LG WD 14440TDS Washer: Persistent Spin Program Hang & Drum Arrangement Issue
talbotsolara 29358 17
Why does my LG direct-drive washer keep re-arranging the load and hanging during the spin program without advancing the timer, even though the drum starts to spin and the tub is empty?
Check the drain pump assembly first, especially the impeller and its cover, because a seized or partially blocked pump can make similar LG washers stall before spin and keep trying to re-balance the load [#18519164] In one matching case, the impeller cover was damaged, sludge got into the pump housing, and the impeller froze; cleaning it and replacing the pump afterward solved the problem [#18519164] Also inspect the hydrostat hose/chamber and the drum wheel positioner/tacho, because a bad empty-water signal or position sensor can stop the washer from completing spin [#16884052][#16884061] If the motor is brushless, brush wear is not the cause, and a bearing problem would usually be obvious when turning the drum by hand with the washer off [#16884061][#16885110]
  • #1 16881881
    talbotsolara
    Rate: 12
    Hello, I saved the washing machine from scrapping LG DD WD 14440TDS, the problem is that, for example, I choose the spin program without rinsing, e.g. 1000 revolutions shows the time of 12 minutes. She turns the drum to arrange the load and begins to spin, slowly spinning to medium speed, then slows down and again as if she was trying to arrange the laundry, and arranges it constantly and "hangs" and time does not pass.
    However, after turning off and on from the beginning of the same program, it does not even start to screw, only endlessly as if it tried to arrange and it freezes again. The pump turns on, sometimes it is quieter and louder, it is probably flown out, but it probably does not stop it from freezing. I tried empty and with some load, it looks a bit like in other washing machines as if there was a problem with the tacho.
    I also have a similar LG DD washing machine, so I can replace something, I will add that sometimes when the drum is idling, it screams a little, but if it screwed in slightly, it does not, the bearing has no noticeable play, where to start looking?
    I will add that I dealt with the repair of washing machines and I have already repaired a dozen thanks to this forum, without even creating a new topic or asking myself any questions, so I can do it, but LG DD is a bit new.
  • #2 16881972
    michalek1988
    Help: 68
    Rate: 181
    Have you checked if you can pump out the water without any problems? In my old Amica, contamination accumulates notoriously at the filter. I have a very small bathroom so removing the filter requires emptying the bathroom. Dishwasher tablets turned out to be quite an effective method. None of the manufacturers recommends it, but I decided that I had nothing to lose, 1 tablet a month is enough and something will always come off. There are also special tablets for washing machines, but they are weaker than dishwasher tablets. Sometimes it was able to work without a problem, other times when it was spinning (whether it was in the washing process or just spinning). If you want, try to put 1 tablet (any brand) at about 60 * C and a long wash. Pay attention to whether the washing machine makes any disturbing sounds during washing.
  • #3 16883801
    talbotsolara
    Rate: 12
    I did not wash with this washing machine, because if I do not want to spin, the laundry will not end either, the filter is clean, the pump looks like it is just flown out, and it should not affect, first let it spin normally, then it can run the laundry.
  • #4 16883859
    michalek1988
    Help: 68
    Rate: 181
    Try to do what I wrote earlier, here a lot depends on the quality of water and contamination of clothes, detergents used. Because if it's an electrical or mechanical fault, this tablet won't do you any good, if you have easy access to the filter, you can clean it yourself and try again. If the washing machine has water, spinning will not start, and you will not drain the water when your filter is blocked.
  • #5 16883871
    talbotsolara
    Rate: 12
    This washing machine does not contain any water, it is dry.
  • #6 16883958
    michalek1988
    Help: 68
    Rate: 181
    Are you sure that the pump is worn, not blocked, and hence the difference in comfort?
  • #7 16884052
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6953
    When the washing machine is "drained" of water, the condition of the pump does not matter, it may not even work.
    My friend talbotsolara , to check the cleanliness of the hydrostatic impulse chamber, or if you have a donor, it is worth trying to replace the drum wheel positioner (after removing the drive wheel at the bottom, there is a positioner on the coils, probably 5 wires come to it).
  • #8 16884061
    wiesiekmisiek
    Help: 259
    Rate: 524
    And what brush motor? What condition of the brushes? As for the pump, it can work louder when dry. You also need to check the hydrostat, the patency of the hose, the patency of the lower cup, i.e. connecting the pump to the washing unit itself. It may also be that the hydrostat is jammed and does not give a signal that the washing assembly is empty of water and thus, consequently, there will be no spinning. Too short brushes also prevent spinning and may damage the rotor in the motor. Good luck, because if you do not detect anything in these operations, then you will have to take care of the control panel and the module, and there will be more work and more precise work. Let me know about the results of these reviews, then someone else will probably drop off something more. You do not know the washing machine (the point is that you were not its user), you need to review everything from the very beginning, including drainage patency.
  • #9 16884082
    talbotsolara
    Rate: 12
    I have just disassembled the pump unit (there are two), one pours water probably back into the powder hopper and one traditionally poured out of the washing machine, the pouring one is obviously more flushed, but both work. As for brushes, they are missing because it is a brushless motor on the drum. The cup and hose are free, the pressure switch I do not know how to check because it is stepless, it seems to me that it is something like a potentiometer that deflects the pressure from the cup, I will immediately replace the second washing machine if they are the same. I was already getting to the positioner, but I haven't pulled it out yet. I changed the hydrostat and the same thing, something is spinning for a moment and 15 minutes. only 2 minutes elapses. Is this drum whining at idle speed probably a bearing? The drum seems to resonate.
  • #10 16885110
    mrice
    Help: 2213
    Rate: 6953
    The bearing will be heard when you turn the drum with your hand when the washing machine is turned off, and when the positioner is damaged, the drive makes interesting sounds too ...
  • #11 16885534
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    Since you have already checked a few things, it may be worth checking the heater for breakdown to ground, preferably with an inductor.
  • #12 16885540
    talbotsolara
    Rate: 12
    I will check with the meter has a range of 40M?.
  • #13 16885611
    Lodxx
    Help: 105
    Rate: 245
    So it can be ruled out because the results are okay.
  • #14 16885617
    talbotsolara
    Rate: 12
    The meter is up to 40Mohm;] I wrote wrong.
  • #15 16898996
    talbotsolara
    Rate: 12
    I replaced the entire drive and then the same. Together with a strange noise, I think I give up because a wheel with magnets fell down, and when two pieces broke off, sticking it on will not do anything, right? Because it seems that then the poles are formed there?
  • #16 16899017
    michalek1988
    Help: 68
    Rate: 181
    If you cut a bar magnet (any other magnet will do the same), you will get 2 smaller ones in half, neither of them will have only the North or only the negative pole. The cut lines will be opposite to those you have at the "primary" ends of a large magnet.
  • #17 16899500
    talbotsolara
    Rate: 12
    In short, is it sticking together or not?
  • #18 18519164
    andrzejbzdyra
    I have just been struggling with the LG washing machine for three days. Model WD 14352 FD, although it does not matter because the pumps are the same or very similar in all LG and maybe other brands. Symptoms similar to the first post. It usually blocked around 10-12 minutes, i.e. before spinning, or 23-25 minutes, i.e. before pre-spinning. I tried switching between programs. Sometimes she went, sometimes she didn't. If not, it became as above again. Finally, I took the water pump assembly apart. And all clear. A hole has been punched in the impeller cover through which the pump impeller axis passes and sludge has entered the housing, which can often be seen in the filter. It was he who caused the pump to freeze. Quick clean, a little oil inside and the washing machine did a few washes without a hitch. Of course, this is an ad hoc repair only to verify the correctness of the diagnosis. Inexpensive item and goes to replace.
The discussion revolves around issues with the LG WD 14440TDS washing machine, specifically a persistent problem where the spin program hangs and the drum fails to spin properly. The user describes the machine attempting to arrange the load but freezing during the process, with the timer not progressing. Various troubleshooting steps are suggested, including checking the water pump, filter cleanliness, and the condition of the hydrostatic pressure switch. Users also discuss the potential impact of a faulty drum positioner, motor brushes, and bearings. One participant shares a similar experience with another LG model, where a blockage in the pump assembly was identified as the cause of the freezing issue. The conversation emphasizes the importance of thorough inspection and testing of components to diagnose the problem effectively.
TL;DR: LG Direct Drive washers that loop “arranging the load” often stall near 10–12 or 23–25 minutes; “Quick clean… did a few washes without a hitch.” [Elektroda, andrzejbzdyra, post #18519164]
Why it matters: This FAQ helps DIYers quickly isolate pump, sensor, or rotor issues that cause persistent spin-program hangs on LG WD 14440TDS and similar models.
Why does my LG WD 14440TDS hang on spin around 12 minutes?
This pattern matches a pump assembly that intermittently seizes from sludge at the impeller cover. The washer loops its balance routine and never ramps to full spin. Confirm by opening the pump module; cleaning often restores function temporarily, but replacement is the durable fix. Users report stalls near 10–12 minutes (pre‑spin) and 23–25 minutes (pre‑wash spin). [Elektroda, andrzejbzdyra, post #18519164]
How do I tell if drainage is the cause when the tub seems empty?
If the washer is fully drained, the pump’s condition does not prevent spinning. Next, inspect the hydrostatic chamber and tubing for blockages and verify the drum position sensor. As one expert notes, “When the washing machine is ‘drained’ of water, the condition of the pump does not matter.” [Elektroda, mrice, post #16884052]
What is the hydrostat (pressure sensor) and how do I check it?
The hydrostat senses water level via a hose from the tub’s lower cup. A jammed sensor or blocked hose stops spinning by reporting water still present. Check hose and cup for debris, then verify the sensor toggles as you apply and release pressure. Replace if stuck. [Elektroda, wiesiekmisiek, post #16884061]
What is the drum positioner on LG Direct Drive, and where is it?
It’s the drum wheel position sensor used for load balancing and ramp‑up control. Access it after removing the bottom drive wheel; the positioner sits on coils and typically has about five wires. Failure causes odd drive noises and endless balancing cycles. [Elektroda, mrice, post #16884052]
How do I inspect and clean the LG pump module (quick 3‑step)?
  1. Remove the pump assembly; note there may be separate drain and recirculation pumps.
  2. Open the impeller cover and clear sludge around the impeller shaft and cavity.
  3. Reassemble and test; if it frees up, replace the pump to avoid reoccurrence. [Elektroda, andrzejbzdyra, post #18519164]
Could bearings cause whining at idle and affect spin?
Yes. Check by turning the drum by hand with power off. Roughness or rumble suggests bearing wear. Also consider the positioner: a failing position sensor can produce unusual drive sounds and poor ramp‑up. Address sensor issues before assuming major mechanical failure. [Elektroda, mrice, post #16885110]
Does this LG Direct Drive motor have brushes I should replace?
No. The WD 14440TDS uses a brushless Direct Drive motor mounted on the drum. There are no carbon brushes to inspect or replace, so focus on sensors, pumps, and bearings instead. [Elektroda, talbotsolara, post #16884082]
Should I test the heater for leakage to ground during no‑spin diagnostics?
Yes. Insulation breakdown can upset control logic. Use a meter with a high‑resistance range (up to 40 MΩ) and check heater to chassis. If readings are sound, rule it out and continue with pump and sensor checks. [Elektroda, talbotsolara, post #16885617]
My pump gets louder when running dry—normal or a fault?
Louder pump noise when dry can be normal, but it should not be rough or seized. If the machine is truly drained and noise persists, inspect for sludge, worn bushings, or impeller damage, then replace the pump assembly if wear is evident. [Elektroda, wiesiekmisiek, post #16884061]
I replaced the entire drive, but the hang persists. What else could be wrong?
Check the rotor’s magnet ring. If the ring fell and pieces broke off, control and balance routines degrade, and adhesive repairs may not hold. Replace the rotor assembly to restore proper pole alignment and stable spin‑up. [Elektroda, talbotsolara, post #16898996]
Can a detergent or dishwasher tablet clean help unblock things?
Some users report success running a long 60 °C cycle with one dishwasher tablet to loosen residues. Manufacturers do not recommend it, but it can free debris and improve drainage temporarily. Always clean the filter manually first. [Elektroda, michalek1988, post #16881972]
What does the endless “arranging the load” loop indicate on LG?
The drum rotates slowly to balance laundry before spin. If drainage or level sensing misreports, or the positioner fails, the controller repeats that loop indefinitely and time appears frozen. Verify pump, hydrostat, and the position sensor. [Elektroda, talbotsolara, post #16881881]
How do I confirm the washer is actually empty before spin?
Open and clean the filter, then ensure the drain path is clear. If water remains, spinning will not start. After clearing, run drain again and watch the outlet. Persistent stoppage points to the pump or its housing. [Elektroda, michalek1988, post #16883859]
Is a noisy pump always the root cause of spin hangs?
Not if the tub is fully drained. Once empty, focus on the hydrostatic impulse chamber and the drum positioner. These faults can mimic drainage issues and keep the cycle in a pre‑spin loop. [Elektroda, mrice, post #16884052]
