Windows 10 Home (10.0.16299) Update: Brightness/Colors Issue, Screen Darkening & Fix
1900xxx 3924 2
  • Disable Windows 10 automatic contrast dimming
    #1 16904503
    1900xxx
    Rate: 27
    Yesterday I did some major update to Windows 10.
    The current version of the system is: Windows 10 Home (10.0.16299)
    The problem is that after this update I can't adjust the brightness / colors,
    everything got so dark (I don't know how to describe it exactly).
    The thing is that when starting the system as it enters the desktop,
    this is old for half a second and turns darker.
    How to turn it off so that it does not dim?
    I read on the internet that in this amendment some improvements were made to contrasts, etc.
    But it doesn't suit me: /
    Does anyone know how to disable this option?
  • #2 16904607
    piotr.solek
    Help: 18
    Rate: 15
    Take a picture and insert. In the background, you can also open the screen brightness settings window as well as the Windows system window with additional brightness settings / night mode.
  • #3 16904625
    1900xxx
    Rate: 27
    @ piotr.solek I did not change any screen brightness settings, it was done yesterday evening after installing the Windows 10 update.
    I have the night mode turned off.
    This is exactly the point:
    "... UI updates with Fluent Design: Edge now supports improved dark theme, offering darker blacks and better color contrast , text and icons. This is the answer to many of the accessibility issues that make Edge more visually friendly. As for Fluent, the browser now supports the well-known Reveal effect, which appears on navigation buttons, action buttons, tab bar buttons and lists. Microsoft also responded to Insider feedback and improved the quality of acrylic (the translucent material in Fluent Design System) so that more colors show through the title bar (tab strip). ... "
    Can you somehow turn off this "Fluent"?
    I've already got the hang of it, set the options in the nVidia panel
