[Solved] CLASS 430A rectifier - starting - someone will explain what is displayed on the
kamil12173 8922 9
What does the display on a CLASS 430A rectifier/starter show, and what does it mean when the value rises during starting?
It is an ammeter showing the charging current flowing through the terminals, so the display is useful for monitoring current draw [#16902605] [#16902608] [#16902623] A reading like 60 increasing to 100 means the current is rising in amps, not volts [#16902608] [#16903676] The higher the current, the more the unit is delivering/flowing through the circuit [#16903676] If the battery is fully discharged, do not use the start function immediately; charge it for about 10 minutes first [#16903034]
  • #1 16902587
    kamil12173
    Rate: 61
    Hello, I have a little problem.
    I have a rectifier with a class 430 start. In the attachment there is a control panel.
    The problem is that I don't know what parameter is displayed on this display.
    I do not write anywhere, is it Volts or something else, this parameter usually increases, for example, on the start function it can have 60 and grows, for example, to 110. Has anyone had a deal and will tell you what this parameter is and is it useful?
    • CLASS 430A rectifier - starting - someone will explain what is displayed on the 615820955_2_644x461_prostownik-samochodowy-class-430-rozruch-12-24v-z-rozruchem-400ah-dodaj-zdjecia.jpg (40.35 KB) You must be logged in to download this attachment.
  • #3 16902608
    robokop
    Help: 1763
    Rate: 6372
    The ammeter is - it indicates the current that flows through the terminals.
  • #4 16902618
    kamil12173
    Rate: 61
    Thank you, after searching in googles, it just seemed to me that maybe it would be what you are writing. And I will ask, because when I take the start-up function for a dead battery, the value is initially, for example, 60 and it grows and wait a while until the parameter increases? Because, for example, it can increase to 100. The more the better?
  • #5 16902623
    polmar
    Help: 38
    Rate: 220
    This is an ammeter, rather very useful
  • #6 16902676
    kamil12173
    Rate: 61
  • #7 16903034
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    When the battery is fully discharged, do not use the start-up function, start charging for about 10 minutes
  • #8 16903515
    kamil12173
    Rate: 61
    and how with these amps increasing at startup?
  • #9 16903676
    helmud7543
    Help: 1216
    Rate: 1564
    The lower the resistance = the higher the current consumption of the receiver, the more A. Is it good? How do you treat a fallen battery in this way (and you do not support spinning the engine), it's not really, unless you are charging a cattle over 1000 Ah ...
  • #10 17734231
    kamil12173
    Rate: 61
    Thank you for your help.
The discussion revolves around a Class 430A rectifier, specifically its control panel display, which indicates the charging current during the starting function. Users clarify that the displayed parameter is an ammeter reading, showing the current flowing through the terminals. It is noted that when starting a dead battery, the initial value may rise from 60 to 100 amps, indicating that higher values are generally better for charging. However, caution is advised against using the start function on fully discharged batteries; instead, a preliminary charging period of about 10 minutes is recommended. The relationship between resistance and current consumption is also discussed, emphasizing that lower resistance results in higher current draw.
