[Solved] Screen Brightness Adjustment Issue on Dell Inspiron N5040 with Intel HD Graphics 8.15.10.2900
5661 12
Why can't I change the screen brightness on a Dell Inspiron N5040 with Intel HD Graphics 8.15.10.2900, and how can I fix it?
The brightness problem was caused by TeamViewer; uninstalling it made the issue disappear and restored normal brightness control [#19461699] Earlier, the thread suspected a Windows 10 update and suggested rolling back or reinstalling the graphics driver, but Dell drivers still did not fix the problem [#17185182][#17188849]
  • #1 17184627
  • #2 17184888
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    The screen is dark and I cannot brighten it.
    Highlight the lamp on the side, see if you have the image content under this "darkness"> eg Win desktop
    What do you have after other exits?
    ps
    Dell Inspiron N5040 (platform 48.4IP01.011 UMA MB 10263-1)
  • #3 17185102
  • #4 17185162
    lisek
    Help: 6352
    Rate: 6883
    This is what it is like in the end?
    :idea: x you write that dark, now that very bright ????????????
  • #5 17185182
    Matuzalem
    Help: 1653
    Rate: 1101
    If it is Windows 10, and "yesterday" update was downloaded, the symptom may be due to it. In this case, you can try to roll back the previous driver versions.
    If the system is different, then also in this case changing / reinstalling the driver will not hurt.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #6 17185413
  • #7 17185898
    matixxx66
    Recently, when installing a new Windows, I had it too, but I have dell 5010 I downloaded ati drivers from della and everything worked
  • #8 17186044
  • #9 17186058
    matixxx66
    Did you try on Dell's side?
  • #10 17186075
  • #11 17188849
  • #12 17192838
  • #13 19461699
The user is experiencing an issue with screen brightness adjustment on a Dell Inspiron N5040, specifically with Intel HD Graphics driver version 8.15.10.2900. Initially, the screen was too dark, and after a reboot, it became excessively bright with no ability to dim it. The problem arose after a Windows 10 update, and attempts to roll back the driver were unsuccessful. The user also faced difficulties installing the latest Intel drivers due to system compatibility issues. Suggestions included reinstalling drivers from Dell and checking for updates, but the user reported that Dell's drivers did not resolve the issue. The brightness can only be adjusted during the boot process when the Dell logo appears.
TL;DR: On a Dell Inspiron N5040, 1/1 reported case was fixed 100% by uninstalling TeamViewer; "The reason was the TeamViewer application." [Elektroda, Anonymous, post #19461699]
Why it matters: This helps Dell Inspiron N5040 owners on Windows 10 quickly restore stuck brightness control when drivers look fine but software conflicts block changes.
What finally fixed the Inspiron N5040 brightness control issue in this thread?
Uninstall TeamViewer. The original poster removed TeamViewer, then brightness control immediately worked again. "The reason was the TeamViewer application." [Elektroda, Anonymous, post #19461699]
Did a Windows 10 update trigger the brightness problem?
Yes. The issue appeared right after a Windows 10 update. The user then planned to try the latest manufacturer drivers. [Elektroda, Anonymous, post #17185413]
Why won’t Intel’s latest graphics driver install on this system?
The Intel installer showed: “This system does not meet the minimum requirements.” That message blocked installation of the latest graphics driver. [Elektroda, Anonymous, post #17186044]
Should I try Dell-provided graphics drivers first?
Yes. A Dell 5010 user fixed display behavior with drivers downloaded from Dell. That suggests trying OEM drivers on similar Dell models. [Elektroda, matixxx66, post #17185898]
Why did my screen switch from dim to very bright after a reboot and refuse to dim?
The thread starter reported this exact symptom after restarting the laptop. They could not dim the screen afterward. [Elektroda, Anonymous, post #17185102]
How can I tell if this is a hardware backlight issue instead of software?
Shine a lamp at the screen to look for a faint image when it seems dark. "Highlight the lamp on the side, see if you have the image..." If you see the desktop, image generation works and the darkness is from backlight level. [Elektroda, lisek, post #17184888]
I can change brightness only when the Dell logo appears. What does that mean?
In this case, brightness keys worked only during the Dell splash screen. After Windows loaded, brightness control stopped responding. [Elektroda, Anonymous, post #17188849]
How long did it take the OP to confirm the root cause?
Three years later, they confirmed the fix and cause. They wrote that removing TeamViewer solved it. [Elektroda, Anonymous, post #19461699]
How do I remove TeamViewer to restore brightness control?
Do this:
  1. Uninstall TeamViewer from the system.
  2. Restart Windows.
  3. Test Fn brightness keys and Windows Settings > System > Display. [Elektroda, Anonymous, post #19461699]
Can rolling back or reinstalling the graphics driver help?
Yes, especially after a Windows 10 update. A contributor advised rolling back or reinstalling the driver. "Try to roll back the previous driver versions." [Elektroda, Matuzalem, post #17185182]
