Lexia Full Chip for PLN 420: Worth Buying? Covers Difficult 207, 307, 407 Peugeots
6351 19
Is a Lexia “full chip” interface for PLN 420 worth buying, and will it handle the difficult Peugeot 207, 307, and 407 models?
For PLN 420, it is probably not worth being very picky, but the advertised “full chip” claim looks doubtful. The forum says the unit is actually a C-revision board that can be flashed normally, rather than a guaranteed true full-chip version [#16848607] Another reply says the device has no seals, was opened, and all places on the board are populated with components [#16859753] A further comment warns that photos can show anything, so you cannot trust the pictures alone to judge what electronics are really inside [#16852126] The thread does not clearly confirm special coverage for the difficult 207/307/407 Peugeot models, so the safest conclusion is that the offer is acceptable only as a budget buy, not as a guaranteed premium interface [#16848459][#16848607]
  • #1 16848456
  • #2 16848459
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    You know for four hundred zlotys, it is no problem to be picky.
  • #3 16848607
    sebap
    Help: 538
    Rate: 1082
    For the note "Full chip" they delete more and this is only the C revision loaded, which you can upload without any problems.
  • #4 16849630
  • #5 16850898
    sebap
    Help: 538
    Rate: 1082
    Ok. What does it have to do with it?
  • #6 16852126
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    Adam.kowalski432 wrote:
    The photos on the board show all the parts.
    In the pictures, I can show that I have Tesla in my garage.
    And the interface with the poorest electronics will come, and you will not check because there will be a seal on the interface.
    On many forums they warn about the weakest versions of electronics, but until you open them you won't see what's inside.
    So they can do anyway in ....
  • #7 16852174
    Help: 1405
    Rate: 6430
    You know, for 4 stówy, I would not even bother or work or not, I take pictures, take pictures, advertise the seller and after it.
  • #8 16859753
  • #9 16889139
  • #10 16889229
    szymitsu21
    Help: 343
    Rate: 1300
    What can you do with immo with this equipment?
    And what do you want to do?
  • #11 16889564
  • #12 16889603
    Help: 1405
    Rate: 6430
    Adapt the second driver
    Have you ever done it at all or do you write so cheerfully?
  • #13 16890124
  • #14 16890150
    szymitsu21
    Help: 343
    Rate: 1300
    I did but not diagbox. And I know that, for example, bsi can be added
    If you have PIN, and bsi for virgin.
  • #15 16890197
  • #16 16890285
    szymitsu21
    Help: 343
    Rate: 1300
    What do you mean virgin?
    Being able to learn.
  • #17 16890328
  • #18 16890369
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    I understand shimitsu. Or maybe you have experience working with maps?
    With what maps?
    Map of Poland, Europe, Russia? I have a few Poland and Europe at home.
    As for the ECU maps, Lexia doesn't.
  • #19 16890395
  • #20 16908177
The discussion revolves around the value of purchasing a Lexia Full Chip for PLN 420, particularly for diagnosing complex Peugeot models such as the 207, 307, and 407. Participants express skepticism about the quality and functionality of the device, noting that the "Full chip" version may only include a C revision that can be easily uploaded. Concerns are raised about the potential for inferior electronics and the importance of inspecting the device before purchase. The conversation also touches on the capabilities of the Lexia tool regarding immo adaptation and ECU mapping, with some users sharing their experiences and technical knowledge about using the device for diagnostics and modifications.
TL;DR: A Lexia “full chip” clone around ≈ PLN 400 can be a punt; “for four hundred zlotys, it is no problem to be picky.” [Elektroda, Strumien swiadomosci swia, post #16848459] Why it matters: Shoppers want to know if a budget Lexia clone is usable and what to watch for before diagnosing Peugeots.
Is a ~PLN 400 “full chip” Lexia worth buying?
As a low-cost bet, yes—treat it as test-and-return. One user advises documenting with photos and pushing the seller if faulty. This price tier signals compromise, so protect yourself with clear evidence on arrival. Include the price in your risk calculus: ≈ PLN 400. [Elektroda, Strumien swiadomosci swia, post #16852174]
What does “full chip” really mean on clone interfaces?
Sellers often use “full chip” loosely. A member reports it can mean only a C‑revision board is flashed, not enhanced hardware. Expect marketing language rather than guaranteed premium components. “Full chip” here doesn’t certify component quality or coverage. Inspect the board if possible. [Elektroda, sebap, post #16848607]
Do listing photos prove the hardware quality inside?
No. Photos can show anything; the shipped interface may differ. One expert notes you won’t know the electronics grade until you open it, and sellers may use seals to deter that. “On many forums they warn about the weakest versions.” [Elektroda, pepe150, post #16852126]
What if the interface arrives sealed or feels low quality?
Assume risk. A seal can hide sparse or weak electronics. Document unboxing, then test functions you need. If performance is poor, use your evidence for a return. Edge case: you may be unable to verify internals without breaking a seal. [Elektroda, pepe150, post #16852126]
Can I open the interface to verify that all components are populated?
Yes, some units arrive without seals. One buyer opened the case and found every field populated. This is the only reliable way to confirm parts density on a clone tool. Proceed carefully to avoid damage and preserve return options. [Elektroda, 3057074, post #16859753]
Will this Lexia clone handle Peugeot 207, 307, and 407 models?
The buyer’s claim is that it “takes a lot, even the difficult 207 307 407 Peugeots.” Treat that as anecdotal and verify on your vehicle. Test key functions first, such as fault reading and live data. [Elektroda, 3057074, post #16848456]
What can I do with immobilizer (IMMO) using this setup?
You can perform pairing tasks if you have the vehicle PIN and a BSI prepared to learn. Without both, adaptation will fail. Plan your workflow and ensure PIN availability before starting. This is the minimum requirement set. [Elektroda, szymitsu21, post #16890150]
What does a “virgin BSI” mean in this context?
“Virgin” means the BSI is reset and ready to learn new immobilizer data. Once virginized, the module can be taught with the correct PIN. As one expert put it, it must be “able to learn.” [Elektroda, szymitsu21, post #16890285]
Can Lexia/DiagBox edit ECU fuel/ignition maps?
No. A member clarifies that Lexia does not handle ECU map editing. It’s a diagnostic and configuration tool, not a calibration suite. Use dedicated tuning hardware/software for maps. [Elektroda, pepe150, post #16890369]
How do I adapt a second ECU/driver with this tool?
Three-step How-To:
  1. Obtain the vehicle PIN and prepare the BSI to virgin state.
  2. Connect Lexia/DiagBox and start the learning/adaptation routine.
  3. Complete pairing following on-screen prompts, confirming IMMO sync. Failure to have PIN or virgin BSI blocks adaptation. [Elektroda, szymitsu21, post #16890150]
I used another tool before—can DiagBox add a BSI later?
Yes, users note BSI addition is possible; the key is meeting prerequisites. If you can supply the PIN and have a virgin BSI, DiagBox can learn it during pairing. Prior tooling doesn’t prevent this process. [Elektroda, 3057074, post #16890124]
How should I document and handle a bad unit on arrival?
Photograph everything: packaging, interface exterior, and test failures. Then contact the seller with proof and request a return or replacement. “For 4 stówy, I would not even bother… advertise the seller and after it.” [Elektroda, Strumien swiadomosci swia, post #16852174]
