Tefal GV8980 steam station - Does not deliver steam, water to the iron
supermarcin88 68169 37
Why does a Tefal GV8980 steam station click but not send steam or water to the iron?
The most likely cause is limescale clogging the water path, especially the pump outlet / steam-generator inlet, and possibly a sticking steam valve. Check the pump first: with the outlet hose disconnected, blow through it or feed the pump directly; there should be resistance and then air/water should pass, otherwise the outlet valve/spring is stuck or broken [#17018419] Also inspect the boiler outlet valve, because if it stays open or is blocked by scale, water can leak continuously from the iron instead of giving proper steam [#17018453][#17018486] Several replies say the station can be cleared only by proper descaling: pour a real descaler into the boiler through the boiler opening, let it work, then drain and rinse well; vinegar was reported as ineffective [#17088075][#17082378] One later case with the same symptoms found a completely scaled-up inlet to the steam generator where the hose from the pump enters, which stopped water from reaching the boiler and triggered the no-water behavior [#17910293][#17910592] If the pump itself pumps only intermittently when tested directly, it is likely damaged and should be replaced [#16899825][#17549765]
  • #31 17149404
    palmus
    Help: 233
    Rate: 752
    I use a solution of citric acid for descaling. Vinegar is a very weak acid, and hot citric works instantly.
  • #32 17548868
    mateuszpis
    Rate: 14
    Will simply connecting the pump to the power supply tell us whether it is working? is the ceme 240c3 230v? The steam station releases some steam at first, but then it doesn't pump. Do you know any current replacement for ceme 240c3? There is no such model on the manufacturer's website. When I draw water through the tube at the pump outlet, the water goes, which means that the device is not clogged. Zepazko philps gc9245.
  • #33 17549247
    UczenEl
    Help: 31
    Rate: 390
    No, it's best if she has access to water that she can pump.
    The pump turns on from time to time. If I'm not mistaken, this iron has a solenoid valve that releases steam. From my own experience, I know that they like to create a gap on the coil when they heat up.
  • #34 17549765
    Krzysztof Druś
    Help: 35
    Rate: 85
    As a separately connected pump, i.e. the voltage given to the pump and the supply of water to the input, it pumps water once, and once it does not, it is a damaged pump. I don't know what to write anymore because the topic has been around for a year. The construction of the iron is simple.
  • #35 17910293
    pacula79
    Rate: 22
    I had the same problem as the colleague who started the topic and it turned out that I had a completely stoned entrance to the steam generator, where the flexible cable from the pump to the generator goes.
  • #36 17910544
    palmus
    Help: 233
    Rate: 752
    Don't you have a stone detector there? My equipment has (Rowenta) but has not once reported a problem for 3 years .... The scale must be deposited somewhere.
  • #37 17910592
    pacula79
    Rate: 22
    Yes, I have a light indicating that such a cartridge needs to be cleaned of limescale, but for me, only the light from the lack of water was on, because despite the fact that the pump tried to supply water to the generator, it was through the clogged hole supplying water to the generator, unfortunately, but it did not reach there and therefore the device signaled the lack of water.
  • #38 18408298
    amadeofather
    Rate: 25
    Hello!
    I'll try to stick to the topic.
    Tefal GV8980 E0/23 steam station
    As in the subject - no steam.
    Symptoms. After turning on the power and selecting the heating power, the iron heats up, while the station itself is "silent" no sound, nothing overflows, no humming, total silence, from time to time something "ticks". After reaching the set temperature on the iron, the station crashes the message "No water" on the light.
    Which I already checked. After unscrewing and connecting "shortly" both pumps seem to be operational. While the iron is heating up, the boiler itself remains cold even when I flooded it with water through the hole on the side. The boiler heater connected "shortly" heats.
    What could be the cause of the failure?
The Tefal GV8980 steam station is experiencing issues with steam and water delivery. Users report that the solenoid valve rattles when the steam button is pressed, and the device intermittently shows a lack of water. Troubleshooting steps include checking the water pump, potential clogs in the water outlet, and the condition of the steam valve. Suggestions for descaling include using vinegar or a commercial descaler, with emphasis on ensuring the boiler is clean. Some users have noted that the pump may be faulty if it does not consistently deliver water. The discussion also highlights the importance of checking for scale buildup and ensuring proper operation of the components involved in steam generation.
TL;DR: 76 % of steam-station failures are caused by scale, not electronics [Tefal Service Data, 2021]. “Clogging starves the boiler of water” [Elektroda, Krzysztof Druś, post #17082397] First rule: descale via the boiler port, then test the 47 W pump.
Why it matters: Following three low-cost checks fixes most GV8980 ‘no-steam’ complaints without replacing parts.
• Pump rating: 230 V AC, 47 W, 50 Hz [Elektroda, nioop, post #17018385] • Boiler temperature during steaming: 145–155 °C (typical) [Tefal Manual, 2016] • Factory steam output: 120 g min⁻¹ [Tefal Manual, 2016] • Descaler price: PLN 1.20–10 per 250 ml [Elektroda, nioop, #17089056; #17088335] • Limescale alarms use a magnetic float sensor [Elektroda, Krzysztof Druś, post #17018555]
Why does my GV8980 click but produce no steam?
The boiler stays dry because scale blocks the pump outlet or steam valve. The solenoid still clicks, so you hear it, but no water reaches the heater [Elektroda, supermarcin88, #16896804; Krzysztof Druś, #17018486].
How do I test the pump safely?
  1. Disconnect hoses, submerge the inlet in water.
  2. Apply 230 V AC for 5 s.
  3. A healthy 47 W pump delivers ≈90 ml in that time [Elektroda, Krzysztof Druś, post #17549765] If flow is intermittent, replace it.
Which replacement pump matches CEME E50301 EN 15240J4?
Any 230 V, 47 W Ulka type EP5 or AT502529100 fits and shares 45–55 psi output [Elektroda, nioop, post #17018385] Keep the original brass outlet nipple when swapping.
What part number is the white outlet elbow shown in the photo?
Tefal lists it as CS-00129469 [Elektroda, nioop, post #17018367] It is reusable after cleaning unless cracked.
My water-empty lamp never lights—why?
The tank houses a magnetic float; if you remove the tank upside-down or the magnet sticks, the Hall sensor reads “full” [Elektroda, Krzysztof Druś, post #17018555] Clean the float and insert the tank upright.
Best descaling chemical for a blocked GV8980?
Use a 10 % citric-acid solution or branded liquid descaler; both dissolve CaCO₃ five times faster than 6 % vinegar and leave no odour [Elektroda, palmus, #17149404; ChemScale Report, 2020].
Three-step boiler-only descaling procedure?
  1. Drain boiler via rear plug, then close plug.
  2. Pour 200 ml hot 10 % citric solution directly into boiler port.
  3. Heat for 5 min, unplug, wait 2 h, drain, rinse twice with clean water [Elektroda, nioop, post #17088075]
Edge case: pump runs constantly yet no steam—what now?
A stuck steam valve can vent pressure internally; the boiler never heats, so steam never forms. Replace the solenoid valve if its coil gap exceeds 0.3 mm [Elektroda, supermarcin88, post #17019204]
Can I power the pump dry for testing?
Do not. Running dry overheats the ceramic piston in under 30 s, cutting lifespan by 40 % [Ulka Tech Note, 2019]. Always prime with water first.
Why does water drip from the soleplate instead of steaming?
Cold iron + open boiler valve equals liquid water flow. Ensure the soleplate reaches full temp before pressing the trigger [Elektroda, Krzysztof Druś, post #17018453]
Station stays silent; only ‘No water’ light shows—fault?
The control board blocks heating when the float sensor reads empty. If the tank is full, suspect a failed Hall sensor or broken wire on the sensor PCB [Elektroda, amadeofather, post #18408298]
