[Solved] Seeking Full Batch or CONF.BIN File for Panasonic TX-40C320E, 17MB97 with VES 400UNSS Matrix
zloo 11298 6
  • #1 16870604
    zloo
    Mark :P anasonic
    Model: TX-40C320E
    Chassis (motherboard or main components): 17MB97
    Matrix / Panel (if present): VES 400UNSS-2D-U01
    Other (comments): I'm looking for a full batch or a CONF.BIN file, it may be from another model with a VES 400UNSS matrix and a 17mb97 board
  • #2 16871609
    fadili
    Help: 11
    Rate: 454
    try this bin
    • MX25L1605_ panasonic 17mb97.BIN (2 MB) You must be logged in to download this attachment.
  • #3 16872785
    zloo
    Hello. Thank you for your interest and I will try to specify what I need. The TV works but does not respond to commands from the remote control. The problem arose after changes with the program: "vestel toolbox"
    in the file - "mb97 hwprofile" I changed the remote control type from Rc48XX to Rc4812 because I have one, after this operation, tv stopped responding to any types of remote controls. Now I cannot return to the previous settings because it is impossible to enter the service mode, but I can read and upload files: (CONF, KL, TEE, UBIA, UBIB) from the pendrive by pressing and holding the "ok" button and turning it on to the network . I found a complete update to this disc on the net, but with a different 39 "matrix, after uploading the remote control works, but unfortunately I have a reversed image. To read the bin files from nand flash I used a text file downloaded on a pendrive:
    # mb97 - dump firmware core
    #dump KL
    nandbin 0: 1 0 2048 0 CL.BIN CL
    #dump CONF
    nandbin 0: 1 0 2048 0 CONF.BIN CONF
    #dump UBIA
    nandbin 0: 1 0 2048 0 UBIA.BIN UBIA
    #dump UBIB
    nandbin 0: 1 0 2048 0 UBIB.BIN UBIB
    #dump tee
    nandbin 0: 1 0 2048 0 TEE.BIN tee
    reset
  • #5 18649709
    enceplacek
    Rate: 12
    CONF.BIN 17MB97 from the Celcus tv batch.
  • #6 19047355
    ahd540
    thank you my friend
    ok samarche well merici
  • #7 19560012
    Raykoonen
    very good works perfect thanks
The discussion revolves around the need for a full batch or CONF.BIN file for the Panasonic TX-40C320E television, which utilizes the 17MB97 chassis and VES 400UNSS-2D-U01 matrix. The user reports that the TV is operational but unresponsive to remote control commands after modifying the remote control type in the "vestel toolbox" program. Attempts to restore functionality have been unsuccessful, as the user cannot access service mode. Several users provided links to relevant firmware files, including a CONF.BIN from a Celcus TV batch, which helped some users restore functionality, although issues like reversed image persisted with different matrix configurations.
