Screen Mirroring on Sansung tv and Huawei P9 litte does not play nc + GO
dudikn 10854 8
  • #1 16892629
    dudikn
    Hello, I have a problem with Samsung UE40J5200 TV playback from Huawei P9 litte nc + Go application. When trying to choose a program from the list I have such a message
    nc +
    No video playback via Screen Mirroring. Disable this option on the device and restart the video.
    I want to mention that materials from Cyfrowy Polsat Go and HBO GO work without any problems.
    Please help me how to run the nc + GO application via screen Mirror on tv.
  • #2 16893038
    suser222
    Help: 74
    Rate: 84
    It is not possible whether the application informs you. This is deliberate, because "nc + platform allows you to use its services on several TVs as part of the Multiroom service."
  • #3 16893842
    dudikn
    Hello, I solved the problem by installing an older version of the nc + go application
  • #4 17073469
    przemekvip20
    Rate: 10
    hello, can you provide which version and where did you install? I have the same problem...
  • #5 17849236
    miroxl
    Rate: 12
    Raises. What app version does not block mirroring?
  • #6 17862738
    dudikn
    It used to work on ver 5.3 but for some time it doesn't work anymore. After a second "freeze frame" as on other versions
  • #7 18192766
    wojzag2
    Run nc + him from the browser and by topic :)
  • #8 18193005
    dudikn
    I have to run nc + go on the tv browser and it will be flashing. You tried?
  • #9 18193229
    wojzag2
    That's right, you're welcome
The discussion revolves around issues with screen mirroring from a Huawei P9 Lite to a Samsung UE40J5200 TV while using the nc+ GO application. Users report receiving a message indicating that video playback is not possible via screen mirroring, while other applications like Cyfrowy Polsat Go and HBO GO function correctly. One user resolved the issue by installing an older version of the nc+ GO app, specifically version 5.3, although it has since stopped working. Alternatives suggested include accessing nc+ GO through the TV's browser, which may provide a workaround for playback issues.
