[Solved] Win 10 Key Remapping Issue: Incompatibility with Sharpkeys, KeyTwek & MS Keyboard Layout Creator
waski90 5025 6
  • #1 16846277
    waski90
    Hello, I have a problem with the keyboard in the laptop. Exactly that the tab key went out, with Win 8.1 I used sharpkeys or keytwek and swapped it with another key without any problem, but yesterday I updated the system to 10 and the changes disappeared. the above mentioned programs stopped working at 10, so I tried a tool from Microsoft, i.e. MS Keyboard layout Creator and it keeps throwing me an error:
    CL.EXE returned 1
    RC.EXE returned 1
    LINK.EXE returned 1
    I would not like to go back to wines 8.1 to fix it, and I will not replace the keyboard for one button. Anyone know the solution to the problem? In addition, I can only add that the program sharpkeys or KeyTwek adds entries to the registry under the path: Computer \ HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Keyboard Layout but the system probably does not load them later because the keys do not change.
  • #3 16846637
    waski90
    I can test them, but they probably won't help because, as I wrote, the previous programs add an entry to the registry correctly, the problem is that the system probably doesn't read it and doesn't change the keys.
  • #4 16853898
    waski90
    all tested, no program works for me on 10.
  • #5 16853952
    DriverMSG
    Help: 3984
    Rate: 4862
    I installed it out of curiosity link on my Windows 10 laptop and assigned a TAB to the [Q] button - it works fine.
    The attachment is the registry file.
    The only difference is that I made the changes from the built-in administrator account.
    • Q-TAB.zip (782 Bytes) You must be logged in to download this attachment.
  • #6 16855969
    waski90
    i've already gone back to 8, but if i have a little more time i'll check your file, thanks! :)
  • #7 17375491
    waski90
    DriverMsg, new disk new win still no program working, return your file like this! That's why I have a big request to you, could you please drop this file but change ~ to tab? Thanks in advance.
    Smaller, it surprised me when I edited your file, thanks!
✨ The discussion revolves around a user's issue with key remapping on a laptop after upgrading from Windows 8.1 to Windows 10. The user previously utilized SharpKeys and KeyTweak to remap keys, but these programs ceased to function post-upgrade. Attempts to use the Microsoft Keyboard Layout Creator resulted in errors related to CL.EXE, RC.EXE, and LINK.EXE. Other participants noted that they had success with key remapping on Windows 10, particularly when using the built-in administrator account. The user expressed frustration with the inability to remap keys and considered reverting to Windows 8.1, while others offered to share registry files for remapping assistance.
