[Solved] Toyota Yaris 2016 (51kW) Air Pressure Sensor: Switching to Winter Tires without Sensors
jerzy 10 26643 4
  • #1 16885992
    jerzy 10
    Rate: 92
    Toyota Yaris 51kW 2016 r has 175/65 / R15 tires with air pressure sensors,
    If I exchanged for complete wheels with winter tires but without sensors, will there be any problem except that the tire pressure warning lamp will probably be on?
  • #2 16886571
    szymitsu21
    Help: 342
    Rate: 1292
    There will be no other problem.
  • #3 16886579
    jerzy 10
    Rate: 92
    I read that there are two types of tire pressure control systems, direct and indirect. Which system is used in Toyota Yaris III 2016 51Kw gasoline
  • #4 16894928
    jerzy 10
    Rate: 92
    Everything is clear, it is a direct system, air pressure sensors are installed in the wheels. I exchanged for a set of wheels with winter tires without sensors. The indicator behaves the same as before the change, i.e. after starting the engine it goes out.
  • #5 17122332
    jerzy 10
    Rate: 92
    After replacing the wheels without sensors, except that sometimes the indicator lights up, nothing else happens.
