Audi A4 B6 2003. - Parktronik does not work, no speaker sound
bolekf2 10473 3
  • #1 16906128
    bolekf2
    Rate: 258
    Hello, I have a problem with the A4 B6 sedan. After turning on the reverse, there is no signal, it is completely silent. Park in the controller. there are no errors, the rear lights work in the car.
    The driver itself was replaced, no improvement whatsoever.
    Then it will get to the speaker and replace it, the one in the rear shelf, under the rear window, next to the speaker, in the center. Still no improvement whatsoever.
    After connecting to the controller and testing the speaker, it clearly works and squeaks. After turning on reverse, complete silence.
    In the controller, when reverse gear is engaged, it is clearly visible in the parameters that the controller sees reverse gear engaged.
    The loudspeaker harness has been checked and it is ok. Maybe there is somewhere else, another loudspeaker from the parktronic that has been damaged?
    The car has a hook, so it occurred to me that maybe after connecting the hook, something deactivates in the controller and the parktronic turns off, maybe there is a switch somewhere, in the middle of the car, or at the hook itself, although I couldn't find anything like that.
  • #2 16906321
    bodzio012
    Help: 161
    Rate: 780
    If there is a hook, then this is the hook module to disconnect if the trailer plug is fastened, if you have already checked for errors, check how the sensors see the obstacle, do they work?
  • #3 16906382
    bolekf2
    Rate: 258
    Someone could take a look at the diagram, is the cut-off only about giving the mass to pin 5, the 16-pin plug in parktronic?
    In this case, you can check if there is no mass on the 5th pin, or cut this wire, then the system should work, or I'm right, because I'm not 100% of the diagram and description
  • #4 16967811
    bolekf2
    Rate: 258
    The problem was just in the hook harness, fixed and it's working. Thanks for your help, best regards
