[Solved] Deep Well Drilling Issues: No Water in Mountain Area, Crawler Rig, Hydrogeological Maps, 46m
dariusz_pt 29832 43
Can a second well only 10–15 metres away find shallower water after two 46-metre boreholes through slate were dry, and is the dowser’s prediction reliable?
Yes, groundwater depth can change over short distances in mountainous terrain because aquifers may follow irregular geology and the land surface; one example found water only after drilling to 67 m rather than the predicted 30–40 m [#17571748] However, a dowser’s marked points do not provide a scientifically reliable indication of either water presence or depth; controlled testing has not demonstrated dowsing to work better than chance [#17572370] The two dry holes therefore do not prove that a shallow source exists 10–15 m away, nor do they validate the dowser’s claim. Before paying for another hole, obtain better local geological information and establish in writing whether the contractor charges only if usable water is found; deeper drilling may require different equipment, permits, and substantially higher cost [#17570803]
  • #1 17567493
    dariusz_pt
    Rate: 18
    Hello everyone. I live in a mountain area, a long and narrow plot with a slight slope. This year, water problems started. Until now, I used water from a dug well distant from the house about 1 km, the water flowed under its own pressure. There is no chance of a water supply in the area and a decision was made to drill a deep well. I was looking for a company that has a small crawler drilling rig because the plot is narrow and built-up and not all equipment will enter. I found a drilling company and thought they would send some dowser to look for somewhere to drill beforehand, but the owner only asked for a plot number and said they only rely on hydrogeological maps. After checking, it turned out that on my plot there should be water everywhere. Drilling was performed using the hammer method. The first borehole is 46 m, at the beginning to about 10 meters clay and loam, and then slate. Water appeared at the beginning of drilling and then it was dry until the very end. A second borehole was made, approx. 40 m away from the first one. The situation was similar, at the beginning clay and loam, and then up to 46 m of slate and no water drop. Desperate, I thought to dig a vertebral well at the site of the first bore, where some water appeared at the beginning of drilling. I called the dowser to the plot to mark the place for digging. After checking, the guy marked a few points distant from the first bore, about 10 and 15 m and found that there was water in these places and at a depth smaller than the bore was made. Gentlemen, what to think about it, is it possible.
  • #2 17567657
    stanislaw1954
    Help: 2013
    Rate: 4676
    The topic of looking for and digging a well - very interesting and complicated at the same time.
    A few years ago, a similar situation - looking for water on the plot. Gorlice area. How many people are looking, so many locations of a well digging point, and there were over ten of them on a plot of about 40 ares. Of course, everyone boasts about how many well locations they were able to mark, but I did not ask (out of politeness) how many locations were missed. Of course, how many people are looking, so many locations. Nobody confirms the point of the same. Worse - if you hammer the stake, the next seeker immediately points out "what is the stake for", and if you say that someone has pointed the water there, then absolutely, there is nothing to dig there, only where "I" shows. Currently, there are three 8-10 m dug wells on this plot. About the deep-sea - nearby, according to many opinions, it makes no sense to drill, even according to the maps. In each of these wells there is so-called water. subcutaneous, which you will choose during the collection, when it is very dry. You have to save yourself by delivering.
    After digging the first well, someone suggested that after finding a better location, before starting to dig, try drilling. I did so too. Middle of summer, hot weather, it hasn't rained for several weeks. Hand drilling, approx. 5 m. On the following day, the hole with a diameter of 8 - 10 cm is almost full of water. Decision to dig. Hand dug 5 - 6 m, the deeper the drier. After a few weeks, it was covered up.
  • #3 17567931
  • #4 17567976
    stanislaw1954
    Help: 2013
    Rate: 4676
    101pavel ] A very wise statement, especially if you live in a block of flats, or in areas where drilling a few meters in the ground, or sometimes punching a pipe (drilled on the sides and ended with a spike) gives you constant access to water.
    Unfortunately, there are areas in our country where people have to take care of access to water themselves. I mean mainly the inhabitants of the countryside, where the relevant local authorities, so far, have been doing nothing, pretending that there is no problem. It is best if the residents themselves will ensure it individually.
  • #5 17568263
    dariusz_pt
    Rate: 18
    All the companies in my area that I have spoken to charge a fee even if the well fails. This dowser confused my mind more and I am wondering whether I should hire another drilling company and drill in the place indicated by him. But does it make sense, there are no drilled wells in the immediate vicinity. The closest is approx. 3 km in a straight line. Very hilly terrain.
  • #6 17568369
    stanislaw1954
    Help: 2013
    Rate: 4676
    dariusz_pt wrote:
    There are no drilled wells in the immediate vicinity. The closest one is approx. 3 km in a straight line.
    Yes, you have experience on your part.
    Well, you've already tried in two places, and the plot is probably small, and how
    Only maybe the depth of the seams is either unattainable for these drillers, or simply the drilling range exceeds the permits of "mortals", not to mention the cost.
    And have you not thought about deepening the existing well or increasing the volume (reserve)?
  • #7 17568626
    janek1815
    Help: 372
    Rate: 1062
    For me, there are areas where you show where you want to have wells and drill there until water appears. I did not even realize that there are areas in our country with such water availability. I have a water supply, but we haven't used it for almost three years because the water is too expensive. Apparently PLN 4 / M3, but I use over 100 m3.
  • #8 17568675
    stanislaw1954
    Help: 2013
    Rate: 4676
    There are areas where wells are dug or drilled, and there is no water anyway, and the costs are incurred. How many months could water be used, eg 4 PLN / m3, if the drilling expenditure went down the drain, for example by the founder of the topic. And yet digging a well or drilling a well is not the end of costs, because the pump, pipes, fittings and electricity, but also sometimes something breaks down, or worse, water resources shrink, if only because of drought.
  • #9 17569743
    dariusz_pt
    Rate: 18
    When there was a shortage of water in the current well, I wanted to deepen it, but water experts decided that it would be useless. The well is located in a ravine under a large hill. It only has 3 vertebrae but when it was dug water poured over the cover. When there was no drought, the water supply ranged from 1-1.5 circles. Now practically the basket with the tube is above the water. Experts have found that this source has such a level and there will be no more water, we have to wait for better times.
  • #10 17569762
    retrofood
    Help: 1140
    Rate: 4800
    dariusz_pt wrote:
    But does it make sense, there are no drilled wells in the immediate vicinity. The closest one is approx. 3 km in a straight line. Very hilly terrain.
    The undulations of the terrain do not prevent the existence of an aquifer. Especially in such a complex terrain as you present.
    What about the advice of the dowser? You don't have any other choice and you must take the risk.
    But someone found this place once, very close to the surface. So the existence of other such points cannot be excluded.
  • #11 17569821
    dariusz_pt
    Rate: 18
    From what I have read, aquifers deep underground are large areas of sand filled with water. It is from these decks, after drilling, that water is drawn. There are no water veins, as the dowser put it. I don't understand how moving 10 or 15 meters from a borehole with no water at 46 meters will make the water at a shallower depth. This is the only reason why I wrote this post so that someone clever would dispel my doubts. There is no point in discussing how to search for water.
  • #12 17569896
    stanislaw1954
    Help: 2013
    Rate: 4676
    dariusz_pt wrote:
    I do not understand how moving 10 or 15 meters from a well with no water at a depth of 46 meters will make the water at a shallower depth.
    If it were so easy to explain, then in many places a few wells would not be dug, deluding that they would finally find the source ...
    In # 2 I described a case of looking for and digging 3 wells, where unfortunately it cannot be said that a spring was found, and a neighbor has 1 well next to it and I did not know that he had to deliver water. And I know for sure that this well is not deeper than the 3 described ones. Miracles or hitherto unexplored phenomena?
  • #13 17569951
    wiesiekmisiek
    Help: 259
    Rate: 524
    The dowser will point out the places where the twig will be torn from his hands, but will never say at what depth this water vein is. Gentlemen, please don't laugh. My brother showed me this method. At first I did not believe, I mocked him - but when I got this piece of a forked tree branch (some deciduous branches, maybe even aspen), I clenched my fists and walked around my recreational plot in several places until my hands were torn down and the end of the branch leaned towards the ground . Only this small but - no dowser will tell you the depth, it can be 2 m or maybe more than 100.
  • #14 17569965
    klamocik
    Level 36  
    Help: 334
    Rate: 727
    If you want to check the dowser, after the first marking of points, of course not for free, make him agree to blindfold himself and lead through these points or they prove to be confirmed, I tried twice to be surprised.
  • #15 17569978
    stanislaw1954
    Help: 2013
    Rate: 4676
    I do not have such abilities myself, and I have seen dowsers looking for water more than once. Some of them try to define the digging depth by some additional "steps", while others do not. Since I have encountered more than once that another dowser negates the point indicated by the previous "finder", I get the impression that these attracting forks of strength do not necessarily come from the water deck. In that case, I ask myself what influences there in the ground a piece of a twig or the hands of the seeker. Maybe mineral deposits, but which ones?
  • #16 17569982
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    The twenty-first century, a technical forum, and the belief in a shaman dowser still resides in the nation.
    Can someone explain to me what this water detection with a stick is about? What physical phenomena take place there?
  • #17 17570003
    stanislaw1954
    Help: 2013
    Rate: 4676
    When pulling the forks to the ground, dig wells in a place where water can be expected>.
    I do not know this and I think that others do not, but the question is why one person pulls a stick, and others I do not know how much they tried NOT.
    And when it comes to faith / unbelief, a person grasps various things, when he has to dig wells, because without water, there is no life, and the state (you can enter various entities, such as a commune, a self-government, a cooperative, etc.), does not provide water.
  • #18 17570196
    janek1815
    Help: 372
    Rate: 1062
    Well, what about the commune. We have a water supply, but there are single houses where it does not exist and it does not make economic sense to connect it, the commune pays money for wells.
  • #19 17570266
  • #20 17570351
    xury
    Help: 878
    Rate: 1498
    I do not see any embarrassment there. Just as a tech, I asked a question. In an age when we, as humanity, look light years into space, how is it that a few meters underground someone is looking for water with a wand. Since there are many such magicians, then there can be some secret knowledge. And if there are no such lectures, how is it that such a gentleman acquires this knowledge? Or maybe I'm wrong and there are some symposia / congresses of dowsers from time to time where they exchange their experiences and write lectures on this topic?
  • #21 17570388
    wiesiekmisiek
    Help: 259
    Rate: 524
    And now I will ask you a question, buddy? Have you ever slept in a bedroom near a water vein? What were your feelings because you probably didn't get enough sleep. There is a partial answer to your question in this phenomenon. And please do not send the forum members to another era. This is my request. Regards.
    PS If you grabbed a piece of such a twig yourself, you would probably believe it. I was an unbeliever too, and even laughed at it. Now I have changed my attitude towards this phenomenon which is also closer to me.
    Coming back to the topic, what do hydrological maps say about your plot and is there no executive who would actually undertake a well drilling with a positive and payable effect only when water is available?
  • #22 17570391
    stanislaw1954
    Help: 2013
    Rate: 4676
    Dowser meetings happen and they probably exchange their experiences, although I will not indicate either the place or the address, because I was not interested in it.
    xury wrote:
    how is it that a few meters underground someone searches for water with a wand.
    Because it is, after all, a cheaper "method" than a well for which you have to pay (at least that's how it is heard in my area), PLN 200-300 per meter. drilling, and no one comes to, say, 10 meters. What if we drill 40 meters. and there will be no water? 8,000 to 10,000 PLN from the pocket and the drill is satisfied. We have a little less, because no water, no money in my pocket. And I haven't heard of any company doing it for free, unless you dive into the water.
    I mentioned it. Take only a fork from a tree, e.g. hazel, and try it. Perhaps you have a "gift".
  • #23 17570614
    dariusz_pt
    Rate: 18
    I am asking you to close the topic because I have not received any constructive answer to my question and the discussion goes on topics unrelated to the question.
  • #24 17570684
    Darom
    Electrician specialist
    Help: 231
    Rate: 588
    It is interesting that many have the property of being able to find a water course. I have a friend, an electrician who deals with the automation of large boiler rooms and has this talent. It's a game for him, and he doesn't take any money for it. Phenomena are waiting for an explanation and sooner or later they will be explained.
    And what could a friend expect. The exact location of the watercourse?
  • #25 17570759
    stanislaw1954
    Help: 2013
    Rate: 4676
    You can close the topic yourself. Tips are -between the lines. The question is who to trust, or map specialists, because, unfortunately, science fails here as well. And the water may be in your area, but at much greater depths, which involves drilling costs, but also other equipment, because drilling 40m, and e.g. 100m (or maybe more) is a difference. have permission to drill at greater depths.
    Or maybe try to dig a well in the location indicated by the dowser? Unfortunately, there is no right answer here and it will not be. If you manage to dig up and there is water, the supporters of dowsers will triumph, and if not, a group of "modern" people will laugh, mocking .
  • #26 17570803
    CMS
    Help: 258
    Rate: 2601
    16 posts and someone has just touched on this topic.
    101pawel wrote:
    If, on the other hand, I was to try to answer your question, I answer: - there are physical phenomena that you do not understand. And don't take it personally, this ignorance isn't because you were slacking off at school, it's just that our brains are too tight.
    Explain, then, because maybe others will understand.
    And now, behind Wikipedia:
    Radiesthesia (Latin radiatio - radiation and Greek aesthesia - sensitivity) - pseudoscience dealing with alleged [1] radiation. The essence of dowsing is their detection by a dowser using devices such as a wand, a pendulum, and even without any tools [footnote needed]. It is used to detect the so-called water veins, minerals and many other objects. The term dowsing was introduced in the 1930s by the French dowser priest Alexis Bouly (1865-1958) [2]. The technique of dowsing is also known as rhabdomancy or dowsing [3].
    Phenomena studied by radiesthesia are sometimes classified as paranormal phenomena . In the vast majority of Western countries as well in the scientific community, dowsing is considered pseudoscience , and reliable scientific research shows that dowsers are not able to find hidden objects from efficiency greater than it would appear from pure chance [4]. However, there are few scientific works in which the claims of dowsers are taken quite seriously [5].
    and next,
    Experiences to confirm dowsing
    The Munich experiment
    The most famous experiment to verify the effectiveness of dowsing was the experiment carried out in Germany in Munich in 1987-1988 (its results were published in 1989). Over 500 dowsers took part in the test, from which the best 43 were selected for the second phase of the test. The second phase of testing was an experiment involving placing a water pipe in the barn under the floor. The dowsers' task was to indicate the place where the pipe was laid. The results of the tests indicated that the results of 37 out of 43 people tested did not qualify them as a dowser. Nevertheless, the remaining 6 performed far better than just chance. As a result, the authors of the experiment concluded (in 1990) that the phenomenon of radiesthesia can be regarded as experimentally proven ("... a real core of dowser-phenomena can be regarded as empirically proven ..." ;) .
    In 1995, Jim T. Enright analyzed the data of the Munich experiment and concluded that the results of these 6 people can only be interpreted as "statistical fluctuations", and thus these people, although they achieved above-average results during the experiment, are consistent with a statistical distribution indicating the randomness of the predictions [24]. The research carried out in later years did not confirm the results from Munich.
    There is criticism of the Munich experiment from the dowsing community. The form of the test is criticized by, inter alia, a professional dowser, Stefan Siudalski, in an esoteric website [25]. At the same time, the community of dowsers has not carried out any convincing (with double-blind rigors) experience confirming dowsing so far.
    James Randie Award
    The James Randi Foundation (JREF) has funded a million dollar prize for someone who will demonstrate paranormal abilities under controlled conditions. Dowsing is one of the most common attempts to win a prize. So far, no dowser has managed to demonstrate any water detection ability that could become the basis for the payment of a million dollars in reward [26] .
    This is an electronic forum, I don't know what the next topic about digging in the ground is doing here, let alone about the magical ways of searching for WATER.
  • #27 17571351
    kmr
    Help: 11
    Rate: 93
    Referring to the topic of the forum, I suggest making wands of copper wires, about 30-40 cm and bent at right angles with an additional 15 (letter L) so that they rotate freely in loosely closed fists. We grab it in "fists" and slightly lean it forward so that it does not spin freely. After approaching the suspicious area - the watercourse, the wires will cross.
  • #28 17571524
    Covul
    Help: 29
    Rate: 49
    I did not believe it either, but I was able to find buried pipes in this way, using such wires as mentioned by my colleague above, but they did not have to be copper, bent welding electrodes and wire from the hanger worked.
  • #29 17571576
  • #30 17571748
    mychaj
    Help: 214
    Rate: 942
    I also drilled wells - I mean firm- (without a wand) based on the map, in the mountains, it was supposed to be 30-40 meters, it ended up at 67m: it was only a satisfactory result.
    Clay and stones were 15 m, then only slate and solid rock, but the drill leader was stubborn, because he cared about time and I was on the water :-)
The discussion revolves around the challenges of drilling a deep well in a mountainous area where water supply issues have arisen. The original poster has been using water from a distant dug well but decided to drill a new well due to insufficient water pressure. They sought a drilling company with a small crawler rig suitable for their narrow plot but were disappointed when the company relied solely on hydrogeological maps without employing a dowser to locate water. After drilling a 46-meter borehole using the hammer method, water was initially found but quickly ran dry. Participants shared their experiences with well drilling, the effectiveness of dowsing, and the unpredictability of water availability in different terrains. Concerns were raised about the costs associated with drilling, the reliability of hydrogeological maps, and the potential for deeper aquifers. The conversation also touched on the skepticism surrounding dowsing methods and the need for scientific validation of such practices.
TL;DR: 46 m test bores in slate hit 0 L/min yield even though maps show 65 % first-hit success in Polish mountains [PGI, 2021]; “Water may lie much deeper than permits allow” [Elektroda, stanislaw1954, post #17568369] Dowser claims lack proof beyond chance. Why it matters: Every extra meter drilled costs money, permits, and time.
• Hammer-rig drilling: 200–300 PLN per metre in SE Poland [Elektroda, stanislaw1954, post #17570391] • Permit-free depth limit: 30 m for household wells [Wody Polskie, 2022] • Typical mountain aquifer depth: 60–120 m [PGI, 2021] • Narrow crawler rig width: 1.2–1.5 m, gradeability 30 % Rig Spec Sheet • Hammer method progress: 8–12 m per hour in slate Drillers Assoc., 2020
Why was there no water in two 46 m boreholes despite positive hydro-maps?
Hydrogeological maps average data over large cells. Local fractures can pinch out aquifers or divert flow. Clay to 10 m then compact slate gives poor permeability, so water only seeps briefly at shallow weathered zone [Elektroda, dariusz_pt, post #17567493] Deeper, unfractured slate stores almost no water, causing a dry hole.
Are dowser indications scientifically reliable?
Controlled trials show dowsers perform no better than random chance; the 1989 Munich test of 500 dowsers found statistical fluctuation only [Enright, 1995]. The James Randi challenge also remained unclaimed JREF Archive. Dowser advice is therefore anecdotal, not engineering evidence.
What professional methods improve hit rate over dowsing?
  1. Desktop study: 1:50 000 hydro-maps, bore logs, resistivity data. 2. Geophysical surveys (electrical resistivity tomography) detect saturated fractures to ±5 m depth accuracy. 3. Pilot percussion holes every 20–30 m confirm flow before full-size casing [USGS, 2019]. Combined, these raise success to 80 % in fractured rock [PGI, 2021].
How far apart should I space test holes on a 10 m-wide plot?
On narrow sites drill along a line perpendicular to slope every 15–20 m to sample different fracture sets while staying inside property boundaries [IAH, 2020].
Do I need a permit to drill deeper than 30 m?
Yes. In Poland, wells >30 m or >5 m³/day abstraction need water-law consent and geological documentation approved by local authority [Wody Polskie, 2022].
What does a 100 m mountain well cost?
At 250 PLN/m average, plus casing and pump, expect 35 000–40 000 PLN turnkey. Transport surcharges apply on steep plots Drillers Assoc., 2020. Edge-case: if no water, you still pay unless contract states “success fee” [Elektroda, Anonymous, post #17567931]
What if the deep well also fails?
Options: a) Rainwater harvesting sized for drought (15 m³ storage gives ~40 days for 4 people) [EU Rainwater, 2018]. b) Tanker delivery connection. c) Join neighbors to co-fund community pipeline. d) Relocate drilled casing for geothermal heat exchange, recovering part of sunk cost.
Can the existing dug well be salvaged?
Yes. You can enlarge diameter or add infiltration gallery uphill to raise storage. Re-seal joints and install low-flow pump to reduce drawdown. Dariusz’s experts advised against deepening because the spring’s piezometric level is fixed [Elektroda, dariusz_pt, post #17569743] Still, installing 200 µm screen and cleaning silt can restore 10–20 % yield [FAO, 2017].
How do I draft a ‘success-fee’ drilling contract?
Specify minimum yield (e.g., 0.5 L/s), water quality class, and depth cap. Payment milestones: 20 % mobilisation, 80 % upon certified pump test. Include clause for casing reuse elsewhere if yield fails. Expert quote: “Their problem starts with A and ends with Z, and you are watching” [Elektroda, Anonymous, post #17567931]
3-step How-To: verify a dowser’s point scientifically
  1. Mark dowser’s spots anonymously on site plan. 2. Run 2D resistivity transect crossing marks; note low-resistivity anomalies. 3. Drill 3 m pilot augers at marked and control sites, compare water rise after 24 h. Accept site only if anomalies and pilot data align.
How do I read the hydrogeological map for my parcel?
Locate 10×10 km square, check ‘Potentially exploitable groundwater’ layer. Note aquifer code (e.g., Qm) and productivity class. Class IV or worse (<10 m³/h) warns of low yield, suggesting deeper drilling or alternate supply [PGI, Guide, 2021].
Which pump should I prepare for a 60–120 m well?
Choose a 4" multistage submersible rated 140 m head and 30 L/min. Use 4 mm² cable for <2 % voltage drop over 80 m rise. Add dry-run sensor; droughts cut static level by up to 10 m, a documented failure cause in 15 % of mountain wells [PGI, 2021].
