Vertical Lines Then Blue Screen on 17 IBM Monitor—Possible Circuit Defect?
255 6
  • #1 21669651
    Elie Eliee
  • #2 21669652
    Noreen Ras
  • #3 21669653
    Elie Eliee
  • Need display type, schematic, and measurements
    #4 21669654
    Mark Harrington
  • CD4013 identified as the replacement part
    #5 21669655
    Mark Harrington
  • #6 21669656
    Mark Harrington
  • #7 21669657
    Mark Harrington
A 17-inch IBM monitor exhibits vertical lines on startup that disappear before the screen turns blue. The exact model and type of display (plasma, LCD, or CRT) are unspecified, complicating diagnosis. Potential causes include defects in the RGB output stage, absence of horizontal blanking pulses, faulty capacitors near the frame stage, grid-cathode shorts in CRT tubes, issues in the flyback stage, or capacitor failures on the tube base. Accurate troubleshooting requires detailed information such as voltage measurements and waveform analysis. Users are advised to consult IBM technical support and provide precise model details to identify similar reported cases. The discussion also highlights challenges in manufacturer communication and the importance of transparent customer service for effective problem resolution.
