Coding Hyundai i30 Remote from Aliexpress (433 MHz, HA-T005) with VGA Cable & Cascade Program
_no_rulrs_ 38145 15
How can I code a Hyundai i30 central-locking remote from Aliexpress using a VGA cable and the Cascade program?
To program only the central-locking remote, use a CAN cable, open the Code saving tab in Cascade, press Enter, and then press the open/unlock button on the remote [#16919872][#16920312][#16942031] One reply also says this procedure is for the central-locking remote only and not the immobilizer [#16920312] Another user claims that for this Hyundai i30 only a G-scan 2 can do the job and suggests finding a workshop with that tool [#16942072]
  • #1 16900636
    _no_rulrs_
    Rate: 25
    Hello, I am looking for the entire coding procedure of the new Hyundai i30 remote.
    I am ordering from the Aliexpress remote control to the 433 MHz central lock, ha-t005 and I would like to encode it with the VGA cable and the Cascade program.
  • #2 16901238
    srbastek
    Rate: 38
    Oh, I'm hooked on the subject.
    It may be useful for the future.
  • #3 16912004
    _no_rulrs_
    Rate: 25
    the topic is still valid :)
  • #4 16912240
    coperfild
    Help: 291
    Rate: 1697
    What is a VGA cable, do you have an ordinary kkl or a canem?
    Make a car scana and specify what modules it connects with.
  • #5 16916141
    _no_rulrs_
    Rate: 25
    the cable I have
  • #6 16919872
    coperfild
    Help: 291
    Rate: 1697
    Rather cable with can, in the program menu you need to have the active Code saving tab press enter key and on the remote control you press the opening.
  • #7 16920312
    rob4028
    Help: 66
    Rate: 472
    Do you mean coding the central locking remote control or coding immo?
    Added after 54 [seconds]:
    What year of this I30?
    coperfild wrote:
    Code saving
    is used for coding C.Zamka pilot and that's all, so you do not fire your car .......
  • #8 16923526
    _no_rulrs_
    Rate: 25
    Rather, I just wanted to encode the pilot from the central unit
    I am waiting for this remote control ordered from AliExpress
    and as for immo, I planned to clone a tablet from the original pilot (PLN 100)
    i30 fd 2008 1.6 90km crdi
  • #9 16939421
    _no_rulrs_
    Rate: 25
    current topic
  • #10 16940686
    rob4028
    Help: 66
    Rate: 472
    But access to IMMO this year is no longer valid ..... :cry:
  • #11 16942031
    _no_rulrs_
    Rate: 25
    Hello, I just want to program the remote control from the central lock
  • #12 16942072
    Aleksander_01
    Help: 1167
    Rate: 3436
    Only G-scan 2 will overwhelm. Search for a workshop that has such a device or service.
  • #13 16945164
    _no_rulrs_
    Rate: 25
    I was sure that it can be done by using the Cascade program
    somewhere on the forum I found a similar old topic ... but no details
  • #14 17004501
    dyzmak
    I purchased the VAG KKL PL USB FTDI 232 RL cable.
    I have Hyundai I30 vintage 2007 (FD) 1.6 CRDI 115KM Korean VIN production starts KMHD.
    I want to encode a new immobilizer key.
    Will Cascada be able to encode a new key?
    I have a key without a remote control, not folded.
  • #15 17013221
    rob4028
    Help: 66
    Rate: 472
    You will not do it yourself.
    You need the IMMO code, so look for the man who will find this code ....
  • #16 18886186
    revolt2
    Rate: 115
    I wonder why the IMMO code to adapt the central locking remote control ...?
The discussion revolves around coding a new Hyundai i30 remote control (model HA-T005) purchased from Aliexpress, specifically for a 433 MHz central locking system. Users inquire about the coding procedure using a VGA cable and the Cascade program. Clarifications are sought regarding the type of cable needed, with suggestions pointing towards a CAN-compatible cable. The conversation also touches on the distinction between coding the central locking remote and the immobilizer (IMMO) system, with some users expressing concerns about the necessity of an IMMO code for programming. The need for specialized equipment, such as G-scan 2, is highlighted for successful coding, and there are mentions of difficulties in accessing IMMO codes for newer models.
TL;DR: For Hyundai i30 FD remotes, users report pairing 433 MHz HA‑T005 units via the Cascade “Code saving” function, but “Only G‑scan 2 will overwhelm.” [Elektroda, Aleksander_01, post #16942072] Why it matters: This FAQ helps DIYers decide when Cascade and a KKL/CAN cable are enough and when a pro scanner is required for success and security.
Can I code an AliExpress 433 MHz HA‑T005 remote to a Hyundai i30 FD with Cascade?
Yes, forum users reference pairing through Cascade’s “Code saving” function for central locking. This process pairs the remote to the central locking module only. It does not add an immobilizer transponder to start the engine. Plan your workflow around remote pairing versus IMMO key programming, which are separate tasks. “Code saving is used for coding the central-locking pilot and that’s all.” [Elektroda, rob4028, post #16920312]
Which scan tool is most often recommended in the thread for this job?
Members state that “Only G‑scan 2 will overwhelm,” suggesting that a professional G‑scan 2 can complete the pairing when simpler interfaces struggle. If you lack G‑scan 2 access, consider a workshop equipped with this tool to avoid repeated failures and save time. This aligns with the thread’s strongest single-tool recommendation. [Elektroda, Aleksander_01, post #16942072]
Is the immobilizer affected when I pair the central locking remote?
No. Pairing the central locking remote does not program the immobilizer. Your car will not start with an unprogrammed transponder even if the remote locks and unlocks doors. Treat IMMO key coding as a separate step requiring the immobilizer PIN and appropriate tooling. “You do not fire your car” after using Code saving. [Elektroda, rob4028, post #16920312]
Does a VAG KKL USB cable work for i30 FD key coding?
A KKL cable may communicate with some modules, but it is not sufficient for immobilizer key programming by itself. Key coding requires the immobilizer code and compatible software or a pro scan tool. Users who bought KKL hardware still needed the IMMO PIN to proceed. [Elektroda, rob4028, post #17013221]
What does the Cascade “Code saving” option actually do?
In this context, Code saving enters a pairing mode for the central-locking receiver. With the function active, you press Enter in software and then press the remote’s unlock button to store the code. This links the 433 MHz remote to the central unit but does not touch IMMO. [Elektroda, coperfild, post #16919872]
How do I pair the central locking remote using Cascade? (3 steps)
  1. Connect your CAN-capable interface and open Cascade’s Code saving tab.
  2. Press Enter to activate learning on the target module.
  3. Press the remote’s unlock/open button to store the code. [Elektroda, coperfild, post #16919872]
What if Cascade connects but the remote still won’t program?
Confirm your interface supports CAN and that the remote is the correct 433 MHz type. If pairing still fails, escalate to a shop with G‑scan 2, the thread’s recommended tool for this platform. Hardware limitations are a common cause of unsuccessful attempts. [Elektroda, Aleksander_01, post #16942072]
Will coding an AliExpress remote let my 2008 i30 FD start?
No. A paired remote only controls central locking. To start the car, you need a key with a matched transponder or a cloned chip. The thread author planned to clone the transponder from the original key, which is a separate process from remote pairing. [Elektroda, _norulrs, post #16923526]
What is the CAN bus, and why does my cable need it?
The CAN bus is the car’s controller network connecting modules like the central lock ECU. Your interface must support CAN to access the correct module for pairing on many vehicles. Members explicitly ask whether the user has KKL or CAN-capable hardware before proceeding. [Elektroda, coperfild, post #16912240]
I have a 2007–2008 i30 FD; is IMMO access straightforward?
Not always. One member noted that IMMO access for that year was “no longer valid,” implying tighter access or changed procedures. Expect to retrieve the immobilizer code or use pro equipment if DIY paths fail. Treat IMMO as a separate, more restricted workflow. [Elektroda, rob4028, post #16940686]
Do I need the immobilizer code to add a new key without a remote?
Yes. A member trying to add a non-remote key still required the immobilizer code to complete programming. Without the PIN and proper tooling, DIY attempts stall even if diagnostics connect. Plan for code retrieval or professional service. [Elektroda, rob4028, post #17013221]
What frequency remote should I buy for i30 FD central locking?
The discussion revolves around a 433 MHz HA‑T005 remote sourced from AliExpress for central locking. Ensure your replacement matches this frequency and form factor. Mismatched frequency remotes will not pair or function, even if procedures are correct. [Elektroda, _norulrs, post #16900636]
Is Cascade the best choice, or should I go straight to a pro tool?
Cascade can pair remotes via Code saving when hardware and vehicle support align. However, the thread’s clear recommendation is G‑scan 2 if you meet connection errors or incomplete menus. “Only G‑scan 2 will overwhelm,” summarizing the pro-tool advantage. [Elektroda, Aleksander_01, post #16942072]
Edge case: Why would someone ask for the IMMO code just to adapt a remote?
They shouldn’t. One user questioned why IMMO code would be needed to adapt only the central-locking remote. Remote pairing and immobilizer programming are separate. Confusing the two leads to unnecessary hurdles and costs. Keep tasks distinct to avoid delays. [Elektroda, revolt2, post #18886186]
Can I clone the transponder from my original key to a new one?
Yes, the thread author planned to clone the transponder “tablet” from the original remote for about 100 PLN. Cloning duplicates the IMMO identity, allowing the new key to start the car without dealer coding. Remote pairing remains a separate step. [Elektroda, _norulrs, post #16923526]
What’s a quick success checklist before I start?
Verify: 1) Correct 433 MHz HA‑T005 remote; 2) CAN-capable interface; 3) Cascade Code saving access; 4) G‑scan 2 backup plan. Following this cuts retries and tool-swaps. When in doubt, hand it to a shop with G‑scan 2. [Elektroda, Aleksander_01, post #16942072]
