New GTX 1070, i5 6600k, ASUS Z170: Fans Not Working After System Load, BIOS, Driver Issues
6207 10
Why do the fans on my GTX 1070 stop after Windows loads, and are they supposed to stay off until the card warms up?
The GTX 1070 likely has semi-passive cooling, so the fans can stay off at low temperature and should start around 50–55°C [#16878085] Put the settings back to default, open HWiNFO, and watch the GPU temperature and fan speed while running a game or stress test in a window so you can see when the fans start [#16878085] If fan control software is installed, uninstall all GPU utilities such as MSI Afterburner and other fan-control tools, then install only the graphics drivers again and retest [#16878531]
  • #1 16877718
  • #3 16877857
  • #4 16877865
    pitrala1
    Help: 129
    Rate: 111
    Do they move normally under load? What temperatures under stress does the card reach?
    The fact that the fans go out can be something quite normal, the card may have a passive mode - below a certain temperature the fans are turned off.
    EDIT:
    I just noticed that under load they move - so it's like I wrote - close the case and play :)
    EDIT2: however temperatures.
  • #5 16877890
    Piterixos
    Help: 38
    Rate: 56
    Misteriol wrote:
    @ Radu23 thanks for the improvement and I will give a screen soon :) I will add that after m
    Ok, I attach the report: https://mega.nz/#!d0Fl3QoD!Ij64wnhWPF0LQ6KTgOEIbOjxpTk48qYrfjzkKIpnp7s
    I will add that when I started knowledge 3 on windmills from afterburner msi, I have 1/3 less fps and the card reaches 95 degrees before it was max 80
    You were supposed to include a screen with sensor readings, not a hardware specification report.
    What is the card temperature in idle? With these fans off? Maybe this card is just so programmed, in my GTX 1060 the fans almost do not spin at all.
    I understand that in MSI afterburner you can regulate the speed normally and everything works?
    Temperatures under stress at revs set to maximum are how much?
  • #6 16877918
  • #7 16877930
    pitrala1
    Help: 129
    Rate: 111
    In MSI after boulevard, didn't you uncheck the automatic fan regulation?
  • #9 16878085
    atomic99
    Help: 171
    Rate: 338
    @Misteriol These cards have semi passive cooling, put everything as it was at the beginning.
    Turn on HWiNFO, start a game in the window so that you can observe the temperature and rotation of the graphics card fans.
    After the graphics get how well I remember 50-55 °C fans should start working.
  • #10 16878531
    pitrala1
    Help: 129
    Rate: 111
    Uninstall all drivers, graphics card programs (your afterburner, if you have any other to control the fans or graphics, too), then install the graphics card drivers themselves. Run HWINFO, play some demanding game at least 10-15min and give screen but only the GPU section in this program.
  • #11 16878660
The discussion revolves around issues with a newly built PC featuring a GTX 1070 graphics card, an i5 6600k processor, and an ASUS Z170 motherboard. The user initially faced problems with the system not displaying an image and the fans not operating until physical pressure was applied to the cooling system. After resolving the initial boot issue, the user reported that the GPU fans stop working after the system loads, despite being operational during stress tests. Various suggestions were made, including checking fan settings in MSI Afterburner, monitoring temperatures with HWiNFO, and ensuring proper driver installation. It was noted that the GTX 1070 has a semi-passive cooling feature, where fans activate at certain temperatures, typically around 50-55°C. The user confirmed that the fans began functioning correctly after reaching the specified temperature.
