Troubleshooting Uneven Pendulum Clock Movement: Leveling, Adjustment, Temperature & Humidity
sanfran 13974 19
Why does an old pendulum clock run unevenly, and how should its movement be cleaned and lubricated?
An uneven pendulum clock is usually caused by dried oil, dirt, or wear in the pivots/bearings and escapement, so the movement should be cleaned thoroughly and lubricated only at the bearing points, not on the wheel teeth [#16843016][#16912385] Old oil can harden like varnish and even make the spring or other parts move unevenly, so a deeper clean may be needed: clean, then rinse with a degreasing paraffin or similar solvent, dry it well, and oil it again [#16851762] One reply gives the traditional sequence as washing in water with ammonia, rinsing in gasoline, drying, then lubricating; the important part is to use only a tiny amount of very light oil, because excess oil slows the gears and attracts dust [#16912002] Suggested lubricants include sewing-machine/spindle oil, thin gear oil, or dedicated low-speed clock oils such as Moebius 8000/4 or 8030, with synthetic oils lasting longer [#16843016][#16968309] Also check for worn or oval pivots and sockets, especially around the anchor and escapement wheel, and run the escapement after lubrication to distribute the oil [#16843016]
  • #1 16843005
    sanfran
    Help: 966
    Rate: 3008
    Here is the patient:
    Troubleshooting Uneven Pendulum Clock Movement: Leveling, Adjustment, Temperature & Humidity Troubleshooting Uneven Pendulum Clock Movement: Leveling, Adjustment, Temperature & Humidity Troubleshooting Uneven Pendulum Clock Movement: Leveling, Adjustment, Temperature & Humidity
    Apparently he remembers the interwar period, if not earlier, but I am not sure about the dates.
    The problem is uneven gait. Sometimes it goes well and sometimes it is a minute or two late a day. After adjusting the length of the pendulum, you can start to rush.
    The clock is perfectly level, on average wound up once a week. The temperature in the room is 18-22C, humidity is 50-60%. The only thing it is exposed to is the vibration of the wall when the door to the garden closes with more force (the one on the right).
    Gravity doesn't play a trick either, because another shuttle ticks in the room above (from 1954 - the date is stamped there) and requires a minute adjustment every two months.
    The movement was cleaned a few years ago by a watchmaker, but if necessary, I can clean it myself again, because there are no watchmakers in Scotland.
    What to pay attention to, what to use to lubricate / preserve the mechanism?
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    A rather vile conductive mechanism :cry: . It's not Becker or Junghans. I suspect that the pivots and sockets are made - especially the pivots of the anchor and the escapement wheel. Of course, it will not hurt to lubricate it - with oil for sewing machines. Disassemble the escapement and "let" the mechanism after lubrication. That is, lock the escapement wheel, wind the spring and unlock it until the spring is fully unscrewed.
  • #3 16843028
    sanfran
    Help: 966
    Rate: 3008
    Thanks, I'll try what you do.
  • #4 16843033
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    Well, in my childhood, after my technical school class, I ran to my father's friend - a watchmaker and "apprenticed" :D with him ... Hence my knowledge of the subject. Sometimes I will also repair a mechanical clock myself.
    saskia
    Help: 174
    Rate: 1087
    I am renewing the old clock and what I noticed is that cleaning should be as you described, but twice, i.e. after the treatment as you described, rinsing with a degreasing paraffin (it would be good if mechanics use to degrease brake discs) I would have any dry old oil mixed with rinse with dust or cobwebs and only then oil it again.
    These paintwork, after cleaning, break off and transfer to different parts of the mechanism, or even seal the spring itself, so it does not develop uniformly.
    Such old oil can sometimes dry like varnish, especially when someone has used the wrong oil.
  • #6 16865294
    Romulus7874
    Help: 109
    Rate: 459
    Once upon a time, I had to revive a soggy mechanical clock mechanism without disassembling it. Well, I used the "method" of boiling. I put the whole mechanism in a larger pot and just boiled it. Then, after it dries nicely, I smeared it all, especially the springs. I did a similar maneuver later with the cassette player mechanism from the car. Some kids (I think) put something toffee-like in there.
    And the clock works to this day as if what.
    Boiling and ammonia cleaning method for clock mechanisms
    #7 16912002
    wada
    Help: 168
    Rate: 732
    Half an hour of cooking in water with the addition of Louis and a little ammonia is the old method of watchmakers.Then such a warm mechanism is rinsed in gasoline, and then well dried, and then lubricated, and with such steel / brass connections gear oils (brown) are the best, not none of the vaseline machine (colorless).
    You can use thin oil for gearboxes, it is not allowed to give it too much, preferably dip a sharp needle in oil and then touch the pin socket, this micro drop is enough, the excess oil inhibits the work of the gears depending on the spring tension, and sticks to it dust.
    Some window cleaners have ammonia on the label - you can cook them freely, or use ultrasounds to clean the clock mechanisms.
    The original watchmaker's fluid for cleaning the mechanisms is a mixture of water, soap and ammonia.
    Aleksander Sulikowski he came from an old, bourgeois Krakow family. He inherited from his father a watchmaker's shop, which was founded in 1858. The company operating in Krakow at 1 Grodzka Street enjoyed a great reputation. At the Sulikowski plant, he ran a store for pocket watches, pendulum watches, French clocks and alarm clocks, and also dealt with repairs. Aleksander Sulikowski was an active activist in Krakow's industrial societies - he was the president of the Craft Credit Association, and he also sat on the city council. He died in Kraków in 1910 at the age of 50.
    This watch is quite unique and valuable - at auctions it reaches PLN 15,000 - so don't spoil it, it could have been made in 1885-1890
    A, Sulikowski was a representative of the Swiss brand OMEGA after 1900, and developed several patents for this company.
    These clocks are not hung on a spirit level but on an ear, the swipe of a pendulum Tick Tock - they should sound in the ear the same time.
    Check if you have a weight stuck under the minute hand in this white part, these mechanisms required a well-balanced minute hand and an hour hand.
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • Lubrication advice for clock pivots and gears
    #8 16912242
    sanfran
    Help: 966
    Rate: 3008
    Thanks, I'll try. After talking with my family, I received photos dated 1918 and 1935, where the clock was displayed outside the house, so in fact its age is 100+ years.
    wada wrote:
    These clocks are not hung on a spirit level but on the ear, the swipe of the pendulum Tik / Tak - they should sound on the ear the same time.
    Yes, the minute hand is well balanced. There is a metal friction clutch between the gear of the hands and the mechanism, so without balancing it would be impossible. The mechanism is removed, it is in good condition, the gears are without visible signs of wear. Only some elements have a large axial play (considering the dimensions of the mechanism), but it does not look like wear, but rather deliberate operation. I used hot water rinse and lubrication.
    Should only the tips be lubricated, i.e. the seat points in the crank, and should the gears run dry, or should the gears be lightly lubricated?
    As for car oils, gear oils are usually denser, have viscosity classes of 75-90, which may be too viscous at room temperatures. On the other hand, synthetic engine oils are much rarer, maybe they would be better suited?
  • #9 16912385
    k4be
    Help: 102
    Rate: 333
    The teeth of the wheels in the clocks are never lubricated.
  • #10 16912558
    zdzicho44
    Help: 30
    Rate: 117
    Read on the watchmaking forum.
  • #11 16912756
    wada
    Help: 168
    Rate: 732
    Exactly.
    My father did not see him lubricate the brass / brass connections, when a brass one worked with a steel one, he gave a micro-drop for a few teeth on a steel one - he was driving a needle soaked in oil. He always preferred natural oils, and as little as possible, so this density did not interfere, and to these large mechanisms he gave gear oil, which is used in lathes, and it was very rare. And for 60 years he has revived the clocks a lot, for various museums, Ossolineum and private persons, and at home I still have a dozen fully functioning antiques, in which a large amount of parts was made extra.
    Elefant
  • #12 16915781
    saskia
    Help: 174
    Rate: 1087
    wada wrote:
    Exactly.
    This lathe oil used to be called spindle oil.
    To this day, these oils are used, only under different names, but it is just a thin oil and I think that the same is still used to lubricate the bed of the lathe after work and cleaning of chips. Its parameters are similar to the so-called oil. 3 in 1, which is slightly denser than the WD40.
    By the way, I would like to point out that there is such a thing as oil drying time, which is very clearly among the oils used in dyeing.
    Nevertheless, all oils have a "degree of drying up", and although a given oil does not belong to the category of drying up, each oil "dries up".
    If it is not a direct drying process, such as, for example, varnish, then each one undergoes thickening, or the reverse process of cracking, i.e. breaking larger-complex particles on the straight, so the opposite of this is the merging of smaller particles into larger, and probably the best known there is such a process taking place in fuel oils, i.e. diesel, which, after years of storage, combines into more complex fractions until it finally becomes useless as a diesel fuel.
    I once bought a lathe that looked like someone had flooded a bed of tar.
    It turned out that the lathe had been out of use for over 50 years, and the oils that were used to lubricate the bed simply rotted to such an extent that their consistency resembled tar. After washing them with acetone, it turned out that the lathe from 1937 had almost new, little-used beds, and a detailed check of the origin of the lathe showed that it was used by the Royal Navy, from which it went to private hands during the surplus and survived almost intact, unused but lubricated in a private garage.
  • #13 16916239
    landy13
    Help: 195
    Rate: 260
    Machine oils are produced in various viscosity versions. From L-AN10 to L-AN150. link1, link2.
    L-AN10 is actually almost like water.
  • #14 16918967
    wada
    Help: 168
    Rate: 732
    I found a bottle of this oil from my dad and he writes:
    Gear oil
    For precision machines and mechanisms
    The following are listed: closed-circuit and pressure-cycle lathe gears, precise mechanisms, clocks ...
    oops from 1978, a rare amber color, and very slippery to the touch, and hard to wash off your fingers.
    Elefant
  • #15 16919886
    saskia
    Help: 174
    Rate: 1087
    The same oil is used for sewing machines.
  • #16 16922649
    zdzicho44
    Help: 30
    Rate: 117
    Bone oil or petroleum jelly is used for sewing machines, so that it can be washed off if the fabric is dirty.
  • #17 16922708
    wada
    Help: 168
    Rate: 732
    Exactly
    And the vaseline ones have a poor glide and dry quickly - they become sticky, rubbery.
    Elefant
  • #18 16922726
    zdzicho44
    Help: 30
    Rate: 117
    Bone oil is good for precision mechanisms, but has the disadvantage that it oxidizes. Its working time is about 6 months. Synthetic oils are the most durable.
  • #19 16968309
    ta_tar
    Help: 700
    Rate: 2053
    The mechanisms should be equipped with oils for the low-speed mechanisms.
    Eg.
    Moebius 8000/4 Natural oil for mechanical watches
    Application:
    - anchor pallet stones
    - idler wheels
    - metabolic fingers
    - gears
    parameters
    working temperature: from -15 ° C to 80 ° C
    viscosity in cSt:
    0 ° / 20 ° / 50 °
    280/95/29
    Moebius 8030 Natural oil for alarm clock mechanisms
    Application:
    - alarm clock anchors palettes
    - idlers and gears for alarm clocks, wall clocks and standing clocks
    parameters
    working temperature: from -18 ° C to 80 ° C
    viscosity in cSt:
    0 ° / 20 ° / 50 °
    440/115/31
    Just by the viscosity, we can see that you can't use different oils without damaging the mechanisms.
  • #20 16968348
    sanfran
    Help: 966
    Rate: 3008
    I look at the above entries and leave it as this clock survived the century without modern petrochemicals :-)
    The clock has been cleaned, lubricated with machine oil and so far it works perfectly.
    Thank you for the entries, I consider the topic closed.
The discussion revolves around troubleshooting an uneven pendulum clock movement, which exhibits inconsistent timing despite being well-maintained and properly leveled. Users suggest various methods for cleaning and lubricating the clock mechanism, emphasizing the importance of using appropriate oils and cleaning techniques to avoid damaging the delicate components. Recommendations include using sewing machine oil, gear oils, and natural oils specifically designed for low-speed mechanisms. The clock's age is estimated to be over 100 years, and participants share personal experiences and techniques for maintaining antique clocks, highlighting the significance of proper lubrication and cleaning to ensure optimal performance.
TL;DR: For uneven pendulum movement, clean, oil sparingly, and use correct low‑speed oils; e.g., Moebius 8030 is ~115 cSt at 20 °C. “The mechanisms should be equipped with oils for the low-speed mechanisms.” [Elektroda, ta_tar, post #16968309]
Why it matters: This FAQ helps owners of antique pendulum clocks diagnose drift, choose oils, and adjust beat without damaging valuable mechanisms.
How do I fix uneven pendulum movement without full disassembly?
Start with a light oil and service the escapement. 1) Lock the escapement wheel. 2) Wind the spring, then unlock to let it run down under fresh oil. 3) Recheck beat by ear and regulate length. This restores smooth power flow. [Elektroda, Krzysztof Kamienski, post #16843016]
Should I level the case with a bubble level or by ear?
Level by sound. Hang the clock so Tick–Tock intervals match in your ear. Equal spacing indicates correct beat, even if the case isn’t bubble‑level. This is the practical setup method for these mechanisms. [Elektroda, wada, post #16912002]
What oil should I use, and where do I apply it?
Use low‑speed watch oils (e.g., Moebius 8000/8030). Apply tiny drops to pivot holes, pallet stones, and other steel‑on‑brass points. Avoid over‑oiling. Example viscosity: Moebius 8030 ~115 cSt at 20 °C. Keep wheels clean; don’t oil teeth. [Elektroda, ta_tar, post #16968309]
Should I lubricate the gear teeth?
No. “The teeth of the wheels in the clocks are never lubricated.” Oil belongs at pivots and pallets only. Oily teeth collect dust, increase drag, and destabilize rate over time. Keep the train dry and clean. [Elektroda, k4be, post #16912385]
Can I use sewing‑machine or spindle/gear oils instead of watch oil?
Light machine oils can work in a pinch if used sparingly, but specialized watch oils are preferred. Some restorers report success with sewing‑machine oil after careful cleaning. Always apply minimal amounts and verify beat and rate afterward. [Elektroda, sanfran, post #16968348]
How much oil is the right amount on pivots?
Use a micro‑drop delivered by a needle to each pivot. Excess oil slows gear motion and attracts dust. Focus on steel‑to‑brass interfaces and avoid brass‑to‑brass points. Less is better for long‑term stability. [Elektroda, wada, post #16912756]
What’s a safe deep‑clean method for gummed movements?
Traditional method: boil components in water with a small amount of cleaning agent containing ammonia, rinse in gasoline (solvent), then dry and oil. This removes varnished oils and debris before lubrication. Confirm materials tolerate the process. [Elektroda, wada, post #16912002]
Is boiling the whole movement really used by watchmakers?
Yes, an old shop method uses about half an hour in water with cleaner and ammonia, followed by a solvent rinse, drying, and lubrication. Many now prefer ultrasonic cleaners, but the principle is the same: degrease thoroughly before oiling. [Elektroda, wada, post #16912002]
Why does my clock gain or lose 1–2 minutes per day?
Length, friction, and beat errors cause daily drift. One owner observed 1–2 minutes/day variation that improved after cleaning and light machine oil. Wall vibrations and door slams can also disturb the beat and timing. [Elektroda, sanfran, post #16843005]
Do temperature and humidity affect rate stability?
Yes. Reported operation at 18–22 °C and 50–60% RH still showed drift when friction or beat were off. Stable environment helps, but correct cleaning, oiling, and beat adjustment matter more for timekeeping. [Elektroda, sanfran, post #16843005]
What is the escapement, and why does it matter here?
The escapement is the anchor and escape wheel that meter energy to the pendulum. Worn pivots or dirty pallets cause uneven impulse and drift. Service this area first when timing is unstable. [Elektroda, Krzysztof Kamienski, post #16843016]
Can door slams or wall vibrations throw off my pendulum clock?
Yes. Vibrations from a nearby door can shift the beat and cause intermittent drift. After reducing vibration, re‑set beat by ear and verify rate over several days. [Elektroda, sanfran, post #16843005]
Are antique Sulikowski‑signed clocks valuable or delicate to service?
One contributor notes sale values around PLN 15,000 and late‑19th‑century origin. Handle gently, avoid experimental oils, and use minimal lubrication to protect originality and value. [Elektroda, wada, post #16912002]
Is spindle oil the same as modern watch oil?
Spindle oil is a thin machine oil once used on lathes and beds. It resembles light general oils and can thicken or gum with decades of neglect. Watch oils are formulated for low‑speed precision pivots. [Elektroda, saskia, post #16915781]
Quick 3‑step how‑to: refresh power train after oiling?
  1. Lock escapement, then oil pivots lightly. 2. Wind mainspring. 3. Unlock and let it run down to distribute oil evenly, then set beat. [Elektroda, Krzysztof Kamienski, post #16843016]
