How to program the remote control for the central locking FH 2010. ?
lukasz56 17862 11
How can I reprogram the central locking remote for a 2010 Volvo FH after replacing the battery?
You cannot reprogram this remote yourself if it has been decoded after the battery change; Volvo treats it as a security feature, and with only one remote you have no way to assign it back to the central locking controller [#18774842] The battery has to be swapped quickly—take the old one out and immediately put the new one in—otherwise the remote may lose its pairing [#18774842] If you still have a second working remote, it is needed for coding; without it, the dealer suggested replacing the central locking controller together with two remotes [#18774842] Before blaming coding, check that the remote board is intact and that it actually transmits using a tester or a radio check [#17207286]
  • #1 17203614
    lukasz56
    Rate: 98
    Volvo FH 2010, the remote control does not show any signs of life after replacing the battery, someone will suggest how to program it to work again?
    Moderated By CameR:
    Separated from the archival topic: https://www.elektroda.pl/rtvforum/topic1312803.html
    Reg. 3.1.19. Do not send messages on archival topics if this is another question, especially other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
  • #3 17204806
  • #4 17205866
    lukasz56
    Rate: 98
    The fuse is good, that's the first thing I checked. The remote control does not work after replacing the battery, it worked before.
  • #5 17205967
    mariann
    Help: 551
    Rate: 649
    lukasz56 wrote:
    The remote control does not show any signs of life after replacing the batteries
    Is the battery installed correctly? Check where the plus and minus should be. Anyone can make a mistake the first time they do it.
  • #6 17207259
    lukasz56
    Rate: 98
    The battery is inserted right at 100%, I suspect that there may also be a problem with coding the remote control because I unfastened the cube of the alarm control unit (the one next to the LCM) looking for why the door from this panel on the driver's door does not close. coding the remote control (turn the ignition switch to the ON position five times and the hazard lights should turn on and then you can code the central locking remote control) but this procedure does not work for me, I don't know why. Someone will tell you how to handle it?
  • #7 17207286
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Include photos of both sides of the remote control board.
    Check with the tester if the remote control "transmits"?
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #8 17207294
    lukasz56
    Rate: 98
    I will add photos tomorrow, when it comes to the pilot test, I will have to get some radio and put it on the loudspeaker, we will see if it cracks because I do not have a special tester, unfortunately.
  • #9 17318442
    lukasz56
    Rate: 98
    CameR wrote:
    Fix the remote!
    The remote has been checked, it is operational, it looks like the remote control has not seen the central locking control unit (I unfastened it to check, maybe it was decoded with the remote assigned?) How can I re-code this remote control? I will add that I only have one for anger .
  • #10 18774270
    zibius
    Hello, was the problem solved? I struggle with a similar one, the pilot is functional, I cannot check the controller, he cannot see the pilot. I will be grateful for the hints
  • #11 18774842
    lukasz56
    Rate: 98
    Unfortunately, it was not possible to connect the remote control with the controller, even the Volvo service did not help, which could not assign the original remote control to the controller (they proposed to buy a new central locking controller with two remote controls for PLN 1,200 net) You have to be careful, e.g. when changing the battery in the remote control, because you need to do it quickly, take one battery out and put in the other, I took out the weak battery and went to the store with it to buy a new one, when I put it on, the remote control was already decoded and because I only had one remote control, I had no way to assign it to the switchboard ( you need a second efficient remote control) This is a Volvo security feature that prevents you from adding a foreign remote to the controller.
  • #12 19705020
    marpil871
    Rate: 10
    Hello, do you have this coding procedure for the second remote control for Volvo FH?
The discussion revolves around programming the remote control for the central locking system of a Volvo FH 2010 after a battery replacement. The user reports that the remote shows no signs of life post-battery change, despite confirming correct battery installation and checking the fuse. Suggestions include verifying the battery orientation, testing the remote's transmission, and re-coding the remote control. The user suspects that the remote may have lost its connection to the central locking control unit, especially after disconnecting the alarm control unit. A critical point raised is that if the battery is changed too slowly, the remote may become unassigned, necessitating a second functional remote for re-coding. The user ultimately faced challenges even with assistance from Volvo service, which recommended purchasing a new central locking controller due to the security features preventing unauthorized remotes from being programmed.
TL;DR: On Volvo FH 2010, losing remote pairing can mean a PLN 1,200 controller replacement; "You need a second efficient remote control." Quick battery swaps reduce unpairing risk; if decoded, coding needs two remotes or dealer tools. [Elektroda, lukasz56, post #18774842]
Why it matters: This helps Volvo FH 2010 owners restore remote locking after a dead battery or module unplug without wasting time or money.
How do I reprogram a Volvo FH 2010 remote after a battery change?
If the remote unpaired during a slow battery swap, you need two working remotes or dealer-level programming. The system blocks adding unknown remotes without an already paired unit. If you only have one remote, coding may fail. In that case, service may recommend replacing the controller and supplying two matched remotes. Fast battery swaps help avoid this situation next time. Test the remote first to confirm it transmits before pursuing coding. [Elektroda, lukasz56, post #18774842]
Whats the safe way to swap the remote battery without losing pairing?
Prepare the new cell before opening the remote. Swap the old cell for the new one quickly to avoid power-loss timeout. Verify operation immediately near the truck after the swap. This minimizes the risk of the remote decoding and losing pairing. If it still fails, assume it unpaired and plan for re-coding with a second working remote or dealer support. "Do it quickly; take one battery out and put in the other." [Elektroda, lukasz56, post #18774842]
Does the five-times ignition ON hazard-flash method work on FH 2010?
A user tried the sequence—turn ignition to ON five times until hazards flash—and it did not work on their FH 2010. The hazards never confirmed programming mode. If this fails, the remote likely needs coding with an existing paired remote or dealer tools. Consider that unplugging modules can complicate pairing. Do not repeat the cycle endlessly; verify your remote transmits first. Quote: "turn the ignition switch to the ON position five times." [Elektroda, lukasz56, post #17207259]
Can I pair a single remaining remote, or do I need two?
You generally need a second already working remote. The system prevents adding unknown remotes, described as a "Volvo security feature." With only one unpaired remote, coding attempts may fail. Owners reported needing dealer help or a new controller kit that arrives with two paired remotes. Plan to secure a second good remote before attempting DIY programming steps. [Elektroda, lukasz56, post #18774842]
Remote dead after battery swapwhat should I check first?
Confirm the coin cell polarity and seating. Ensure the plus and minus are oriented as marked in the holder. Clean the contacts gently if tarnished, then retest near the truck. Battery misplacement is a common first-time error and mimics a dead remote. If it remains unresponsive, proceed to a transmit check with a radio or tester. [Elektroda, mariann, post #17205967]
How can I test the remote without a dedicated RF tester?
Use a basic radio as a quick check. Place the radio near the remote's PCB or case speaker area. Press the remote button and listen for a crackle or buzz in the speaker. Consistent noise suggests the remote is transmitting. Absence of any noise points to a dead transmitter or battery issue. This is not a calibrated test, but it can confirm basic activity. [Elektroda, lukasz56, post #17207294]
Which fuse should I check for central locking if the remote stopped?
Inspect the central locking fuse in the truck's fuse panel before deeper diagnostics. A blown fuse disables locking, regardless of the remote state. Replace only with the specified rating to avoid module damage. If the fuse tests good and the remote worked before the battery change, focus on the remote and pairing. A fuse check is a quick, low-cost elimination step. [Elektroda, Anonymous, post #17204806]
I unplugged the alarm/central locking module; did that erase my remote?
After unplugging the module near the LCM, the remote may no longer be recognized. The reported ignition-cycling method failed to re-enter programming mode on FH 2010. Expect to need a paired second remote or dealer programming to restore locking. Avoid disconnecting the controller during troubleshooting unless necessary. If done, plan for potential re-coding. [Elektroda, lukasz56, post #17207259]
Dealer couldnt program my original remotewhat are my options and cost?
One owner reported the dealer could not assign their original remote back to the controller. The proposed solution was a new central locking controller with two remotes for about PLN 1,200 net. This is the edge case when coding fails and security blocks additions. Budget accordingly if you lack a second working remote. [Elektroda, lukasz56, post #18774842]
How do I know if the controller sees my remote?
Verify the remote transmits first, using an RF tester or a simple radio crackle check. If it does not transmit, the controller cannot see it. If it does transmit and there is no response, pairing may be lost. At that point, plan for coding with a second paired remote or dealer tools. "Check with the tester if the remote 'transmits'?" [Elektroda, CameR, post #17207286]
Is there a DIY procedure to code a second remote on FH 2010?
The thread does not confirm a working DIY sequence. The commonly cited five-ignition-cycle method did not enter programming mode in this FH 2010 case. Consider that later systems can require dealer-level tools or a known paired remote to add another. Without confirmation, avoid repeated attempts and test the transmitter first. [Elektroda, lukasz56, post #17207259]
Should I repair the remote hardware before attempting coding?
Yes. If the remote does not transmit or power up, coding cannot succeed. Inspect the PCB, switch domes, and battery contacts, then repair as needed. Replace the cell with a fresh, correct type. After confirming transmission, attempt coding steps or consult a dealer. Expert advice was blunt: "Fix the remote!" [Elektroda, CameR, post #17204073]
