Acer Laptop - Black Screen with Cursor & Safe Mode after Startup on Windows 8.1: Solutions?
dako2012 4587 2
  • #1 16874929
    dako2012
    Hello. Well, I have a problem with the laptop. After turning it on, the Acer inscription starts and then there is a black screen and a cursor, and there is only safe mode in every corner on the desktop. Tried all alt ctrl delta actions .... But nothing helped.
    Maybe it's my fault because I turned on safe mode earlier it was ok, I restarted it and that's it. I will add that it is windows 8.1 and it was not even moved anywhere.
    Please help.
  • #2 16875055
    Pedros050
    Help: 2471
    Rate: 3923
    Hello. Did you press F8 while booting the system?
  • #3 16875066
    oficek
    Hi
    It looks like operating system files are damaged.
    Before you run system recovery from the system disc or partition, please consider whether you have important data.
    If so, back them up using another computer, e.g. using an external pocket.
    On Acer laptops, system recovery usually starts by holding down the ATL + F10 keys at startup.
    Before using the recovery option, try to repair your system if this functionality is available
    best regards
