Using TP-Link WR841N as WDS Bridge: Troubleshooting Network Issues & Changing Router IP Address
poldzer 9762 5
  • #1 16880947
    poldzer
    Help: 15
    Rate: 83
    Hello!!
    I wanted to use this by net router with wifi passed to me on the cable. I found this guide: http://www.tp-link.com.pl/faq-227.html?id=87. He found a network etc. But still net is gone :( i changed router ip: 192.168.1.2 but then i can't login: \. Any ideas? The ping command crashes that the host is not found but receives 4 packets. Weird stuff :( .
  • #2 16881347
    bogiebog
    Help: 2569
    Rate: 1530
    Upload gargoyle software to your hardware version.
    And then use WISP or AP client mode.
  • #3 16881831
    jimasek
    Help: 3783
    Rate: 2681
    WDS is a weak and unstable choice, especially when you have two different chipsets on your devices. As above, try with Gargoyle.
  • #4 16882613
    poldzer
    Help: 15
    Rate: 83
    The gargoyle and the factory firmware are the same. Everything seems to be set up. He found a wifi network and read its parameters. The ping command correctly pings both routers. Even the indicators show some kind of network traffic. But the page won't load. Browser crashes an IP error. What to look for?
  • #5 16882759
    bogiebog
    Help: 2569
    Rate: 1530
    Show gargoyle settings.
    What is the IP of the root router?
    You set the security in the gargoyle as in the main router?
  • #6 16882819
    poldzer
    Help: 15
    Rate: 83
    The topic is overwhelmed. it was enough to change the IP of the bridge-router to 192.168.1.2. Everything works. I close.
