Lexia or Diagbox? Which one is better for a beginner? Which is better diagnosed
elektronikq 79152 11
Should I use Lexia or Diagbox to diagnose my Citroën, and which one is better for a beginner?
Use Diagbox if you want the broadest compatibility, especially for newer Citroëns; Lexia/PP2000 is mainly for older cars, and newer models will not be on its list [#17533100] For roughly 2010-era cars, Lexia/PP2000 is still enough, while newer cars require Diagbox [#17533100] The thread also notes that the two are largely the same interface apart from vehicle coverage [#17533100]
  • #1 17532915
    elektronikq
    Help: 70
    Rate: 614
    I ordered a citroen cable. The best way to diagnose a car?
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    The question is a bit pointless.
    It's like asking if XP or Win 10 is better - the answers will be different.
    You will not diagnose newer Lexia or PP2000 cars because they will not be on the list.
    How do you want to do, for example, 2010 is enough Lexia / PP2000, newer cars are Diagbox.
    I think that this is one and the same graphic design apart from what I wrote above.
    People have manie updates and even up to 307 would like the latest soft which will not change anything on the car because usually updates are the latest cars.
    That's my opinion.
  • #3 17533170
    elektronikq
    Help: 70
    Rate: 614
    Thank you for opinion. For a beginner it gives a little to understand.
    For now I want to connect the berlingo and turn it on so that the door closes automatically when the engine is started after some time.
    I installed Diagbox 7.01 and want to keep updating but the files provided on the board are broken. I wrote to the producer and I am waiting for a reply.
    Are Lexia and Diagbox free programs?
  • #4 17534132
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    No, they are paid programs.
    What you can find on the internet are pirated versions.
    And you do not have a button to block? If you have a running car, hold it for 5-10 seconds. A message should appear on the display.
  • #5 17535193
    elektronikq
    Help: 70
    Rate: 614
    I installed the diagbox 7.44 properly.
    Managed to. Before I can take this door?
    Unfortunately I do not have a button
  • #6 17536133
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    In BSI - the configuration and changing there.
  • #7 17536826
    elektronikq
    Help: 70
    Rate: 614
    I turn on the diagbox then some BSI tab and the configuration and there is something with the door?
    grala1
    Help: 1495
    Rate: 5052
    You start the program, choose the brand you are interested in.
    You choose the car with which you want to connect.
    You choose 2 option with 4 or NARAWA.
    A GLOBAL TEST should be started, that is communication with all drivers in the car.
    You choose BSI.
    You choose TELECIFICATION (sometimes depending on the version you have to choose REPAIR and only later TELECIFY will be possible to choose)
    This video should help you.
    https://www.youtube.com/watch?v=wEFB0kACz8g
    It's worth before you change anything into the VISUALIZATION and save it in the form of a printscreen so that you can return to the factory settings later if something does not work.
  • #9 17537671
    elektronikq
    Help: 70
    Rate: 614
    Grala, thank you for the entry. It will be tested this week.
    I will only change one parameter so printscreen will not be needed. But thank you for your valuable attention.
  • #10 17547044
    elektronikq
    Help: 70
    Rate: 614
    I connected and two windows popped out:
    Scantool and Lexia. Ver 7.44. I have to read a little about it because I do not want to make poverty.
    Can I transfer the data from one BSI to the other BSi to exchange it in the car?
    dziungwaj
    You need to solder an eeprom there are pin data, vin, keys, mileage.
  • #12 19524635
    Rebeliant-au
    What if I have, for example, a c5 lemon from 2011, should I embrace the diagbox or something else?
    Because I don't know if I understood correctly.
The discussion revolves around the comparison between Lexia and Diagbox for car diagnostics, particularly for beginners. Lexia is suitable for older models (up to 2010), while Diagbox is recommended for newer vehicles. Users express concerns about software updates and the availability of free versions, clarifying that both programs are paid, with pirated versions available online. A user successfully installed Diagbox 7.44 and seeks guidance on configuring automatic door closing features in a Citroën Berlingo. Instructions for using Diagbox to access BSI settings and perform configurations are provided, along with advice on data transfer between BSI units.
TL;DR: For PSA vehicles ≤2010 use Lexia/PP2000; newer need Diagbox; "newer cars are Diagbox." Install Diagbox 7.44 for coverage. [Elektroda, grala1, post #17533100]
Why it matters: This helps beginners pick the right PSA diagnostic tool and safely change BSI features like auto door locking.
Which is better for a beginner: Lexia/PP2000 or Diagbox?
There isn't a single "better" choice. Use Lexia/PP2000 for vehicles around 2010 and older, and Diagbox for newer models. As one expert put it, "You will not diagnose newer Lexia or PP2000 cars." Start with Diagbox if you need coverage for recent PSA cars. [Elektroda, grala1, post #17533100]
How do I enable automatic door locking on a Citrobn Berlingo?
Do it in the BSI via Diagbox telecoding. How-To:
  1. Start Diagbox, select your brand and vehicle, and run Global Test.
  2. Enter BSI, choose Repair if required, then select Telecoding (TELECIFICATION).
  3. Find Automatic Door Locking and set the desired state, then confirm.
Save a Visualisation before changes to revert if needed. [Elektroda, grala1, post #17536973]
I don't have a lock button; can I still enable auto-lock?
Yes. Without the button, enable or disable auto-lock by changing the BSI configuration in Diagbox. [Elektroda, pepe150, post #17536133]
In Diagbox 7.44, why do two windows open (Scantool and Lexia)?
This can happen when you connect. Diagbox 7.44 may present both Scantool and a Lexia window. Continue using the module shown and proceed carefully. [Elektroda, elektronikq, post #17547044]
Where exactly in Diagbox is the door-locking option?
After Global Test, enter the BSI module. Choose Telecoding (TELECIFICATION); if needed, pick Repair first to unlock Telecoding. Then browse BSI configuration for locking features. Take a Visualisation screenshot before changes. [Elektroda, grala1, post #17536973]
What is a Global Test and should I run it first?
Global Test initiates communication with all control units in the car. Run it first to detect modules and avoid misconfiguration. Then enter BSI from the results list to telecode features. [Elektroda, grala1, post #17536973]
Is updating Diagbox from 7.01 to newer worth it?
Updates primarily add support for newer cars. For older models, updates often change nothing in practice. Avoid update mania if you only service cars like the 307. [Elektroda, grala1, post #17533100]
Can I transfer data from one BSI to another with software only?
No. To clone a BSI, you must move or program its EEPROM. That chip holds the PIN, VIN, key data, and mileage. Soldering or chip programming is required. [Elektroda, dziungwaj, post #17547066]
What if I change the wrong BSI setting?
You may disable features or cause unexpected behavior. Before editing, open Visualisation and capture screenshots of current settings. That lets you restore factory behavior if needed. [Elektroda, grala1, post #17536973]
Which software should I use for a 2010 Peugeot 307?
Use Lexia/PP2000. For cars around 2010 and older, Lexia/PP2000 is sufficient. Newer vehicles require Diagbox instead. [Elektroda, grala1, post #17533100]
How do I toggle auto-lock without a diagnostic tool?
If the car has a lock button, hold it 510 seconds with the engine running. A confirmation message should appear on the display. If there is no button, use BSI configuration. [Elektroda, pepe150, post #17534132]
