iPhone 6: Touch ID Not Working After LCD Replacement - 11.1 Silver, Black Home Button Issue
nemesis1 4881 6
  • #1 16859658
    nemesis1
    Hello, I will describe the problem, which will dispel any questions and suggest accurate answers, namely I have an iPhone 6 and 11.1 silver. Everything was smart in this touch id. The phone fell down and the LCD burst but continued to work on this touch id too. I decided to replace the LCD with a functional black with a black touch id button. I put on a new black LCD with a black home button and the finger recognition function stopped working. I put on the white original buttons for the new black LCD it works finger recognition function. What should I do to make this black button work because the black LCD and the white button look poor? thanks for the info
  • #2 16859689
    KamGr
    Help: 77
    Rate: 203
    You won't do anything about it, the button is assigned to the motherboard and that's why the one from the second display doesn't work for you.
  • #4 16881564
    Chawek
    Help: 6
    Rate: 61
    The original button has an integrated circuit paired with the processor. After replacing the button with another Touch ID it stops working, it's completely normal. If you want Touch ID to work, unfortunately you have to stay with the original white button ;)
  • #5 16883511
    bogdan2491
    Help: 52
    Rate: 97
    Probably there will be a stubborn service that will do it to work on black but when it comes to profitability it's definitely cheaper to find a white display, apart from the fact that such a procedure is a serious interference with the motherboard.
    In your situation, I would think about one of three solutions
    - live without Touch ID
    - live with the white button
    - buy a white display
  • #6 16883519
    hacker_ice
    Help: 36
    Rate: 101
    There is an option to do it but you would have to pull the whole system out of the button and this is very risky and you will lose touch ID if someone does it wrong.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #7 16883746
    Chawek
    Help: 6
    Rate: 61
    Due to the high risk of this operation, I did not mention this option :) The desire to have a black button is not worth the risk.
The discussion revolves around an iPhone 6 user who replaced a broken LCD with a black one, but the Touch ID functionality ceased to work with the new black home button. Responses indicate that the Touch ID button is paired with the motherboard, making it incompatible with non-original buttons. Suggestions include using the original white button, purchasing a white display, or living without Touch ID. Some responses caution against risky modifications that could permanently disable Touch ID.
