Vectra C blower - The blower only works in 4th gear despite the resistor being r
patrykp4 10863 9
Why does the blower in a Vectra C only work on speed 4 even after replacing the resistor?
The blower likely has a dead relay under the dashboard panel, not a faulty resistor. Replace the relay under the board, probably the blue one [#16933863] To get to it, remove the plastic under the steering wheel panel and access the back of the box [#16941821] If needed, also clear any air-conditioning faults and try starting the blower with a diagnostic tool [#16933305]
  • #1 16933044
    patrykp4
    Rate: 9
    Hello, I have a vectre c 1.8 2003. namely, I have a problem that the blower only works in 4th gear, I read that it could be a blower resistor, it was replaced with a new one and still nothing. Anyone have an idea what else could it be?
  • #2 16933081
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    And you bought a new resistor, isn't 123 spinning at all?
  • #3 16933167
    patrykp4
    Rate: 9
    I bought a new one, but it still doesn't spin at 1,2,3
    Added after 22 [minutes]:
    I will add that the air flow went elegantly for 2 suddenly jumped to the highest speed and went out, since then it works only for 4, I also checked if the blower is not blurred, but everything is okay.
  • #4 16933305
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    patrykp4 wrote:
    blower resistor, it has been replaced
    Can you write something more?
    Have you replaced the fan controller with a "brand new" or a "different" one?
    Can you use the diagnoscope to start the blower?
    Clear air conditioning faults.
    Sometimes the blower won't start without clearing the errors.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #5 16933317
    Help: 1405
    Rate: 6430
    Since it has 4 gears it's a ceramic resistor, if it's good, it's a broken switch.
  • Suspect faulty blower speed switch or wiring
    #6 16933516
    patrykp4
    Rate: 9
    Tomorrow, if I find the time, I will jump to fix the errors, it is a replacement. Switch, showing the regulator of airflow speed change? but if I put on 4 and it works, is it possible that only on 123 it doesn't work? I will add that in my friend's vc when the resistor burned to him, when turning on one was heard one-hole popping, and here nothing.
    I haven't tried the diagnoscope.
    Added after 16 [minutes]:
  • #7 16933863
    BoroPiotr
    Help: 17
    Rate: 52
    replace the relay under the board, probably blue
  • #8 16934526
    patrykp4
    Rate: 9
    Blue, relay under the board, hm. Specifically where? How to get to it
  • #9 16941821
    BoroPiotr
    Help: 17
    Rate: 52
    you have to unmount the plastic under the handlebar board and get to the back of the box
  • #10 21002446
    krzysiekpilus
    >>16933863
    golden shot, the relay is dead, thanks a lot for the tip.
The discussion revolves around a 2003 Vectra C 1.8 experiencing a blower malfunction, where the blower only operates in the fourth speed despite replacing the blower resistor. Users suggest various troubleshooting steps, including checking the fan controller, using a diagnostic tool to clear air conditioning faults, and inspecting the switch for airflow speed regulation. A faulty relay under the board is also mentioned as a potential issue, with instructions provided for accessing it. The original poster confirms that the blower does not function at speeds 1, 2, or 3, and expresses intent to further diagnose the problem.
