Iiyama Monitor Issue: Black Bar on Right Side, Auto Button & Max Resolution Troubleshoot
galler72 7638 5
  • #1 16868033
    galler72
    Rate: 8
    Hello forum members.
    It kicked me to press the auto button on the monitor (iiyama) and the black stripe on the right side jumped. The control buttons cannot be adjusted. The resolution is at the maximum as recommended. Please help.
    Pedros050
    Help: 2471
    Rate: 3930
    Hello. How many inch monitor? What kind of cable is the VGA / DVI connected with?
    krzychupar
    Help: 1490
    Rate: 633
    You need to press the auto button again and set the image parameters again after the menu is displayed. This should be described in the operating instructions.
  • #4 16868136
    galler72
    Rate: 8
    iiyama E2001WSV
    ekran 20 ''
    VGA
  • #5 16868150
    Pedros050
    Help: 2471
    Rate: 3930
    Turn off the monitor unplug the VGA cable wait for a while and reconnect the VGA cable and turn on the monitor and the strip should disappear.
  • #6 16868152
    galler72
    Rate: 8
    krzychupar and PITERRR thanks. Problem solved.
    You really have to press "auto" again and hold it down longer.
    The black bar disappears almost completely and the rest can now be adjusted with the buttons from the monitor menu.
    Thanks and regards!
