New washing machine - low-failure, durable, low water consumption
magdalenaaaaa 1308 1
  • #1 20266855
    magdalenaaaaa
    Hello, I need to buy a new washing machine - reliable, of course. I don't need any goodies. What can you recommend and what to pay special attention to. So far, I have used a Bosch WFO2063PL washing machine.
  • #2 20266881
    Kenworth 18
    Help: 2442
    Rate: 3749
    Fix this Bosch if it has broken down and works twice as much as the current hardware. However, if there is pressure on something new, please specify what criteria the equipment should meet. If a load of 6-7 kg is enough, you can consider Bosch from the WAJ series or a slightly larger Bosch from the WAN series. Any model and the fewer fountains the better.
