Skoda Octavia I MPI 2007 The engine indicator -VAG shows the thermostat error
Userr1 7824 5
  • #1 16877219
    Userr1
    I warmly welcome
    I would like to deal with the problem in my Skoda.
    The car is:
    Skoda Octavia I, 2007 petrol
    Current mileage 170,000km.
    After turning the key on the desktop, the yellow engine light appears and does not disappear.
    Auto, the engine generally works well except for two things.
    Thank you in advance for any hints.
    Greetings.
    Cinek_Barczewo
    Rate: 26
    Hello, has there also been a fault in the refrigerant fluid temperature sensor? Perhaps he is the cause. greetings
  • #3 16877339
    Userr1
    Thank you for your response. From what I remember, it was just this one mistake related to the thermostat. The mechanic, what checked it, he asked if I do not have any problems with the temperature while driving.
    helmud7543
    Help: 1216
    Rate: 1564
    I do not know how to use Octavia (let people who are more familiar) but for me the faulty thermostat has led to the engine, and the error is a poor mix on the first probe. The thermostat was playing a bit but it was enough.
  • Confirming thermostat type for BFQ engine
    #5 16879071
    Userr1
    Although I have not checked those snakes yet, I have already bought a Vernet thermostat TH6276.87J
    I hope it will match and the yellow engine light will disappear from the desktop.
    It can not be ruled out that this extinguishing also has another cause ...
    I hope it's nothing serious.
    Added after 1 [hour] 23 [minutes]:
    I have some doubts now whether I bought a good thermostat for my car. I see that there are two types, one such as I bought and the other one built into the housing.
    Could someone confirm on the basis of his knowledge and this is the right thermostat for my car?
    My car is:
    Skoda Octavia I Tour 1U 2009, 1595cm3, 75KW,
    I bought a Vernet thermostat TH6276.87J
    Added after 11 [minutes]:
    In papers I have now found and the designation of the engine is BFQ, so I understand that this thermostat will not fit?
    What should I have, will it be in the housing?
    sebap
    Help: 538
    Rate: 1082
    Since it showed its error, it is connected to the ECU and since it is connected to the ECU, it is probably with the casing, so if the Vernet is TE7141.105J but it will be best if you find organoleptically sitting in your car or approach the car shop and let them pick the VIN number.
