[Solved] VW Touran 2007: Immo Problem with Micronas 1T0920864A & Golf 5 1K0920874B - Recode Tips & Tools
kozik20l 13830 19
How can I recode a 2007 VW Touran/Golf 5 instrument cluster swap for the immobilizer, and which cheap tool can do it?
You will not recode this with VCDS; the thread says it is Immo4 / 3rd generation, so the practical method is to copy the immobilizer data from the old cluster to the new one or use a programmer in service mode. [#16892995] [#16893509] [#16903910] One answer says to read the cluster pins/EEPROM, put the Golf cluster into service mode, and upload the EEPROM with a programmer such as Dragon. [#16892556] The successful final report was that FVDI worked: all immobilizer-block data were copied from the old cluster to the new one and then everything was fine. [#17316744] If you do not already own the right hardware, it is usually cheaper to send both clocks to a specialist than to buy software/tools for a one-off job. [#16891510]
  • #1 16891296
    kozik20l
    Help: 9
    Rate: 16
    Hello, I'm preparing to replace the meter for full fis in Touran 2007. It turns out that there is a meter called Micronas 1T0920864A. I have already purchased a meter from Golf 5 1K0920874B (I will change the housing) it is about the immo ratio which device is the cheapest to recode? I am asking for some tips on how to bite this. I have Vcds and Vasa from the interfaces
  • #2 16891510
    kamyczek
    Help: 394
    Rate: 574
    It will be cheaper to drive to someone who can do it. You will not buy a program that will cover the price of the service because it is much more expensive. It remains to go to someone who has the right device and pay, or if you prefer to send both clocks and receive programmed.
  • #3 16891638
    kozik20l
    Help: 9
    Rate: 16
    The device will be useful for me, it is made for cars, is it cool to support something from Chinese?
  • #6 16891902
    adam7009
    Help: 656
    Rate: 1636
    you see that it is not in the list after all.
    after that, with the immo blocked you won't do anything after the obd.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #7 16892556
    OskiA3
    Help: 5
    Rate: 37
    Read the pins from the counters, give the golf counter in the service mode and upload eeprom, e.g. with Dragon. A reworked topic.
  • #9 16892995
    OskiA3
    Help: 5
    Rate: 37
    VCDSem you won't bite it. Immo4.
  • #11 16893432
    OskiA3
    Help: 5
    Rate: 37
    Read the eeprom clip from the golf counter and insert here. I will give you sm.
  • #12 16893454
    kozik20l
    Help: 9
    Rate: 16
    I understand that this is 24lc33ae? VW Touran 2007: Immo Problem with Micronas 1T0920864A & Golf 5 1K0920874B - Recode Tips & Tools
  • #13 16893509
    mar.wo
    Help: 10
    Rate: 84
    3rd generation immo.
  • #14 16894170
    kozik20l
    Help: 9
    Rate: 16
    hello here is the file from 24c32 reading
    • golfv 24c32.bin (4 KB) You must be logged in to download this attachment.
  • #15 16903910
    OskiA3
    Help: 5
    Rate: 37
    Please, load service mode
    • golfv_24c32_sm.bin (4 KB) You must be logged in to download this attachment.
  • #16 16903912
    OskiA3
    Help: 5
    Rate: 37
    3c / 4 depending on source ;)
  • #17 16903972
    kozik20l
    Help: 9
    Rate: 16
    Ok thanks for the slam I bought the fvdi will come after the holidays I hope it goes smoothly through this interface
  • #18 16903984
    mar.wo
    Help: 10
    Rate: 84
    And it depends only on what rice you get. I keep my fingers crossed and hope you let me know.
  • #20 17316744
    kozik20l
    Help: 9
    Rate: 16
    Hello, I have no problem Fvdi. All immoblock has been copied from old to new and that's all
The discussion revolves around the immobilizer (immo) issues related to replacing the instrument cluster in a 2007 VW Touran with a Micronas 1T0920864A meter, using a Golf 5 1K0920874B meter. Users suggest that hiring a professional with the right equipment is often more cost-effective than purchasing expensive programming tools. Various tools and methods for recoding the immo are discussed, including the use of VCDS, Vasa, and FVDI interfaces. The conversation also touches on reading EEPROM data and the differences between Immo3 and Immo4 systems, with users sharing links to products and resources for further assistance.
TL;DR: One documented success shows cloning the immobilizer block and using FVDI solved the Touran→Golf cluster swap; “All immoblock has been copied from old to new and that’s all.” [Elektroda, kozik20l, post #17316744] Why it matters: If you’re swapping VW clusters, this thread distills the minimal tools and steps that actually worked for DIYers and pros.
What’s the simplest way to fit a Golf 5 1K0920874B cluster into a Touran 2007 (Micronas 1T0920864A)?
Clone the immobilizer block from the original Touran cluster into the Golf cluster, then install. One user achieved success using FVDI and reported no further hurdles. This approach avoids full OBD adaptation when the immo is blocked. “All immoblock has been copied from old to new and that’s all.” [Elektroda, kozik20l, post #17316744]
Can I do the immobilizer adaptation with VCDS alone?
No. A contributor stated plainly that VCDS won’t handle this cluster immobilizer generation. You need EEPROM/service mode or specialized tools to proceed. VCDS remains useful for coding and adaptations after the immobilizer issue is resolved, but it cannot “bite” the immobilizer here. [Elektroda, OskiA3, post #16892995]
Is this setup Immo3 or Immo4?
Expect Immo4 behavior in this swap context. One experienced user identified it as Immo4 for the Golf/Touran case. Treat it accordingly when choosing tools and procedures. This impacts whether OBD-only key learning will work. [Elektroda, OskiA3, post #16892995]
Which affordable tools actually worked for people in the thread?
FVDI worked for the poster who completed the swap by copying the immobilizer block. They confirmed success after the holidays and closed the loop with a positive report. This provides one real-world data point from the same vehicle family and part numbers. [Elektroda, kozik20l, post #17316744]
What’s the recommended professional tool path if I don’t want to gamble?
One member recommended UHDS plus the SMOK Micronas add-on for these clusters. This combo supports service mode and EEPROM operations needed for immobilizer work. It’s a common pro workflow for Micronas-based VAG clusters. [Elektroda, adam7009, post #16891694]
Will a cheap OBD device handle it if the immobilizer is blocked?
No. A user warned that with the immobilizer blocked, you will do nothing via OBD. Plan for bench work and EEPROM access. Consider service mode or direct EEPROM programming to move the immobilizer data safely. “With the immo blocked you won’t do anything after the OBD.” [Elektroda, adam7009, post #16891902]
Which EEPROM stores the immobilizer data on the Golf 5 cluster mentioned?
In this case the poster read a 24C32 EEPROM and shared the dump. Expect similar memory on many Micronas-based clusters, though variants exist. Verify the chip marking before reading or writing to avoid corruption. [Elektroda, kozik20l, post #16894170]
What is “service mode” in this context?
Service mode is a temporary state that allows deeper access to the cluster’s EEPROM and immo data. A helper provided a service-mode file and instructed the poster to load it, enabling the required operations. Tools like SMOK/UHDS implement this. [Elektroda, OskiA3, post #16903910]
How do I swap the immobilizer data? (3-step quick guide)
  1. Read PINs and the EEPROM from the original cluster.
  2. Put the Golf cluster into service mode.
  3. Write the immobilizer block to the Golf cluster, then refit and complete coding. This was the advised flow in the thread. [Elektroda, OskiA3, post #16892556]
Is paying a specialist actually cheaper than buying tools?
Yes, according to a contributor. Professional tools and licenses often cost more than a one-off service. Mailing both clusters to a specialist or visiting a shop can save money and time for occasional users. [Elektroda, kamyczek, post #16891510]
I saw conflicting notes: is it Immo3, Immo4, or something in between?
One participant noted it can be seen as 3C/4 depending on the source. Expect Immo4-like handling, and choose tools that support both where possible. When in doubt, use service mode and EEPROM cloning. [Elektroda, OskiA3, post #16903912]
Any edge cases or failure modes I should watch for?
OBD-only methods fail when the immobilizer is blocked. Plan bench access to avoid bricking the cluster. If a budget tool lacks your cluster in its support list, assume it won’t work reliably for this job. This was explicitly warned in-thread. [Elektroda, adam7009, post #16891902]
Did anyone actually report success after ordering FVDI?
Yes. The original poster later returned and confirmed success using FVDI. They solved it by copying the immobilizer block from the old cluster to the new one. This is the thread’s key outcome. [Elektroda, kozik20l, post #17316744]
Does VCDS help at all after immobilizer cloning?
Yes. Use VCDS for coding, adaptations, and verifying modules after the immobilizer is sorted. It won’t handle the immobilizer transfer itself but remains useful for finalization and checking fault codes. [Elektroda, OskiA3, post #16892995]
What if my EEPROM marking differs (e.g., 24LC33AE vs 24C32)?
The poster initially asked about 24LC33AE but later shared a 24C32 read. Always confirm the exact device before dumping or writing. Reading the wrong chip profile risks data corruption and immobilizer lockouts. [Elektroda, kozik20l, post #16894170]
Should I change the cluster housing when moving from Golf 5 to Touran?
The OP planned to transplant the housing to fit the Golf electronics. This is common for aesthetic and mounting reasons. Do the immobilizer work on the bench first, then handle the cosmetic housing swap. [Elektroda, kozik20l, post #16891296]
