Beko BCN130000 fridge - the light does not work and an alarm sounds
7902 2
  • #1 16858719
  • #2 16932842
    niemiec_a
    Rate: 8
    Did you find out what caused the fault? I have the same situation right now and I'm looking for a solution.
  • #3 16992098
    TofilKasia
    Rate: 11
    If it is a built-in fridge then you need to put two strips with a magnet on the door at the top and there will be a problem when they are missing, as if the fridge was open and the alarm goes off. The strips are included in the package for assembly. I had this problem myself.
