A-KLASA / W168 / 1.6 ben semiaut - Starter Not Functioning After ECU Cable Disconnection
dawidgdansk1981 9303 5
  • Disconnected ECU cable likely triggered starter interlock
    #1 16698076
    dawidgdansk1981
    Until today, the car was running normally, but I wanted to unscrew the flow meter and check how dirty it is.
    However, I did not unscrew it, because I had to leave and unfortunately I tried to start the car on the DISCONNECTED ECU CABLE.
    Of course, the car did not start, even the starter did not turn, but the fan turned on.
    I go back under the hood, plug in the ECU cable and go back to the cabin.
    I am trying to start - the fan does not turn on anymore, I hear that the fuel pump is working, BUT THE STARTER AGAIN DOESN'T SPEED EVEN. And half an hour earlier he was working normally ...
    I connected to the computer and there were errors with the connection to CAN and a short circuit of the starter mass - strange because it greedily worked before and I did not drive the car ...
    I deleted the errors and now purely on the computer and then the starter will not even turn ... please help
    It is a pity that I went and tried to unscrew this flow meter - I would not have this fault now - because it is not known what happened
  • #2 16698094
  • #3 16698156
    dawidgdansk1981
    I'll check the battery area tomorrow
    and if I find a plug with this purple cable, what next ...? - should I check something with a meter?
  • #4 16698170
    kkknc
    Help: 1916
    Rate: 6713
    And you briefly checked the starter itself.
  • #5 16698172
  • #6 16699897
    dawidgdansk1981
    I solved the problem.
    I checked that by putting the plugs back into the ECU, I must have made a mistake - one pin to be exact was bent ...
    After straightening, the car continues to run as before ...
    I close the topic - Thanks - Regards
