2004 Audi A4 B6 Bixenon Self-Leveling Indicator Issue after Parking Stand Replacement
mateuszkaizer 7851 3
  • #1 16639279
    mateuszkaizer
    Rate: 15
    Hello, I recently became a user of the Audi A4 B6 from 2004 with bixenon and I encountered a problem when replacing the parking stands because when removing the lamps I had to disconnect them, after reassembly, all the lights work but there is no leveling and the indicator light on the meter is on. Connections to the lamp checked and cleaned twice. The sensors on the swingarms are good too. In VCDS it shows no error. I'm waiting for help. best regards
  • #2 16641693
    v_dawid_v
    Check if the cables from the leveling motor did not fall off when removing the parking lot, the cables go inside and from what I associate they are close to each other after connecting as everything is ok, the error will disappear by itself
  • #3 16643178
    mateuszkaizer
    Rate: 15
    I have already checked all the contacts in the lamp and the connection cubes several times, cleaned with a preparation for electrical contacts. Still the same
  • #4 16643824
    robi1214
    Help: 151
    Rate: 869
    Xenon calibration
    will do the trick.
