Huawei P8 lite L-21 - Telephone after flooding, red LED blinks and does not turn
paskol 17355 6
  • Flood damage leaves phone stuck at red LED only
    #1 16751565
    paskol
    The phone was after flooding. He did not react at all. After undressing cleaning and drying. After connecting to the charger, the red LED blinks all the time. The phone does not respond to power and you can not enter the recovery or download mode. Immediately after depositing it for a second it was detected under pc, I was happy, but unfortunately prematurely. Do you have any suggestions on what else you can do?
  • #2 16751588
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    What did you eat and how you dried it? Since he was after flooding, why do you want to enter recovery or download mode?
  • #3 16751611
    paskol
    I cleaned it with spirit, visible white air raids. After cleaning, the phone will be able to receive a message if the diode blinking when connected to the charger can be called a telephone call. Earlier he did not react to anything. Now the red LED blinks for some time later, the phone will vanish once and vibrate again and the red LED flashes again.
  • #4 16751653
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    It is best to leave the plate in isopropanol for a longer time. Measure the voltage on the battery. Because something seems to be too low for the phone to start.
  • #5 16751743
    paskol
    the battery before flooding was about 80% rather hesitant, it was low battery.
  • #7 16753697
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    I meant not only guessing the real measurement of the voltage on the meter with the meter. It could have even 100% before flooding, but as the board has a short circuit it will already have 0%
The Huawei P8 Lite L-21 experienced flooding, leading to a non-responsive state. After cleaning and drying, the device shows a blinking red LED when connected to a charger but does not power on or enter recovery/download mode. Initial detection by a PC was short-lived. Suggestions include using isopropanol for cleaning, measuring battery voltage, and considering the possibility of a short circuit affecting the device's functionality. The battery was noted to be low before the flooding incident, which may contribute to the issue.
