Window Washer: Karcher WV Worth Buying? [Saturn, Price, Quality, Liquids, WV 5, Alternatives]
negatyw001 5067 7
  • #1 16866253
    negatyw001
    Help: 6
    Rate: 20
    In Saturn, I came across a cane promoting window washers.
    It does not overwhelm my biggest nuisance (framework), but it seems to be doing well with the windows.
    Questions:
    1) What is it worth?
    2) Do you only have to use original washing liquids?
    3) The most expensive model (Karcher WV 5) has a working time of 35 minutes. It seems embarrassing to me ...
    4) Do you recommend other brands (price / quality)?
  • #2 16866262
    Zbigniew 400
    Help: 283
    Rate: 794
    I recommend. Checked.
    You can use the car sprayer fluid.
  • #3 16866269
    negatyw001
    Help: 6
    Rate: 20
    Windshield washer fluid in the car? Anything? :)
  • #4 16866782
    Zbigniew 400
    Help: 283
    Rate: 794
    Must try.
  • #5 16866792
    kkknc
    Help: 1915
    Rate: 6709
    It's just rubber that scoops up the water. So that it does not drip and sucks inside. All the drink is liquid, you won't do it with the usual one, unless you add some dishwasher rinse aid to the glass. :)
  • #6 16866813
    Zbigniew 400
    Help: 283
    Rate: 794
    You are wrong. The liquid works because I washed the windows myself and it was ok. Maybe the rinse aid will improve the results but you need to check it.
  • #7 16866831
    kkknc
    Help: 1915
    Rate: 6709
    Then keep washing it, when I bought it 4 years ago, I washed it too, I know it.
    On Ori, windows are sparkling and there are no streaks on the "bets", ordinary window or washer fluid does not have this effect. After adding rinse aid, it is OK. There are no rubber streaks and the windows are slippery.
  • #8 16867086
    hessto
    Help: 10
    Rate: 79
    I have karcher WV5 premium + Cleamen 112 liquid Link: 10L or Link: 1L only for spring, summer, autumn, maybe also the car window is ok. :P
    Karcher wv5 (Rubber water vacuum cleaner i.e. dry) vs Regular rubber windshield squeegee (but those rubber wet).
    A car with winter windscreen washer fluids by orlen (floral) or Auchan (Organika) is approx. :)
The discussion revolves around the Karcher WV 5 window washer, with users sharing their experiences and insights. Many recommend the device, noting its effectiveness in cleaning windows without streaks, especially when using specific cleaning liquids. Users mention that while original washing liquids may enhance performance, alternatives like car windshield washer fluid can also be effective. The Karcher WV 5 has a working time of 35 minutes, which some find insufficient. Comparisons are made between the Karcher WV 5 and traditional rubber squeegees, highlighting the advantages of the former in terms of convenience and results. Users also discuss the addition of rinse aids to improve cleaning efficacy.
