Bosch PIE631FB1E - Connecting the induction hob without a protective conductor
37158 12
How should I connect this Bosch induction hob when my kitchen supply has L1, L2, L3 and N but no protective earth conductor?
Connect it as a 2N-style hookup: L1 to terminal 2, L2 to terminal 3, and N to terminals 4 and 5, while leaving terminal 1 unconnected [#16561753] Do not bridge N with PE on the hob connection [#16561031] One reply notes that grounding is still required by current regulations, but this hob’s metal parts are internally isolated and forcing a PE/N link is not recommended because a neutral fault or fire damage could create a shock risk [#16561031] Another reply says terminal 1 is unused/free and should simply be left disconnected [#16562394] For warranty purposes, it was also advised to have a service technician verify and sign off the installation [#16562394]
  • #1 16559315
  • #2 16559759
    peter falk
    Home appliances specialist
    Help: 1158
    Rate: 3362
    kor83 wrote:
    additional bridging of PE with N
    What for? So you need grounding for happiness?
  • #3 16559806
    djlukas
    Help: 94
    Rate: 266
    Buddy, you have a bad connection diagram. Connect according to the third picture where it is 2N.
    Buddy peter falk you so seriously or are you kidding me?
  • #4 16560902
    peter falk
    Help: 1158
    Rate: 3362
    Pretty seriously.
  • #5 16561031
  • #6 16561449
  • #7 16561753
    djlukas
    Help: 94
    Rate: 266
    Well, here is my mistake because I looked too quickly at the pictures. I want you to connect L1 to terminal 2 L2 to terminal 3 and N together to terminals 4 and 5 and do not connect anything to terminal 1.
  • #8 16562240
  • #9 16562323
  • #10 16562347
  • #11 16562386
    djlukas
    Help: 94
    Rate: 266
    I also heard that this clamp is free and some are connecting to it a free third phase.
    I always leave it unconnected. If a colleague hides this way and probably he is servicing these devices, it probably is.
  • #12 16562394
  • #13 16562420
The discussion revolves around connecting a Bosch PIE631FB1E induction hob in a three-phase system without a protective conductor. The user seeks advice on wiring the hob using two phases and a neutral wire, as they lack a protective earth (PE). Responses highlight the importance of grounding according to regulations, while some suggest that the hob's design may allow for safe operation without a direct connection to PE. Various wiring diagrams are debated, with emphasis on the correct use of terminals and the potential risks of improper connections. The consensus leans towards avoiding bridging neutral with PE to prevent electrical hazards, while ensuring compliance with installation standards for warranty purposes.
