The remote control is permanently assigned to the car (BCM) together with the transponder, it is coded from the Sps - tis2web application with the MDI or MDI2 interface ...
The discussion revolves around coding the remote control for a 2011 Chevrolet Cruze's keyless entry system. Participants suggest that a diagnostic device is necessary for the coding process. It is noted that the remote control is permanently assigned to the vehicle's Body Control Module (BCM) and must be coded using the SPS - tis2web application with an MDI or MDI2 interface. Follow-up questions address concerns about re-encoding after decoding, with confirmations that the system remains operational and functional when tested. AI summary based on the discussion. May contain errors.
