[Solved] Miracast Connectivity Issues: Xiaomi Redmi Note 7 with Philips 32PHS5302/12 Smart TV
xanterek 27498 5
  • #1 18196057
    xanterek
    Rate: 12
    Hello, I have a Xiaomi redmi note 7 phone and a Philips 32PHS5302 / 12 Smart TV, unfortunately when I turn on miracast, on the TV, in the application on the phone, the TV asks for permission and that's it. Nothing happens.
    So I decided to write here about what you recommend to combine these 2 things, I mean, for example, that I will turn on a movie on the phone, and I can send the image to TV, as it works on Yt. :)
    I have watched many different items that I attach to the HDMi and I also plug in my phone, but I would need help in choosing.
    Thanks in advance.
    ldsone071
    It is strange that it does not mirror from the phone to the TV, there must be an error on some side - have you tried other connections (another phone or a different TV)?
    In your phone settings, you have 'Wireless display' turned on (Settings-> More-> wireless display)?
    As for the arrangements - I personally recommend Xiaomi MiBox - I use it myself and it works brilliantly (but it uses Wi-Fi mirroring, not cables).
    mamix4
    Help: 6
    Try a factory reset on tv, for me in LG 55 "it helped.
  • #4 18198454
    xanterek
    Rate: 12
    Hmm. .
    Xiaomi MiBox- a bit expensive business, I only want to sometimes turn on a movie because the browser is average hula; P
    I have everything turned on in my phone, I don't have another phone, the girl also has a note 7 :P
    Tomorrow I will try to factory reset and try again. :)
  • #5 18198733
    gasak
    Level 19  
    Help: 20
    Rate: 67
    How is WiFi configured in devices? maybe something is biting there, or the router is messing up something.
  • #6 18202750
    xanterek
    Rate: 12
    So it took a while, today we managed to restart everything and we managed to connect the phone ...
    So like this: If someone digs out the topic with the same idea as me, I do not recommend fighting to eat films like that :P
    In Xiaomi, the strip to undo, the exit is on the screen, not built into the screen, such as the circle on the iPhone, so you can see this bar on the TV screen, it is impossible to widen the screen to the max ... it's better to get tired and enter in the viewer on the TV. :)
    Thanks to everyone for your help. I close
