iphone 6 home button like nap - broken home button but id touch works ip6
dawid12242000 3480 3
  • #1 17311245
    dawid12242000
    Hi. I have this problem I want to buy an iPhone 6, but the home button does not work, but the fingerprint scanner works. Is it possible to repair the button itself? Is it only 1 element and it will not work because I know that the replacement of the button = the touchID function lock and I also know that there is a possibility of an on-screen button, but it's not the same. Thank you in advance for your answer.
  • #2 17311521
    Glemark1
    GSM specialist
    Help: 190
    Rate: 111
    Yes it is possible to repair the TouchID button.
  • #3 17311579
    dawid12242000
    I know it is, but I mean the button itself without TouchID, because after replacing the button, this function is blocked (from what I heard at least) and I want TouchID to work and the button too.
    Glemark1
    GSM specialist
    Help: 190
    Rate: 111
    You cannot replace the entire button because Touch ID will stop working, but in this you can fix the button functions.
