Samsung Galaxy Tab A 10.1 (SM-T585) - no image (black screen)
patmor 20904 9
How can I access a Samsung Galaxy Tab A 10.1 with a black screen to perform a hard reset or secure the data?
You can only do an ADB hard reset if USB debugging was enabled; otherwise boot the tablet into download mode and flash the multi-file firmware [#17317995] The thread also points to hardware failure, most likely a damaged backlight, so a software reset may not fix the black screen [#17318747] Because of that, the recommended solution is to send the tablet to warranty or Samsung service [#17317995][#17318747]
  • #1 17317942
    patmor
    Hello everybody!
    I would like to ask you for help and suggestions - how to get to the device when the screen stopped working?
    The screen (display, matrix) has been showing nothing since yesterday.
    A "click" sound is heard touching the display.
    The tablet has a warranty.
    Question:
    I would not like to send a device that has no PIN security, website password due to sensitive data on the device.
    How to get the device console and perform a hard reset or secure the device?
    Thank you in advance for your help
    PM
  • #2 17317995
    nutergsm
    Help: 1034
    Rate: 1666
    If you had USB debugging enabled, you should do a hard reset with adb. Another option is to put the tablet in download mode and upload multi-file firmware.
    Of course, the tablet should be sent back for warranty repair.
  • #3 17318706
    Lena84
    Rate: 9
    I have the same problem. Two months ago I gave it as a guarantee, after which the tablet returned after a two-week absence with the information that it is working properly and the service was not needed: / The same symptoms as before: the black screen does not respond. A sound is heard when the volume button is pressed as well as after connecting the charger. You can also hear all incoming notifications or screenshot. Nothing else. Hard reset - no response. Maybe there is a way to embrace it yourself?
  • #4 17318747
    nutergsm
    Help: 1034
    Rate: 1666
    I advise you to change the website. Preferably for the main samsung service. This is hardware damage, backlight damaged. How do you light a flashlight on the screen is anything you see?
  • #5 17318793
    Lena84
    Rate: 9
    Now it is a chapel, it has completely given up the ghost: / He lay down a bit and now nothing works.
  • #6 17318927
    nutergsm
    Help: 1034
    Rate: 1666
    Probably discharged.
  • #7 17318989
    Lena84
    Rate: 9
    It doesn't respond to the charger and the laptop can't see it anymore. Tomorrow is going to the site.
  • #8 17850222
    krzysiek_188
    Rate: 15
    Lena84 and what was the solution ?? I have the same problem. Only the volume key is heard and the charging light is on. The tablet turned off three times but after a day, sometimes under the charger it started to work.
  • #9 19358347
    Piorunowski
    Rate: 13
    Hello, I have an identical tablet. Children (6-8 years old) played on it, then one wanted to tear it away and the screen stopped working. When you turn on the power button, the backlight turns on, you hear unlock beeps etc, but the screen will not appear. Tell me, can I save the screen somehow?
  • Intermittent boot with no visible display output
    #10 19686982
    adasko83
    Rate: 19
    I have a similar problem for the second time. Ie the Samsung SM-T585 tablet is on, after connecting the usb power, you can hear the power connection sound. You can also hear the sound when you turn it down and up. The sound is also heard when pressing power plus Vol- (screenshot). Tablet also resets when holding Power and Vol- for 10 seconds. But you can't see anything on the screen, you can't see anything when backlit with a flashlight. But it seems to me that when the battery dies completely then it can be recharged. Somehow he came back to life a few times. you should wait and see if it helps this time. Strange thing, I don't know why this is happening.
The discussion revolves around issues with the Samsung Galaxy Tab A 10.1 (SM-T585) experiencing a black screen and unresponsive display. Users report hearing sounds when interacting with the device, indicating it powers on but the screen remains blank. Suggestions include enabling USB debugging for a hard reset via ADB, entering download mode for firmware updates, and checking for hardware damage, particularly backlight issues. Some users have had similar experiences, with devices returning from warranty service still malfunctioning. Others mention intermittent functionality after charging, but overall, many express frustration with the lack of a visible display and seek solutions to secure their data before sending the device for repair.
