[Solved] Toshiba 40LL3A63DB 17MB211S VES400UNDS-2D-N41 SPI Flash Dump & USB Firmware Request
galutvaa 2133 7
  • Requesting exact firmware version and source
    #1 21584708
    galutvaa
    Hello everyone,
    I'm looking for help with a Toshiba TV,
    model: 40LL3A63DB,
    Chassis (main board): 17MB211S,
    LCD Screen/Panel: VES400UNDS-2D-N41.
    TV is not working after a failed firmware update. It doesn't show the Toshiba logo anymore, only the green LED stays on. No reaction to IR remote, virtual remote, or front panel button. I suspect the SPI flash is corrupted.
    Could someone please share:
    1. A working 2MB SPI flash dump (Winbond 25Q16JVSIQ) for this exact model (or compatible)?
    2. The correct USB upgrade firmware that matches this model/panel to restore the NAND.
    Any help or links would be greatly appreciated. Thank you in advance!
    AI: Could you please specify the country or region where you purchased and use this TV? This can help ensure the firmware or dump provided is compatible with your model.
    UK
    AI: Do you know the exact firmware version that was installed before the failed update, or can you share where you obtained the update file that caused the issue?
    abramkyr1995
    >>21584708 Try, if TV is responding with the buttons on TV (see the blink LED on TV).
  • SPI flash reprogrammed, now seeking complete USB update files
    #3 21585801
    galutvaa
    >>21585703 Thank you for your reply.
    Unfortunately, the only button on the TV is the power button.
    After flashing the wrong dump, the TV powers on automatically, the green LED stays on, and the screen remains black. The power button no longer responds, and there is no blinking from the LED when pressing it.
    The TV does not enter standby anymore.
    I believe only the correct SOI dump will help now.
    Thank you again for any help.
    Added after 2 [hours] 55 [minutes]:
    Update
    I have successfully reprogrammed SPI flash chip. Now the TV responds to the original remote control again. The Toshiba logo appears correctly at startup, but after that the screen goes black.
    I believe the NAND or main firmware is still incorrect or incomplete.
    Now I'm looking for a complete USB update package with all 4 required files: shreder_usb_update.bin, shreder_usb_update.scr, shreder_usb_update.scr.core, upgrade_mb211.bin.
    If anyone has this complete set, i would greatly appreciate your help.
  • #5 21586537
    galutvaa
    >>21586265 Thanks a lot for providing firmware.
    Unfortunately, after the logo, screen still goes black and I cannot access the menu or image. I'm now looking for a full USB update set with all four files: shreder_usb_update.bin, shreder_usb_update.scr, shreder_usb_update.scr.core, upgrade_mb211.bin. If you or someone else has the full USB update, I would greatly appreciate your help!
  • #6 21586872
    yokoono51
    Help: 176
    Rate: 321
    The full software for 17MB211 has 2 files, not 4.
  • #7 21587375
    galutvaa
    According to the official Vestel service manual for the MB211 project, a full USB update requires all 4 files: shredder_usb_update.bin, shredder_usb_update.scr, shredder_usb_update.scr.core and upgrade_mb211.bin.
    See section 12 of the service manual in the attachment for reference.
    • 17MB211S_SERVICE_MANUAL.pdf (5.92 MB) You must be logged in to download this attachment.
  • #8 21600796
    galutvaa
    The dump and firmware were found. The microchips were flashed. The C113 capacitor on the power board was also replaced.
A Toshiba 40LL3A63DB TV with 17MB211S main board and VES400UNDS-2D-N41 panel failed after a firmware update, initially showing only a green LED and no response to remote or front-panel controls. The issue was traced to corrupted SPI flash; after reprogramming the Winbond 25Q16JVSIQ, the Toshiba logo returned, but the screen stayed black, indicating incomplete or incorrect main firmware/NAND content. The discussion focused on obtaining a compatible 2 MB SPI dump and the correct USB recovery package for the UK region, including the MB211 software files referenced in the Vestel service manual. A firmware link was shared, and the problem was later reported as resolved after the dump and firmware were found, the microchips were flashed, and capacitor C113 on the power board was replaced.
