Which Laptop Screwdrivers? Best Options for 50-70 PLN with Good Grip - Recommendations Needed
Dziben 12933 9
What laptop screwdriver set should I buy in the 50–70 PLN range, with a good grip and the right small bits for laptop screws?
For laptops, buy a precision screwdriver set with replaceable bits rather than a single screwdriver, and make sure it includes small Phillips sizes like PH1, PH0, PH00 and sometimes PH000, plus small torx bits [#16887956][#16890967] One user says one size from the Yato-type set is enough for almost every laptop, and another recommends longer screwdrivers because they feel better in the hand [#16887956][#16890967] The 50–70 PLN budget may be too low for really solid screwdrivers, but there are Yato precision sets and a more durable Steel S2 version mentioned as worth looking at [#16890967] Another recommendation is a screwdriver with interchangeable precision tips and a grip that fits your hand, since comfort is individual [#16887956] If you want an adjustable option, one reply also mentions a screwdriver with adjustable tightening force [#16891337]
  • #1 16887882
    Dziben
    Which laptop screwdrivers should you buy for 50-70 PLN to make them good and have a good grip?
    Dziben
  • #2 16887895
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    I have been shooting for a few years very handy strong tips, but I don't know if you will buy this model yet. Which Laptop Screwdrivers? Best Options for 50-70 PLN with Good Grip - Recommendations Needed Which Laptop Screwdrivers? Best Options for 50-70 PLN with Good Grip - Recommendations Needed
  • #3 16887915
    Dziben
    What model is it?
    And can you spin a laptop with them? I have small screwdrivers, they have really small crosses. And the ones in the picture look big. I'm afraid they won't be able to unscrew the small screws.
  • #4 16887920
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    The Yato set does not include a model, crosses, flat, torks on the box
  • #5 16887932
    Dziben
    Ok i will see Do you propose a set of precision screwdrivers? It is best if it was a set, not separately. :)
  • Small cross bits may not fit laptop screws
    #6 16887942
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    You asked about the laptop so I write what I start. All in all, I use the two most often from the set, but I feel so comfortable that I bought another one if something happened to the old ones :D
    Many small ones that I have are too small, and as I wrote especially one size is for almost every laptop :D
  • #7 16887949
    Dziben
    Okay, where could I find such a set? allegro or something? It's a pity you don't have a model.
    Is this the set?
  • Recommend a precision screwdriver set with replaceable tips
    #8 16887956
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    With replaceable small / precision tips. choose how you "sit" in your hand, how you work. It is difficult to advise me on those and my friend uses others and says that they suit him better, it is an individual matter.
    Dziben wrote:
    Which laptop screwdrivers?
    Is this the set?
    No, this is another new model no longer suits me :D
  • #9 16890967
    tomiok
    Help: 133
    Rate: 292
    Me too, the old ones are cooler, better in my hand (for me).
    As for screwdrivers, I like longer ones.
    Sizes are important, e.g. the most commonly used are. (mainly PCs) PH2, and the rest, PH1, PH0, PH00, rarely PH000.
    For this various small torxes.
    The amount of PLN 50-70 is (for me) a lot too small for solid screwdrivers.
    It is true that I usually use a screwdriver with an automatic clutch, but these are already large sums.
    Added after 9 [minutes]:
    marqqv wrote:
    I have been shooting for a few years very handy strong tips, I don't know if you will buy this model yet ...
    http://www.narzedzia.pl/zestaw-wkretakow-precyzyjnych-6-sztuk-yato-yt-2576,35554.html
    Also worth (Steel S2 - durable):
    http://www.narzedziasklep.pl/p/48/8688/yt-257...-stal-s2-zestawy-wkretakow-klucze-reczne.html
    Of the cheaper ones, my favorite set:
    http://www.narzedziasklep.pl/p/48/8687/yt-257...-l-150mm-zestawy-wkretakow-klucze-reczne.html
  • #10 16891337
    Aress124
    Help: 152
    Rate: 214
    I recommend such a screwdriver as an accessory link
    I have been for a year and I am very happy, I do not open a few laptops a day but I use them quite often.
    The casing is a bit shoddy, but the most important thing is that it fulfills its role.
    It is possible to set the tightening force.
The discussion revolves around recommendations for laptop screwdrivers priced between 50-70 PLN, focusing on options that provide a good grip and functionality. Users express a preference for sets of precision screwdrivers, highlighting the importance of size and type, particularly mentioning PH2, PH1, PH0, and various small torx sizes. Some users share links to specific screwdriver sets, including Yato models, while others emphasize the need for durable materials like Steel S2. Concerns are raised about the adequacy of lower-priced options for serious laptop repairs, with suggestions for sets that include replaceable tips and adjustable torque settings.
