[Solved] Monitor blinks - one second there's a picture, one second there's a black screen
kyrtaps 21351 1
  • #1 17852624
    kyrtaps
    Hi!
    PROBLEM: Dell laptop with Win10 I connect via HDMI-HDMI cable to LDC monitor 24" Iiyama ProLite B2403WS . Image on the laptop normal, on the monitor for a second it shows, for a second it disappears, I see a black screen. This kind of blinking goes on all the time.
    Laptop I previously attached to this monitor, with the same cable, with the same settings. There was never a problem. The problem suddenly appeared this morning.
    I checked the HDMI cable. On a different cable the same problem occurs with connecting the laptop to this monitor.
    I checked the monitor's performance - I connected it to my desktop computer with the same HDMI cable - everything works without a problem.
    Just yesterday I connected this laptop to another LCD monitor, with a different HDMI cable - everything worked without a problem.
    I updated the graphics card drivers on the laptop. It did not help.
    I changed the resolution and refresh rate - the monitor continued to blink.
    Tried pressing the plugs, moving the sockets. No effect.
    I have no idea what is going on.
    Anybody can help?
  • #2 17852644
    kyrtaps
    Not long after I started the topic, I found the solution.
    Probably the monitor software went crazy. The flickering was due to the embedded software's attempt to match the displayed image to the monitor.
    1. I gave the laptop image display only on the monitor.
    2. I unplugged the monitor for several seconds.
    3. I plugged it back in and the image stopped blinking. It already works normally.
    Previously turning the laptop/monitor on and off did not work.
    Problem solved.
