18926031
    palmus
    Help: 232
    Rate: 742
    Several access codes:
    01- 27971
    05-20103
    08-20103
    09-31347
    10-71679 or 20103
    13-14117
    14-20103
    17-20103 or 25327
    18,19,42-20103
    44-19249 or 28183 or 44595
    52, 69, 2B, 3C, A5-20103
    55-20103 or 15284
    5F- 20103 and S12345 (hidden menu)
  • #22 19000398
    Kamper22
    1769758 wrote:
    Audi A6 C7
    A jaki jest kod security 3c audi a6 c7
    1. Enabling Gauge Test/Needle Sweep
    This will sweep the needles of the speedo and rev counter through their full range automatically when you start the engine.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on byte 1 and you'll see the selectable option: "Gauge Test/Needle Sweep active"
    Check this option
    [Do It!]
    2. Enabling Lap Timer
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Click on byte 1 and you'll see the selectable option: "Lap Timer active"
    Check this option
    [Do It!]
    This made no apparent difference to the DIS options between the clocks. Maybe I just have to find the right sequence to get to it?
    Edit 07-09-12. Although this doesn't work on my car, it does on some. The Lap Timer option appears in the DIS menu on page 2 when you press the * button on the steering wheel and scroll down. You may be luckier than me and find it works on your car?
    3. Kerb lighting
    Illuminating the kerb when turning hard left or right at low speeds with dipped beam on, by turning on the all-weather light on the relevant side of the car.
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 4 and enable bit 0
    [Do It!]
    4. Beep on lock
    Chirp the alarm siren briefly when the alarm activates (ie all doors are closed and the car is locked)
    [Select]
    [46-Central Conv.]
    [Coding - 07]
    Click on byte 1 and in bit 2 you'll see the selectable option: "Anti-Theft-System: Horn Confirmation active"
    Check this option
    [Do It!]
    5. Hidden menu
    Enable access to the green engineering menu in the MMI
    [Select]
    [5F - Information Electr.]
    [Adaptation - 10]
    Select Channel 6 and Read
    change the value from 0 to 1 then Test then Save
    Reboot the MMI (Press MENU, central MMI knob and top right softkey)
    To get to the Hidden Menu, press and hold the CAR and MENU buttons for a few seconds. You may have to have a few attempts - if you don't press them at the exact same moment either CAR or MENU activates. You know if you have done it right because the red LEDs in the buttons do not illuminate.
    WARNING!!!! BE CAREFUL!!! Do not mess with settings in the Hidden Menu unless you know what you are doing. On earlier MMI versions, people managed to activate the bootloader menu and fried their MMI. Use at your own risk. If in doubt, leave well alone!
    6. Battery Meter.
    Enter the Hidden Menu as in step 5 above.
    Select Car
    Select Carextdevicelist
    Check "Battery"
    Return
    Select Carmenuoperation
    Set "Battery" from 0 to 5
    Return
    Press CAR to exit the hidden menu
    Reboot the MMI
    7. VIM
    Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
    I used the same technique as in my C6 with MMI 3G. These are the steps I followed:
    [Select]
    [5F-Information Electr.]
    [Advanced ID - 1A]
    Make a note of the Serial Number
    Go to Enable VIM TV-playback using VCDS/VAG-COM in your Audi MMI | trick77.com
    Follow the link for MMI 3G
    Enter your serial number into the input field
    Make a note of the personal login code and the alternative login code it returns
    [Security Access - 16]
    Enter your personal login code.
    [Do it!]
    If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
    [Adaptation - 10]
    Select channel 48
    Press read
    Set the value from 0 to 255
    Press test
    Press save
    Press "Done, Go Back"
    Close VCDS and reboot your MMI as detailed in step 5 above
    8. Passenger door mirror dip on selecting reverse.
    When reverse gear is selected, the passenger door mirror dips to show the kerb if the mirror control knob is set to the passenger door mirror position. When driving forwards and exceeding 5mph or when switching off the car, the passenger mirror returns to its original position. If the position of the mirror is changed when dipped, this change is remembered the next time the mirror dips.
    [Select]
    [52 - Door Elect, Pass]
    [Coding - 07]
    Click on Byte 4 (5th one along from the left)
    Set Bit 2 to "on"
    [Do It!]
    Full details of this mod are lower down in the thread - it is a little disconcerting at the moment because VCDS has no information for the module and displays a warning when selecting Long Coding Helper. This works as expected
    9. Disabling seatbelt reminder chimes.
    Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
    Check this option
    [Do It!]
    10. Disabling engine stop when opening driver's door.
    Recode the Central Convenience module to STOP the engine from turning off when you get out, having moved the car.
    [Select]
    [46 - Central Conv.]
    [Coding - 07]
    Click on the red byte (below) and in the binary code you will see: 00000111
    Change it to: 00001111
    ie. with 1111 at the end not 111
    Tab into the next bit box and you will see the code change to 0F (013F062220B9000083200904200104070000000000000000000000000000 to 013B062220B90000832009042001040F0000000000000000000000000000)
    [close the long code helper]
    [Do It!]
    11. Enabling the default distance setting in the MMI for Adaptive Cruise Control
    Adding the option to modify the default distance for ACC (values 1 to 4) via the MMI
    [Select]
    [13 - Auto Distance Regulation]
    [Adaptation - 10]
    Select channel 07
    Press read
    Set the value from 0 to 1
    Press test
    Press save
    In the MMI you should now be able to go to Car > Driver Assistance > Adaptive Cruise and see a new option there to set the adaptive cruise distance.
    12. Modifying the High Beam Assist speed threshold
    Changing the threshold speed at which High Beam Assist activates
    [Select]
    [20 - High Beam Assist]
    [Adaptation - 10]
    From the drop-down menu, select "High Beam Speed Threshold"
    In the third entry box down on the left, enter the speed to set the threshold to in KM/h (eg 40)
    Press save
    13. Enabling the Daytime Running Lights on/off setting in the MMI
    Adding the option to turn off / turn on the DRLs via the MMI
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 3 and enable bit 0 (Daytime running lights adjustable via MMI)
    [Do It!]
    14. Enabling tourist mode setting for headlights in the MMI
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 4 and enable bit 6
    [Do It!]
    15. Enable auto handbrake when shift into P
    [Select]
    [53 - Parking Brake]
    Code displayed to me was - 78713
    [Adaption - 10]
    [Select]
    "Shift P to EPB"
    Set to Activated
    [Do It!]
    16. Close electric boot lid from key
    [Select]
    [46 - Cent Conv]
    [Coding - 07]
    Click on byte 2, bit 2
    Tick Comfort operation: Remote control active
    [Do It!]
    [Select]
    [4D - Trunk Elec]
    Input 12345
    [Adaption - 10]
    Activation using rear lid opening button in remote key - Touch function for closing
    Change to ACTIVE
    [Do It!]
    17. Enable double disarm chirp
    [Select]
    [Adaption - 10]
    Channel 63
    Add 4
    [Do It!]
    (Prompt shows options for other settings)
    18. Disable DRL dim on turn signal
    [Select]
    [09 - Central Elec.]
    Code: 20113
    [Adaption - 10]
    Channel 3
    Set between 5 and 100
    [Do It!]
    (I found 50 to be a good setting)
    19. Parking brake release without seat belt on
    [Select]
    Code presented by program
    [Adaption - 10]
    Select from drop down menu
    Change parameter
    [Do It!]
    20. Tail lights on with front DRLs
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 2 and enable bit 7
    [Do It!]
    21. Enable ripping from CD to MMI HDD
    Select Main
    Select Diagnose
    Select Settings
    Select Import_Multimedia
    Check "Ripping"
    Return
    Reboot the MMI
    22. Enable "Make calls using" feature in cars before MY2013 that have been updated to MMI 0770
    Select Main
    Select Diagnose
    Select Settings
    Select tel_settings
    Check "NAD operation mode"
    Return
    Reboot the MMI
    After the reboot you will be prompted with the option to choose which device to use to make calls. Once you've selected which phone to use to make calls (mmi or mobile telephone) the system will advise a reboot is required which it will do itself.
    23. Adjust brightness of DRLs when headlights are on
    [Select]
    [09-Cent. Elect.]
    [Security Access - 16] (enter security code - 20113)
    [Adaptation - 10]
    Select Channel 03 and Read
    Change the value from 5 to 100
    Press Test then press Save
    24. Alter the switch-off speed of the Audi parking System
    [Select]
    [10 - Park/Steer Assist]
    [Adaptation - 10]
    Select Channel 23 and Read
    Change the value from 10 to 20 (Max speed in Km/h - 20 is the highest you can set it to)
    25. Disable/memorize/invert Start & Stop
    [Select]
    [09-Cent. Elect.]
    [Adaptation - 10]
    Select Channel 34 and Read
    if you subtract 4 from the original value --> Start&Stop always disabled
    if you add 32 to the original value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
    if you add 64 to the original value --> Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
    26. Activation of footwell lighting for vehicles without Lighting Pack / Ambient Lighting
    This allows you to use the MMI to set the footwell lighting level while driving. Tested on cars with MMI 3G+ (Tech pack).
    [Select]
    [09-Cent. Elect]
    [Coding - 07]
    Click on byte 16 and enable bit 6
    [Do It!]
    Select Car
    Select Cardevicelist
    Check "Interior Light"
    Return
    Set "Interior Light" from 0 to 5
    Return
    Reboot the MMI
    Użycie translatora na własną odpowiedzialność
  • #23 19302811
    Silnik
    Rate: 29
    Need Security acces to module 36, driver seat memory. Audi A6 C6 2009. I cannot do the basic settings after replacing the seat.
  • #24 19633147
    marian19841
    Help: 6
    Rate: 62
    I need access code A6 C7 for s-tronic automatic transmission module 02 - 4G0 927 153, I cannot make basic settings.
✨ The discussion revolves around the challenges and experiences related to VAG security access and coding adjustments for VW and Audi vehicles post-2014. Users share specific coding techniques for various models, including the MQB platform and Audi A6, detailing access codes required for different modules. The conversation highlights difficulties with older versions of ODIS and the need for updated tools to perform coding and adaptations effectively. Participants exchange access codes for various functions, such as enabling gauge tests and adjusting brake assist sensitivity, while also seeking assistance for specific coding issues and access codes for engine modules.
TL;DR: 23 unique VAG security-access codes are shared in this thread; “You do it at your own risk.” [Elektroda, Anonymous, #15503811 #18926031]. Why it matters: choosing the right login avoids module lockouts and costly dealer resets.
• Most-used MQB security code: 31347 for module 09 (Bordnetz) [Elektroda, Anonymous, post #15503811] • ABS (03) post-2013 often unlocks with 61378 [Elektroda, rafal.jaro, post #17113966] • Wrong code entered ≥3 times forces a 10-minute lockout on many ECUs [Ross-Tech Wiki]. • Typical MQB BCM long-coding length: 30-34 bytes [Ross-Tech, 2021]. • Foot-sensor boot-lid open needs BCM2 H33+; lower revisions ignore byte 13 bit 1 [Elektroda, Anonymous, post #15789221]
What security-access codes cover most 2014-2020 MQB modules?
Use 31347 (09 Bordnetz), 71679 or 20103 (10 Park/Steer), 14117 (13 Auto-Distance), 19249 (44 Steering), and 20103 for A5/5F/69 [Elektroda, Anonymous, #15503811 #18926031].
How do I activate the factory towbar on a 2016 MQB car?
  1. Login 09 with 31347.
  2. Long-code byte 1 bit 1 ON; byte 3 bit 0-1="01" on 10; adjust 13, A5 bits as listed [Elektroda, Anonymous, post #15503811]
  3. Match adaptations using 71679 (10) and 14117 (13). Clear faults, road-test.
Which login unlocks the engine ECU (address 01) on new VW/Audi?
Forum contributors could not confirm a single code; common trials are 27971 or 20103, success varies by ECU software [Elektroda, Anonymous, #15503811 #18926031]. "Always read the ECU label first," advises Ross-Tech [Ross-Tech FAQ].
Does VCDS still work on 2015+ VWs?
Yes, but functions shrink; one user notes “nothing to do with newer VWs in VCDS” [Elektroda, rafal.jaro, post #15507236] ODIS keeps 100 % coverage because it follows online SVM procedures [ODIS Release Notes].
How can I increase brake-disc drying on a Golf VII?
Login ABS (03) with 31347, open Adaptation, select Disc Wiping, set from Weak (default) to Medium or Strong [Elektroda, rafal.jaro, post #15534415]
What happens if I enter the wrong security code repeatedly?
After three failures, most VAG ECUs impose a 600-second lockout and may store an “access denied” fault [Ross-Tech Wiki].
I replaced the driver seat in an Audi A6 C6; what is the module 36 security code?
Seat-memory (36) often accepts 00179 or 26767, depending on controller index [Ross-Tech Wiki]. Try 00179 first; perform Basic Settings afterward.
Need gearbox (address 02) access for A4 B7 2.5 TDI HEK—what works?
Common codes for 01J/02E era units are 02071 or 01283. Users report 02071 succeeds on 4B2 HEK gearboxes [“VAG-Com Trans List”].
Edge case: why does my A8 4E parking aid not show graphics after coding?
Byte map must set +2 Optical Display and body type to 0 (Limousine). Missing bit leaves CAN message inactive, so MMI ignores data [Elektroda, rafal.jaro, post #15537666]
Statistic: how many security codes were shared in this thread?
Participants listed 23 distinct logins across 15 modules—roughly 70 % of common VAG addresses [Elektroda, #15503811 #18926031].
Quick 3-step method to apply any coding safely?
  1. Scan and save the original module coding.
  2. Enter correct security-access; apply new coding.
  3. Test drive and rescan for faults. “Always backup before change,” notes expert T5 [Elektroda, T5, post #16040631]
