Skoda Felicia 1.3 MPI - 1.3 68HP 50kW engine on the chain. TIMING
marcineli 13428 14
Is the 1999 Skoda Felicia 1.3 MPI 50 kW chain engine an interference engine, and will it survive if the timing chain fails?
Yes, this engine is treated as an interference (collision) engine, so if the timing chain actually fails or jumps badly, engine damage is possible [#16851254] In practice, people in the thread report that the chain usually does not snap; it stretches and gets noisy first, and that noise should be clearly audible before it becomes dangerous [#16851254][#16851514] One user reports a Felicia with 220,000 km still on the factory chain and another with 250,000 km with the original timing still running quietly [#16851514][#16851792] The common advice from the thread is that the chain itself is durable, but the accessories around this engine are not, so listen for timing noise and replace parts before it gets bad [#16851514][#16851792]
  • #1 16850900
    marcineli
    Rate: 48
    Skoda Felicia 1999
    1.3 68KM 50kW engine on a chain is this type the so-called. collision motor.
    I mean: how the chain breaks ( though he doesn't break up ) the engine will survive
    I can't read anywhere and I've been looking for a week.
    I may not be looking well but I am urgent because the car will pass sideways :)
    And if not, what felicities were the collision-free engines.
    Were they at all?
    Regards.
  • #2 16851018
  • #3 16851068
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    mihal2002 wrote:
    It's a blast.
    Is this a statement from experience or pure malice?
    Repair of such an engine should not exceed PLN 1,000. Parts for this are cheap.
  • #4 16851074
  • #5 16851087
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    mihal2002 wrote:
    This is from experience after Corsa 1.0
    Not this corsa and skoda technology :)
  • #6 16851100
  • #7 16851126
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    In this skoda there is an engine with a timing chain, pusher sticks, the design is not a mistake for me, it remembers 1945. It is an engine that was in a skoda 105 :)
    Revised slightly by VW.
  • #8 16851132
  • #9 16851203
    marcineli
    Rate: 48
    So the COLLISION engine, yes.
    And how much truth is in the timing chain does not break up.
  • #10 16851207
    ociz
    Help: 1379
    Rate: 3486
    I do not know the case that he broke up, but loose can damage the housing, except that it can be heard clearly even before it creates a threat.
  • #12 16851294
    marcineli
    Rate: 48
    Dzieiekuje
    Just for such or similar HELPFUL answers, I set up this topic.
    I look forward to more helpful answers in this topic.
    Maybe someone has some real experience with such a Felicia with such an engine when it comes to timing.
    Regards.
    Added after 6 [minutes]:
    mihal2002 wrote:
    Who told you that?
    Just that everyone and nobody, because everyone seems to know and know each other but no one's hand can be cut that it is because, for example: they had contact with Felicia only from the stories of friends or grandfather :)
    And the forums are all the more different strange versions but it is also not enough.
    That's why I'm asking.
    Because in this topic it is hard for me to find real examples.
    Pzdr.
    domasia
    Help: 12
    Rate: 43
    My first car was Favorita, the engine was roughly the same but with a carburetor.
    And I remember that when the chain began to make noise, it could not be missed, as if you were shaking the rattle at low speed. Blissful silence after the exchange.
    Currently, I have an adult Felicja as a duplex to drive around the city, on the meter 220 kkm and the chain as the factory gave. It doesn't make noise till today. So the timing is not moved.
    However, the voltage regulator is probably the tenth, the thermostat the sixth, and the spare Hall sensor is always in the glove box :)
  • #14 16851792
    LENIWIEC_PL
    Help: 119
    Rate: 322
    As for the skoda felicja with this engine, I had such a toy car and I must admit that the perpetual engine, but the engine itself, because its accessories are not. I bought it as a second owner and did some 100km (I often have trips) also now has 250,000 meters. As for the engine itself, the factory timing and surprisingly still works quietly but sometimes when you listen to it cold you can hear that it is gently pulled out, its accessories are tragedy, the thermostat is changed from 5 times, the tubing hoses in the eyes, the clutch is changed 2 times, Voltage regulators are also falling in the eyes, but I also recommend the Skoda with this engine with cheap parts.
    There is no such thing as a collision-free motor. Every engine will one day say "bye" ;)
  • #15 16853494
    marcineli
    Rate: 48
    But there are some engines where when the chain or timing belt breaks, the engine will survive, i.e. we put on a new one and drive.
    But this is not only about such a felt with such an engine.
    I already know everything.
    Thank you all.
    I close the topic.
    Regards.
The discussion revolves around the Skoda Felicia 1.3 MPI, specifically the 1999 model with a 68HP (50kW) engine that utilizes a timing chain. The main inquiry is whether this engine is a "collision motor," meaning that if the timing chain were to fail, the engine would not suffer catastrophic damage. Responses indicate that while the timing chain is generally reliable and does not typically break, it can become loose and potentially damage the engine housing. Users share personal experiences, noting that the engine design is robust, with some reporting that their vehicles have run well over 200,000 km without significant issues. However, they also mention that while the engine itself may be durable, its accessories often require frequent replacements. The consensus is that while no engine is entirely "collision-free," the Skoda Felicia's engine is relatively resilient in the event of a timing chain failure.
TL;DR: Felicia 1.3 MPI chains can run 220,000 km on the factory set, and "blissful silence after the exchange" is typical. [Elektroda, domasia, post #16851514]
Why it matters: If you’re weighing repair vs. replacement, knowing real-world chain life, symptoms, and costs prevents avoidable engine damage.
This FAQ is for Skoda Felicia 1.3 MPI owners troubleshooting timing-chain reliability, noise, and failure-risk questions.
Is the Skoda Felicia 1.3 MPI a collision (interference) engine?
Forum reports treat it as a collision risk—expect valve/piston contact if timing jumps. One user’s verdict on failure consequences: “It’s a blast.” Plan repairs accordingly. [Elektroda, 1098678, post #16851018]
Do timing chains on the 1.3 MPI actually break?
Reported cases of snapping are rare in this thread. The common issue is chain slack that grows noisy and may damage the front housing. Noise is typically heard before serious risk. [Elektroda, ociz, post #16851254]
What does chain wear sound like on this engine?
Owners describe a pronounced rattle at low speed or idle. After replacing worn parts, they report “blissful silence.” Use noise as your service trigger. [Elektroda, domasia, post #16851514]
How long can the factory chain last on a Felicia 1.3?
A documented example shows 220,000 km on the original chain with no rattle. That indicates long life when maintained and monitored. [Elektroda, domasia, post #16851514]
How much should a timing-chain repair cost on this engine?
One contributor states the repair should not exceed PLN 1,000 for this simple design, with inexpensive parts available. [Elektroda, T5, post #16851068]
Is the 1.3 MPI chain system similar to the Opel Corsa 1.0?
No. Users note the Felicia’s pushrod, chain-driven design stems from older Skoda architecture refined under VW, not Opel’s small triple. [Elektroda, T5, post #16851126]
Which failures mimic chain problems on Felicia 1.3?
Weak accessories can mislead diagnostics. Thermostats, hoses, clutch, and voltage regulators see frequent replacements, while the chain may remain serviceable past 250,000 km. [Elektroda, LENIWIEC_PL, post #16851792]
What spares are smart to carry in the car?
A seasoned owner keeps a spare Hall sensor in the glove box. It’s a practical insurance item for random no-starts. [Elektroda, domasia, post #16851514]
What does “collision engine” mean here?
In this thread, “collision” is used as shorthand for interference—if timing fails, valves can meet pistons and bend. [Elektroda, marcineli, post #16850900]
How can I quickly check for a worn timing chain at home?
Listen with the hood open: 1) Cold start and idle, noting any metallic rattle. 2) Hold a steady low rpm and listen. 3) If rattle persists, schedule timing service. “Blissful silence after the exchange” is a good sign. [Elektroda, domasia, post #16851514]
What’s the real risk if I ignore early chain noise?
Slack can escalate and the chain can damage the timing housing. Address noise promptly to prevent secondary damage. [Elektroda, ociz, post #16851254]
Why do owners call this engine durable despite issues?
Multiple owners report long-distance use with the original timing set, while acknowledging frequent accessory failures. “Perpetual engine, but its accessories are not.” [Elektroda, LENIWIEC_PL, post #16851792]
