GTA V Launch Issue: 826 MB Update Repeatedly Downloading - Original Boxed Version Problem
AgeMen 5055 3
  • #1 16833577
    AgeMen
    I have a big problem with GTA V. The game fresh after installation downloads an update of about 826 MB each time I start it. After downloading it, you can play, but the next time you turn it on, the problem returns. Before that, I was doing a full disk format, reinstalling Windows. Of course, I tried to reinstall the game, but nothing has changed. GTA, of course, the original, a boxed version.
  • #2 16834697
    atomic99
    Help: 171
    Rate: 338
    I also had problems with GTAV updates after reinstalling the system, this program helped me (I tried to find the link, but I think they deleted the file from the servers, so I'm attaching):
    Let me know if it helped.
    @AgeMen Files are unpacked normally, 7-zip file * .001 "Extract here" option
    • GTAV_Setup_Tool.zip.002 (91.05 MB) You must be logged in to download this attachment.
    • GTAV_Setup_Tool.zip.001 (95 MB) You must be logged in to download this attachment.
  • #3 16835160
    AgeMen
    Thanks for the offer, I will let you know soon if it helped
    Added after 27 [minutes]:
    I tried to unpack both files, but the archive is damaged in both cases, have you checked these files against operation? Or maybe I did something wrong?
  • #4 16838819
    AgeMen
    I finally found a solution.
    In my case, it was really enough to copy the game data (GTA V folder) to another partition on the disk and delete the remnants (rockstar folders or the current installation). Then I created a new account with administrator privileges and reinstalled the game. Everything works as it should. Subject exhausted.
