Huawei P8 Lite ALE-L21: Phone Not Turning On, U2001 System, Low Voltage at C302 & No Buck Voltage
kamin23 11379 9
Why does a Huawei P8 Lite ALE-L21 not turn on after a U2001 replacement, with only about 1 V on C302 and no buck voltages on the coils?
The fault is more likely around U301, its solder balls, or a short on one of its outputs than on U201, so check U301’s startup behavior and all its lines before replacing it. Measure VPH with only the USB board connected, and ideally use an oscilloscope to see whether U301 produces a brief startup pulse on its outputs; also verify that oscillator X402 is working [#16905853][#16907267] If you only have a meter, use continuity mode to check each BUCK and LDO output of U301 one by one, because a short after U301 will not necessarily show up as a VBAT/VPH short [#16908597][#16910499] The shorting of the coil to ground during the U2001 job may not have killed U301 directly, but overheating can cause balls under U301 to lift or a short under the chip [#16907267][#16908597] Replacing U301 is possible, but it is risky without proper reballing equipment because you can damage the processor [#16908597]
  • #1 16905794
    kamin23
    Rate: 14
    Hello, I have a problem with the Huawei P8 Lite ALE-L21 phone that does not turn on. In general, the phone only worked with a larger backlight, the LCD began to flash and the phone took over 1A. The U2001 system was warming up so I decided
    replace it, unfortunately I did not notice that during the exchange I shorted the coil with the ground. Now the phone does not turn on, when connected to the computer, nothing works. I noticed that on C302 I have only 1V and it should be
    2.5V and after turning on the power on L300, L301, L302, L304 coils, no Buck voltage. Could U301 be replaced? Huawei P8 Lite ALE-L21: Phone Not Turning On, U2001 System, Low Voltage at C302 & No Buck Voltage Huawei P8 Lite ALE-L21: Phone Not Turning On, U2001 System, Low Voltage at C302 & No Buck Voltage Huawei P8 Lite ALE-L21: Phone Not Turning On, U2001 System, Low Voltage at C302 & No Buck Voltage Huawei P8 Lite ALE-L21: Phone Not Turning On, U2001 System, Low Voltage at C302 & No Buck Voltage
  • #2 16905853
    Kuzyn
    Help: 21
    Rate: 64
    VPH voltage is? Connect only the usb plate (without batteries) and then measure the voltage on the buck. It's best to use an oscilloscope to see if you have a short circuit on any of the lines. Also check that the oscillator (X402) is working.
  • #3 16907110
    kamin23
    Rate: 14
    VPH is. I changed the oscillator to the second phone still does not turn on. There is no voltage under USB.
  • #4 16907267
    Kuzyn
    Help: 21
    Rate: 64
    How did you check these voltages? Meter or oscilloscope? On the oscilloscope, you can see if the U301 is trying to start (instantaneous peak voltage at the outputs).
    I asked you to check if the oscillator is working to make sure that the U301 is working.
    Shorting the L2002 coil to ground may not whip u301.
    When I think so now, most likely during the replacement of U2001 you were warming up too much and the balls came out from under U301, or there was a short circuit under it. But without the right measurements, it's just taking.
  • #5 16907309
    kamin23
    Rate: 14
    By meter, I do not have an oscilloscope. In 2001 it was glued and probably your theory of damaged balls is true. Although I did it carefully.
    Added after 4 [hours] 24 [minutes]:
    The maximum heating temperature I used was 340 degrees. When the phone connected to the power supply does not show a short circuit.
  • #6 16908597
    Kuzyn
    Help: 21
    Rate: 64
    The power supply short circuit will only show you if it is on VBAT or VPH. However, the short circuit after U301 will be characterized by the fact that the voltage at the outputs of this system will appear for a short period of time (this time depends on which line is the short circuit, because all outputs start in turn, not all at once). PMU, after detecting a short circuit, resets and tries to start again.
    In this case, the heating temperature has the least impact. The more important is the heating time, because the longer you heat, the more the temperature spreads over the plate, which, if other glued elements are nearby, causes the balls to push the balls out from under the system.
    I set 450 degrees to change this element, but I play very briefly. I have not yet damaged it in this way u301.
    If you decide to replace the U301 (I'm guessing you probably don't have reballing equipment), here you have to be very careful, because when you replace it you can kill the processor.
  • #7 16909005
    kamin23
    Rate: 14
    Thanks for clarifying my problem.
    The disc is intended for parts. Rather I will not replace the U301, I do not have such equipment. I have one more disc that resets all the time. The plate after flooding, of course cleaned. There is no short circuit on VBAT and VPH. So the reset can also be associated with a short circuit after the U301 system? Using a meter, it will detect which PMU line has a short circuit?
  • #8 16910499
    Kuzyn
    Help: 21
    Rate: 64
    Yes you will. Of course, if it is not a reduced resistance, only a short circuit. Set the meter to check circuit continuity and check each output of U301 in turn. It will take you a bit, because you have to check all BUCKs and LDOs, and there are some.
  • #9 17841878
    kamin23
    Rate: 14
    Is it possible to observe a temporary peak of voltage at the outputs with such a toy as dso138 ?.
  • #10 17843810
    kamin23
    Rate: 14
    I noticed that on L302 I only have a moment of tension then disappears. Buck1, buck3 and buck4 are normal. After connecting the power supply, the current consumption is 0.05A and disappears after a few seconds. On the L203 coil I have 3.66Va should be 3.8-4.2V. I have a damaged U301 or U201? Will someone suggest?
The discussion revolves around a Huawei P8 Lite ALE-L21 that fails to power on after a repair attempt involving the U2001 system. The user initially reported issues with the LCD flashing and high current draw. After replacing U2001, a short circuit occurred, leading to the device not turning on. Participants suggested measuring voltages at various points, particularly around U301 and C302, and checking for shorts using a multimeter. The user confirmed low voltage readings and expressed concerns about potential damage to U301 due to overheating during the repair. Further troubleshooting steps included checking the oscillator and assessing the power supply for shorts. The user ultimately decided against replacing U301 due to lack of equipment and inquired about the possibility of detecting shorts with a multimeter.
