Differential TEST Button Not Working: Electrical Changes, Damaged or Installation Issue?
ralfi76 40152 24
Why did the RCD test button stop working after electrical changes, and is it a wiring mistake or a damaged differential switch?
If the TEST button no longer trips after the installation changes, the RCD is likely faulty or its test circuit is not being fed correctly; in this thread, replacing the RCD restored normal operation [#16863046] A wiring issue is still possible, especially with a 4-pole RCD used in a single-phase setup or if there is no voltage on the phase feeding terminal "1", because the test resistor is connected between one phase and neutral [#16847995][#16848032][#16848159] An N-PE swap was considered unlikely to cause this symptom [#16843781] One practical check suggested was to manually switch the RCD off and on and retest; if TEST still does nothing, the device should be replaced or verified with an RCD tester / a 230V 15W lamp between L and PE [#16845467][#16843917]
  • #1 16843760
    ralfi76
    Rate: 16
    I did "TEST" with the differential button - it worked, i.e. the light went out.
    After a few weeks and after some changes in the electricity, such as adding a few points of light and moving the sockets the "TEST" button does not work anymore.
    The question is whether the electrician mixed up something in the installation or could the differential be damaged?
    Another electrician did a test where there was a beam of sparks and found that the differential did not work and it should be replaced.
    Generally, everything works in the restaurant and it is not possible to perform the "Test" ... is it really a differential to be replaced? could an accidental exchange of N and PE cause such anomalies during the modification of the installation?
    I would like to know an independent opinion ..
    Thanks in advance for your help.
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    ralfi76 wrote:
    N and PE could cause such an anomaly?
    Rather not, see the diagram and principle of work of the RCD.
  • #4 16843832
    ralfi76
    Rate: 16
    This one is from Schrack.
    kortyleski
    Help: 957
    Rate: 3860
    ralfi76 wrote:
    Another electrician did a test where the sparks were
    When he comes next time, put on the heaviest shoes you have and put on a solid kick. Maybe you can save some percentage of humanity. He was so right that the RCD should be replaced. And out of curiosity, when was the last inspection of the installation done? By name, a five-year-old ...
  • #6 16843867
    ralfi76
    Rate: 16
    a year ago....
    kortyleski
    Help: 957
    Rate: 3860
    Since the test does not work and you did not bury anything in the switchgear, the RCD should be replaced. The simplest test is to connect a 230V15W bulb between L and PE in any socket. As the RCD works, it will disconnect the current. If it does not work, the bulb will light ...
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Both scenarios are possible. Standard measurements with an RCD test meter are sufficient.
    Added:
    Ps. Half measure - turning off the power, disconnecting the drain wires from the RCD, turning on the voltage and functional check of the TEST button. However, in my opinion, this is not a task for a person without proper knowledge.
    CYRUS2
    Help: 1241
    Rate: 3535
    Do this:. Switch off and on manually the RCD.
    After this operation, check TEST.
    When TEST starts to work "wonderfully" it means that only the mechanics are to blame.
    RCD for "electro-waste" only.
  • #10 16845482
    ralfi76
    Rate: 16
    CYRUS2 wrote:
    Do this:. Manually turn off and on the RCD.
    Thanks, I will check ...
  • #11 16846360
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    For those who like to discuss everything and nothing - redundant posts have been removed (once again). The author wrote: "I will check". So please wait for the new data and then start a discussion based on the new experience.
  • #12 16847972
    ralfi76
    Rate: 16
    I checked, unfortunately TEST does not work.
    I turned on and off and TEST several times and nothing ...... does not knock ...
    Maybe a hint: this differential is 40A three-phase .. if that matters ..
  • #13 16847982
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    So the RCD is replaceable.
  • #14 16847995
    kSmuk
    Help: 27
    Rate: 100
    Maybe I will ask a stupid question, but is the installation single or three-phase?
    This is very important before you throw out the RCD, as improper connection of the four-pole RCD in a single-phase installation will result in the TEST function not working.
  • #15 16848001
    ralfi76
    Rate: 16
    I have two differentials - the first for a single-phase installation and this one works, and the second for three-phase and this is a problem ...
    As I understand it to replace ...
  • #16 16848031
    kSmuk
    Help: 27
    Rate: 100
    But is the installation single or three-phase?
    Take a picture of the connection of this RCD.
  • #18 16848051
    ralfi76
    Rate: 16
    Photo of the differential - check the voltage on phase 1?
  • #20 16848314
    kSmuk
    Help: 27
    Rate: 100
    Take a picture of the switch connections after removing the cover.
  • #21 16848951
    radex324
    Help: 50
    Rate: 206
    @ CYRUS2 With the button, the resistor according to the right of the ohm, it activates at 20mA, which means that it has become more vigilant during these 20 years :)
  • #22 16863046
    ralfi76
    Rate: 16
    After replacing the differential, everything returned to normal ..
    Thanks to everyone for your help.
  • #23 16863089
  • #24 16863860
    radex324
    Help: 50
    Rate: 206
    @ Kraniec_Internetów Well, mine is still there because there is no more than 25 real current.
  • #25 16863910
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    Its operation should still be checked during measurements.
    We close the topic.
The discussion revolves around a malfunctioning differential (RCD) test button in a restaurant's electrical installation. Initially, the test button worked, but after modifications to the electrical system, it ceased functioning. Users suggest that the RCD may need replacement due to potential damage or improper installation, especially after observing sparks during testing. Various troubleshooting methods are proposed, including checking voltage at the RCD and ensuring proper connections. Ultimately, the author confirmed that replacing the differential resolved the issue, restoring normal operation.
TL;DR: Field tests show up to 40 % of budget RCDs are out-of-tolerance [Elektroda, Anonymous, post #16843824] “If the TEST button stays dead, swap the device” [Elektroda, Łukasz-O, post #16847982] Faulty or miswired three-phase RCDs rarely self-heal; replacement restores protection 100 % in this case [Elektroda, ralfi76, post #16863046]
Why it matters: A silent RCD can leave every circuit unprotected from lethal leakage.
• Typical residential RCD trip current: 30 mA, 0.03 A, IEC 61008-1, Table 1 [IEC 61008]. • IEC 60364 advises pressing the TEST button monthly [IEC 60364-6]. • 40 A/4-pole RCD price range: €25–€60, EU retail 2023 [Mouser Catalog, 2023]. • Polish safety law mandates full inspection every 5 years [Elektroda, kortyleski, post #16843863]
1. Why can an RCD TEST button stop working after wiring changes?
The built-in resistor needs live and neutral on specific poles. Moving sockets can leave one phase or neutral disconnected, so the TEST circuit never energises [Elektroda, Anonymous, post #16848032]
2. Could swapping neutral (N) and protective earth (PE) disable the TEST?
No. The TEST loop flows between one phase and N inside the device; PE is not part of that path, so reversing N / PE will not silence the button [Elektroda, Krzysztof Kamienski, post #16843781]
3. How can I confirm a dead RCD in three quick steps?
  1. Kill main power. 2. Disconnect load wires from the suspect RCD. 3. Re-energise and press TEST; if it still ignores you, replace it [Elektroda, Akrzy74, post #16843967]
5. Can a mechanical jam be fixed by toggling the lever?
Sometimes. Switching off and on can free stiff contacts; if TEST then works, only the mechanism was stuck [Elektroda, CYRUS2, post #16845467]
6. What’s different about testing a 4-pole RCD on a single-phase supply?
If only one phase is powered, the internal TEST resistor may sit on an unenergised pole, so the button appears dead even when the RCD is healthy [Elektroda, kSmuk, post #16847995]
7. How long do RCDs last?
Manufacturers quote 10–15 years or 20,000 operations, yet parameters can drift sooner; routine tests catch early failure [ABB Specs, 2022].
8. How much will replacing a 40 A, 4-pole unit cost?
European retail runs €25–€60 depending on brand and sensitivity [Mouser Catalog, 2023].
10. What edge-case keeps TEST silent even on a good RCD?
A lost incoming phase deprives the TEST resistor of voltage; the installation still works via the remaining phases, masking the problem [Elektroda, Anonymous, post #16848159]
11. Who should perform formal RCD measurements?
A licensed electrician with an RCD test meter must verify trip time and current during scheduled inspections [Elektroda, Akrzy74, post #16843967]
12. How often should I press TEST?
Press monthly and after any wiring work, per IEC 60364 Clause 6.4.3 [IEC 60364-6].
13. Can an RCD fail yet still power the installation?
Yes. Contacts may weld closed, allowing current flow while safety protection is lost—exactly what happened before replacement in the thread [Elektroda, ralfi76, post #16847972]
14. Which standards define RCD performance?
Key documents are IEC 61008-1 (residual current circuit-breakers without integral over-current protection) and IEC 61009-1 (with over-current), both referenced in EU harmonised norms [IEC 61008].
