JBL Charge 2+ Speaker: Sound Cuts Out, Temporary Fix with Light Knock - Problem Causes?
figa1337 4146 7
  • #1 16901217
    figa1337
    I am the owner of the JBL Charge 2+ speaker and at some point it started to interrupt the sound. When it is slightly "knocked", the speaker makes a sound for some time.
    What may be the problem?
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    The so-called "cold February". What have you checked so far?
  • #3 16901518
    figa1337
    I undressed it and turned it off because I am afraid that I would tear cables, for example
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Then the service.
    Bartek0009102
    Rate: 11
    That's what these jbls are. A friend had a charge 3 with the same problem, he gave it back for a guarantee and they replaced him.
  • #6 16901548
    figa1337
    Okay, thanks only to the guarantee, so if I gave him to electronics, would he do it to me?
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    No problem.
  • #8 16901556
    398216 Usunięty
    Help: 3925
    Rate: 9371
    Elketronik sure no, but electronics engineer for sure.
✨ The JBL Charge 2+ speaker is experiencing sound interruptions, which temporarily resolve when the device is lightly knocked. The owner has expressed concern about potential internal damage, particularly to the cables, after attempting to inspect the speaker. Responses suggest that the issue may be common among JBL products, with a recommendation to seek professional repair services or utilize warranty options for replacement. It is noted that while general electronics repair services may not be suitable, an electronics engineer could provide assistance.
